Repurposed planer into veneer press - Router Forums
 18Likes
  • 12 Post By difalkner
  • 1 Post By TwoSkies57
  • 1 Post By hawkeye10
  • 1 Post By chessnut2
  • 1 Post By difalkner
  • 1 Post By dovetail_65
  • 1 Post By tomp913
post #1 of 8 (permalink) Old 09-25-2017, 05:58 PM Thread Starter
difalkner's Avatar
First Name: David
Default Repurposed planer into veneer press
I don't know if this should go here or in tools...
Well, I posted the other day that my 20 year old DeWalt 733 planer died and that I would probably repurpose it into a veneer press. That is now complete.
Here's the finished press -
And the 'making of' video -
Enjoy!
David
David
Curly Wood Shop on Etsy
David Falkner - Woodworking YouTube channel
Romans 3:23
difalkner is online now
post #2 of 8 (permalink) Old 09-25-2017, 06:39 PM
TwoSkies57's Avatar
Mr. Difalkner, please step to the head of the class............
difalkner likes this.
Skipper the Penguin
TwoSkies57 is offline
post #3 of 8 (permalink) Old 09-25-2017, 10:54 PM
hawkeye10's Avatar
First Name: Don
David that is a great idea and a great video.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 8 (permalink) Old 09-26-2017, 10:51 AM
chessnut2's Avatar
Great idea, David. And another very good video. Thanks.
chessnut2 is offline
post #5 of 8 (permalink) Old 09-26-2017, 04:05 PM
I dunno. A standard vacuum bag veneer press generates 22 inches of mercury, which translates to about 1500 pounds per square foot (1 inch = 70 pounds).
cjhilinski is offline
post #6 of 8 (permalink) Old 09-26-2017, 10:59 PM Thread Starter
difalkner's Avatar
First Name: David
That's all fine and good but I didn't have one of those to repurpose, I had an old planer. But just for grins, wouldn't 1,500 pounds per square foot equal about 10.4 pounds per square inch (1,500 / 144 = 10.4167)?
Thanks, though.
David
Herb Stoops likes this.
David
Romans 3:23
post #7 of 8 (permalink) Old 09-27-2017, 12:42 AM
dovetail_65's Avatar
First Name: Dovetail
Owning a Vacuum type veneer press, several as large as 72"x144" as small as 12"x12", bag and frame type. But they in no way replace the need for small manual presses like this.
I like your idea for this planer as a press, and it can be used for other stuff, not just veneer. I myself made a small press a bit large than your planer/press using a Shop fox press screw with a huge wheel and cast iron table saw wing. It almost looks like an old manual book binding press(those work for woodworking as well.).
Avacuum press is used not just because the amount of pressure, most times guys that are new to vacuum pressing veneers think they need full blast, they often use too much vacuum pressure, especially on some super thin veneers. The point of a vacuum press is yes a lot of pressure, but EVEN pressure is the key.
I like what you did, might even do something like to with my old Rigid planer. Its's a cool idea and doesn't have to take the place of a vacuum type veneer press at all.
Sometimes I'll make small letters than need go in a .25" deep pocket and they are tight. Vac pressure as much as it is just can never push/pull those letters in the pocket, but my screw press just like your planer/press sure does. So I use that, set the letters then toss the whole Assembly in the vac bag while the adhesive dries.
In other words you made a nice complimentary press for veneering and all sorts of other things.
dovetail_65 is offline
post #8 of 8 (permalink) Old 09-27-2017, 09:47 AM
Nice video, as always, and a great idea for repurposing your old planer, I'm sure it's going to come in handy in the future.
I've found that using cone point setscrews makes laying out the pattern of tapped holes very easy, just screw them in the holes, point out, lay the part to be marked on top and tap with a mallet to transfer the hole location to the part.
tomp913 is offline
thinning the drill press heard with a 120 volt VFD tool613 Tools and Woodworking 9 04-18-2013 08:15 AM
Keep Those Rollers On Your Planer Clean Jerry Bowen Tools and Woodworking 10 04-17-2013 07:53 PM
Safe T Planer (for us with drill press) needed twak Tools and Woodworking 20 05-14-2012 05:20 PM
Veneer hammer rwyoung Show N' Tell 8 05-16-2010 10:52 PM
Walnut Burl Box Build Along (1st Veneer Project) Nickbee Show N' Tell 38 03-18-2008 06:17 AM
