Squareing Corners - Router Forums
 22Likes
post #1 of 15 (permalink) Old 02-04-2018, 04:36 PM Thread Starter
Default Squareing Corners
I have rabbeted out the back of some boxes with a 3/4 x 3/8 rabbet bit for the backs. Wanting to square the corners out. Any Slick way to get them square
Other than useing a chissel ??
MBurke is offline
post #2 of 15 (permalink) Old 02-04-2018, 04:40 PM
BrianS's Avatar
First Name: Brian
Not that I'm aware of Mike. A sharp chisel makes short work of corners.
Brian
(Origin uncertain)
BrianS is offline
post #3 of 15 (permalink) Old 02-04-2018, 05:25 PM
As Brian said. Round bits don't make square corners. If you do the rabbeting before you assemble the frame or box then you can get them square in one operation.
JFPNCM and Danman1957 like this.
post #4 of 15 (permalink) Old 02-04-2018, 05:38 PM
Terry Q's Avatar
Several manufactures make a corner chisel for cleaning out the corner. Whiteside manufacturing has one like this:
https://www.amazon.com/Whiteside-Rou...+corner+chisel
Lots of other manufactures for less money.
Terry Q is offline
post #5 of 15 (permalink) Old 02-04-2018, 06:10 PM
Other than using a chisel ??
corner chisel....
post #6 of 15 (permalink) Old 02-04-2018, 06:27 PM Thread Starter
Thanks to all
....how well would the corner chisel work on a 3/4 deep rabbet in Red Oak ?
I ran across this article while searching. I assume he's using a 1/4 " pattern cutting bit ? I know the corners won't be perfectly square but better than 3/8 radius.
https://www.google.com/amp/s/slowood...for-glass/amp/
On another observation...isn't it strange that a 3/8 corner radius routing template doesn't match a 3/8 radius with a rabbeting bit ? I had to modify a template so the corners matched.
MBurke is offline
post #7 of 15 (permalink) Old 02-04-2018, 08:33 PM
I use a rabbeting bit to cut a 3/8" wide rabbet x thickness of the plywood after the cabinet has been assembled. The OD of the rabbeting bit is 1-1/4" so the corner radius is 5/8", and I find that the radius made on the corner of the plywood panel using the Rockler templates is a pretty good fit to the rabbet.
BrianS, DaninVan, MEBCWD and 2 others like this.
tomp913 is offline
post #8 of 15 (permalink) Old 02-04-2018, 08:45 PM
BrianS's Avatar
First Name: Brian
Thanks to all
Looking at the specs on it, it only has 9/16" of travel so it looks a little short for what you need.
Brian
(Origin uncertain)
BrianS is offline
post #9 of 15 (permalink) Old 02-04-2018, 09:16 PM
Chisel is your best bit. Better to work it through the cut than to strike it with a mallet, although it might be tempting. You'll have better control by working it through the wood gradually. If you feel any excessive resistance consider sharpening again, making sure you strop the edge to get rid of the slight curl that spoils the edge. It being ply, do the down cuts with care so you don't split the layers.
DesertRatTom is online now
post #10 of 15 (permalink) Old 02-05-2018, 01:34 AM
If you are using a chisel then give it a bang vertically on both the sides and then take a chip off about 1/16" to 1/8" thick and repeat until you are down to the right depth. A square chisel mortising attachment for a drill press would square the corners quickly and easily. You might want to use a 1/4" mortising chisel and just do the corner and do the inner edges with a regular chisel still so that you get a nice level surface. That little chunk that's left would pop off easy with the chisel them.
jj777746 likes this.
Rounding corners of table insert ranman Guide Bushings and Templates 17 12-30-2017 01:59 AM
Looking For A Doweling Jig For Mitered Corners Jerry Bowen Tools and Woodworking 9 08-26-2013 07:18 PM
sharp square corners? spidennis General Routing 19 05-02-2013 08:46 PM
HELP! Raised panel corners uneven CPTMichaelAllen Table-mounted Routing 12 02-04-2012 11:27 AM
Inside corners on letters petersenj20 Sign Making 3 08-06-2006 09:32 PM
