Please rescue me... - Router Forums
 4Likes
post #1 of 15 (permalink) Old 09-15-2017, 10:11 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
Default Please rescue me...
...from this morass.
I've searched this forum, Googled for an answer and wandered through Youtube, all to no avail.
I have an insatiable desire to inlay an oval of non standard dimensions using an inlay kit.
So, a template needs to be made.
For the life of me, I cannot figure out how to determine the offsets needed to construct said template in order to yield a 4.5" x 6.5" oval and corresponding cavity.
Somebody, somewhere must understand this arcane alchemy and can explain it in small, simple words for me....PLEASE.
I would be eternally grateful and will sing your praises to one and all.
jj777746 and artman60 like this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #2 of 15 (permalink) Old 09-15-2017, 10:34 PM
Found these
If you're into Sketchop https://help.sketchup.com/pl/article/3000084
And here is a long-winded video showing step-by-step
I did a Google sketch - how to draw an oval - lots of hits.
tomp913 is offline
post #3 of 15 (permalink) Old 09-15-2017, 10:55 PM
kp91's Avatar
First Name: Doug
Gene,
If you are using an inlay kit, you don't have to figure any offsets. All you need is a master the exact size and shape of the piece you are in laying. You use that without the bushing to make the template for the inlay socket. You pop the bushing on and route out the pocket. The bushing will take care of all the math.
Basically all it is doing is offsetting for the width of the router bit.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 15 (permalink) Old 09-15-2017, 11:01 PM
Semipro's Avatar
First Name: John_*
Gene
Watch this utube it the way I have done it ( the guys a little goofy) but you will get the idea
Semipro is online now
post #5 of 15 (permalink) Old 09-15-2017, 11:02 PM
go talk to Kieth about the oval if there are any questions...
and here are your offsets...
Name:	GUIDE BUSHING - TEMPLATE.jpg
Name:	GUIDE BUSHINGS.jpg
Stick486 is offline
post #6 of 15 (permalink) Old 09-15-2017, 11:37 PM
hawkeye10's Avatar
First Name: Don
Gene if I am working from a template I do it like Doug (kp91) does it but if I am cutting an oval out I use an oval cutting jig I made.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #7 of 15 (permalink) Old 09-16-2017, 05:43 AM
Gene, Microsoft Word has an Art feature that automatically draws circles, ovals, squares and rectangles. Make a document with small margins and draw an oval the size you want, print it and transfer the image to the template material. Cut it out, sand out the edges and you have it.
post #8 of 15 (permalink) Old 09-16-2017, 06:34 AM
Gene wants the offset....
Stick486 is offline
post #9 of 15 (permalink) Old 09-16-2017, 08:19 AM
Garyk's Avatar
First Name: Gary
I've always used a "mat" cutter to create patterns for ovals. They can be found at craft supply or picture frame shops. Cheap & simple without all of the math.
Garyk is offline
post #10 of 15 (permalink) Old 09-16-2017, 08:21 AM
Garyk's Avatar
First Name: Gary
"Mat cutters" available at craft shops (for picture frames) is what I've always used for oval patterns. Easy & no math. The cutter & a piece of poster board is all you need.
Garyk is offline
To the rescue honesttjohn Sign Making 16 10-21-2016 10:28 AM
For the older member-Science has come to the rescue PaulH Lobby 27 05-12-2015 07:13 PM
The AMAZING QFC Device! OPG3 Tools and Woodworking 49 07-30-2013 09:05 AM
Circle jig to the rescue..... jw2170 Jigs and Fixtures 8 03-10-2013 08:35 AM
Rescue Maurice Woodturning and Lathes 13 12-15-2008 10:49 PM
