Anti-snipe tip - Router Forums
 28Likes
  • 17 Post By difalkner
  • 1 Post By hawkeye10
  • 1 Post By gmercer_48083
  • 1 Post By chessnut2
  • 1 Post By Gaffboat
  • 1 Post By DaninVan
  • 2 Post By DonkeyHody
  • 2 Post By MT Stringer
  • 2 Post By difalkner
post #1 of 9 (permalink) Old 01-28-2018, 10:40 PM Thread Starter
difalkner's Avatar
First Name: David
Default Anti-snipe tip
This isn't a jig or fixture but rather a tip...
When I do my glue-ups for cutting boards I leave a 'stick' or two a bit long on either end to prevent snipe in not only the planer but also the drum sander. This has the same effect as feeding a sacrificial board before and after your target board for surfacing. I don't always get snipe on my DW735 planer but it's often enough that doing this eliminates the snipe. The little board that's protruding may get some snipe but the target board doesn't. Hope this works for you like it does for me -
David
kp91, BrianS, JFPNCM and 14 others like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #2 of 9 (permalink) Old 01-28-2018, 11:01 PM
hawkeye10's Avatar
First Name: Don
Attachment 325889
David
Good idea David. I have a BYRD SHELIX HEAD on my DW735 and started getting snipe when I installed it. I called Byrd and they said shim the rollers up. I raised the upper part up about as high as I could go and put a spacer in there and lowered the roller down and let it set on the spacer. Right under the roller on both sides you can see where it opens up a little. I made some shims out of drink cans in a "U" shape and installed them on both sides and on both rollers. I put .035 in mine. If you have the Shelix head this will help.
difalkner likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 9 (permalink) Old 01-29-2018, 09:47 AM
First Name: Gary
Looks like a very simple solution.
gmercer_48083 is offline
post #4 of 9 (permalink) Old 01-29-2018, 10:07 AM
chessnut2's Avatar
Great tip, David. Thanks.
chessnut2 is offline
post #5 of 9 (permalink) Old 01-29-2018, 10:22 AM
Gaffboat's Avatar
First Name: Oliver
That's a handy tip, David. Thanks.
Gaffboat is offline
post #6 of 9 (permalink) Old 01-29-2018, 10:59 AM
Great idea! Thanks!!
DaninVan is online now
post #7 of 9 (permalink) Old 01-29-2018, 11:00 AM
DonkeyHody's Avatar
First Name: Andy
That's a good tip, but I'd need the protrusions to be much longer since my snipe is about 3 inches long. Two more tips I'll share that most probably already know.
1. One cause of snipe is lack of support for the free end of the board as it enters and exits the planer. When only one roller is in contact with the wood, it doesn't exert enough down-pressure to overcome the weight of the board hanging unsupported off the end. The free end of the board drops a little, sending the opposite end up into the blades.
2. Another cause of snipe is flex in the frame or lift mechanism of the planer. I can just about eliminate snipe by making very light cuts on the last 3 passes.
JFPNCM and difalkner like this.
DonkeyHody is offline
post #8 of 9 (permalink) Old 01-29-2018, 02:26 PM
MT Stringer's Avatar
I do the same, David. Mostly because I am too lazy to cut the boards the same length!
MT Stringer is offline
post #9 of 9 (permalink) Old 01-29-2018, 06:08 PM Thread Starter
difalkner's Avatar
First Name: David
Mike, the hard part is cutting all the other boards shorter once it's glued up and then claiming I did it on purpose and calling it a 'tip'.
David
gmercer_48083 and MT Stringer like this.
David
Romans 3:23
dado blade for spline joining sjonesphoto Tools and Woodworking 34 03-11-2014 12:11 PM
The Anantomy Of A Snipe Jerry Bowen Tools and Woodworking 10 07-24-2012 06:02 PM
Latest Chapter In Getting Rid Of The Snipe With The New Jointer.. Jerry Bowen Tools and Woodworking 7 07-20-2012 09:05 AM
Tip Rotator Mark Site Help and Suggestions 4 03-10-2008 11:22 AM
