Stop for Pocket-Hole Assembly - Router Forums
 26Likes
post #1 of 13 (permalink) Old 08-12-2017, 04:10 PM Thread Starter
Default Stop for Pocket-Hole Assembly
Making more and more cabinets with pocket-hole construction and been working round holding parts in alignment while driving the screws. I watch these YouTube videos where the assembler holds the part with one hand, drives the screws with the other and it winds up in the exact place he's locking for - this doesn't happen for me. I wind up digging out a scrap of plywood, clamping it to the one part and using it as a stop while I'm driving the screws as shown in the first photo. This works pretty well, but you still have to get (and hold) the edges lined up so they don't move. Getting ready to assembly some cabinets and decided that it was time to make something that worked.
A couple of scraps later, and I have a little fixture that locates on the edge of the panel, holds the part being attached flush to the edge and allows me to drive the screws without the parts pushing out of alignment.
kp91, BrianS, Mike and 11 others like this.
tomp913 is offline
post #2 of 13 (permalink) Old 08-12-2017, 05:40 PM
RainMan 2.0's Avatar
Great idea Tom , I will implement this myself . Funny how the simpler things like that can help so much
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 13 (permalink) Old 08-12-2017, 06:09 PM
CharleyL's Avatar
First Name: Charley
I usually do it the way that you are doing it, because they move on me too. Some wooden shop made T squares and sometimes a clamp or two to hold it in place. I love pocket screws, but hate their appearance, so I will only use pocket holes and screws where there's no way to see them from the outside of what I'm building, or when reaching into a cabinet. I'll usually use biscuits, glue, and clamps or dados, glue, and clamps where the pocket holes and/or screws could be seen, but pocket screws sure make assembly easy for me when I can keep them hidden in the design. Oh, I hate the pocket hole plugs too.
Right now I'm building burial urns. The mahogany wood that I'm using is only 9/16" thick and not 3/4" (from my source that size). The 4 sides are mitered and splined at the corners, but the top is attached using the Kreg mini pocket hole jig to drill a pocket hole in the center of each side and a stainless #7 round head screw is used in each of the four sides, from the inside (Kreg doesn't offer 3/4" #7 fine or coarse thread stainless pocket screws) to attach the top. I use the same stainless screws countersunk into the bottom to attach it into the sides. The bottom can then be removed to place the cremains, but no fasteners will be visible when the urn is fully assembled and sitting upright. The urns are being stained and finished like fine furniture, but they should survive well if ever placed in the ground.
Charley
tomp913 likes this.
Central North Carolina
CharleyL is offline
post #4 of 13 (permalink) Old 08-12-2017, 07:36 PM
Good solution. Pretty much what I do in this circumstance, although I'm inclined for appearance sake, to use a Dado instead. Like you, I don't care tor the look of pocket holes. I have never been able to fill the in so they look OK.
tomp913 likes this.
post #5 of 13 (permalink) Old 08-12-2017, 08:35 PM
kp91's Avatar
First Name: Doug
Frustration is the mother of invention
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #6 of 13 (permalink) Old 08-12-2017, 08:52 PM
First Name: Jerry
We have no way of knowing how many takes were taken in preparation for the demo on the otherwise great concept of pocket holes assembly. As happens so often a little inhumanity is required to get the final results that one is looking for.
Great photos showing what your did Tom.
Jerry
tomp913 likes this.
Jerry Bowen is offline
post #7 of 13 (permalink) Old 08-12-2017, 09:11 PM
Good idea Tom. I discovered that when I use the short drivers I have a tendency to angle my drill too far away from the surface with the pocket hole. That was pulling my pieces out of alignment. Using the longer drivers helped me a great deal. It is always the little things that make you crazy.
kp91 and tomp913 like this.
post #8 of 13 (permalink) Old 08-12-2017, 09:43 PM
kp91's Avatar
First Name: Doug
@Mike I may have to see if that makes any difference on my projects
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #9 of 13 (permalink) Old 08-13-2017, 04:24 PM
chessnut2's Avatar
I have the same problem, and using the longer driver really does help. I discovered something by accident that I may use in the future. I drilled a couple of holes in a board, not knowing that the stop collar was slightly out of position. It was allowing the bit to go a little deeper than I intended. I realized it when I took the board out of the jig, and saw a slight indentation cut into the blue plastic where you set the board down to be clamped into the jig.
When I was assembling the joint, I decided to see if the tiny amount of overpenetration would allow me to make a starter hole in the piece I was joining to. I got the joint into postition, then inserted the bit into the hole and turned it by hand enough to spin the bit without actually drilling the shoulder any deeper. It put just a little more than a dimple in the blank piece, and it seemed to make the screw start where it was supposed to instead of "walking". It may have been a one time piece of luck, but worth trying.
Gaffboat likes this.
chessnut2 is online now
post #10 of 13 (permalink) Old 08-13-2017, 05:06 PM
vindaloo's Avatar
First Name: Angie
Originally Posted by chessnut2 View Post
................It was allowing the bit to go a little deeper than I intended. I realized it when I took the board out of the jig, and saw a slight indentation cut into the blue plastic where you set the board down to be clamped into the jig..............
Oh heck, glad it isn't just me that has those on the blue jig
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
Band Saw Pocket Hole Plug Cutting Jig Dejure Jigs and Fixtures 12 11-25-2015 09:56 AM
Small Circle Cutting (no centre hole) Cowbell General Routing 14 05-26-2014 09:20 AM
Kreg K2000PP ProPack Pocket Hole Jig $91 at Amazon.com evolve The Bargain Bin 1 08-20-2006 02:59 PM
Routing a hole Learning Herb Tools and Woodworking 11 03-20-2006 05:29 PM
hole saw vs forstner bit reds_21 Tools and Woodworking 6 03-20-2005 10:48 AM
