A Different Clamp - Router Forums
 13Likes
  • 13 Post By Dejure
post #1 of 8 (permalink) Old 08-21-2017, 08:47 PM Thread Starter
Dejure's Avatar
First Name: Kelly
Default A Different Clamp
SMALL PARTS HOLDING CLAMP
A small parts holding clamp replaces your fingers for holding small items when cutting them on a band saw, sanding them on a belt sander, drilling or carving them.
There are many variations of small parts holding clamps. Mine are inspired by wood Jorgensen clamps, but use only one tightening screw.
These can be made in any size you desire. Too, there are various ways you can approach some aspects of the construction. I will attempt to point out alternatives as they become relevant.
Those experienced in woodwork probably just need to look at the clamp to see how to go about building it. That said, to build this clamp, you need the parts listed below. All the parts can be had from any decent hardware supply.
1) some scrap plywood or a good hardwood sufficient to make your clamp;
2.1) a toilet T-bolt [for the pivot];
2.2) a 1/4"x20 TPI nut [for the pivot];
2.3) two quarter inch flat washers;
or
2.1) a 1/4" x 20 TPI screw [for the pivot];
or
2.1) a 1/4" x 20 TPI Allen screw [for the pivot];
or
specialty furniture screw [for the pivot];
or
2.1) a 3/8" dowel;
2.2) two number six pan head screws;
2.3) two number six flat washers;
3) a 1/4" x 20 allthread rod;
4.1) two 1/4" x 20 nuts (to double nut (lock) the end from coming loose);
4.2) a 1/4"x20 female knob;
4.3 a 1/4"x20 flat washer;
or
4.1) a 1/4" x 20 T-nut;
4.2) a 1/4" x 20 nut;
4.3) a 1/4" x 20 flat washer;
5) 1/4" x 20 TPI female knob;
6) 1/4" x 20 TPI allthread rod
These are quite easy to make and take only a little while. Most the time is spent waiting for the glue to dry. Too, everything you need for them can be found at a hardware supply.
For further details on how to build these, go to:
https://www.instructables.com/id/SMA...HOLDING-CLAMP/
Name:	_Finished Clamps-1.jpg
Name:	Hardware - T-Nut.jpg
kp91, Mike, JFPNCM and 10 others like this.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #2 of 8 (permalink) Old 08-21-2017, 09:57 PM
Very cool way to keep your fingers! The curve gives you a little wiggle room the straight Jorgenson clamps don't.
post #3 of 8 (permalink) Old 08-22-2017, 04:39 AM
JOAT's Avatar
First Name: Theo
I don't think I have ever made anything small enough to need a clamp of any sort. But if I did, I'd just use vice grips.
JOAT is online now
post #4 of 8 (permalink) Old 08-22-2017, 08:21 AM
hawkeye10's Avatar
First Name: Don
Great post Kelly. I lot of people will benefit from this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #5 of 8 (permalink) Old 08-22-2017, 10:21 AM
chessnut2's Avatar
Very cool, Kelly. I'll use it. Thanks.
chessnut2 is offline
post #6 of 8 (permalink) Old 08-22-2017, 01:37 PM
Nicely done Kelly.
post #7 of 8 (permalink) Old 08-22-2017, 01:50 PM
Never mind just holding small parts Kelly. That design makes a good extended reach clamp too.
post #8 of 8 (permalink) Old 08-22-2017, 08:06 PM
old55's Avatar
First Name: Ross
Nice job Kelly.
Ross,
old55 is offline
sanding blocks PhilBa Project Plans and How To 20 08-25-2015 07:26 PM
Rolling Clamp Rack todd628 Show N' Tell 11 04-25-2015 06:31 PM
Woodpecker's Aluminium Box Clamp Review timbertailor Jigs and Fixtures 12 10-11-2014 10:09 PM
Kelly's New Router Jig Dejure Jigs and Fixtures 1 01-19-2014 12:09 AM
Built in book shelf/ Shopnotes Clamp rack fasttruck860 Show N' Tell 14 09-25-2009 10:40 PM
