Total noob: jigs, bushings, calculations ... - Router Forums
 9Likes
  • 3 Post By P.W.H.
  • 1 Post By P.W.H.
  • 2 Post By MEBCWD
  • 3 Post By P.W.H.
post #1 of 9 (permalink) Old 03-02-2018, 10:57 PM Thread Starter
Country: New Zealand
First Name: Peter
Default Total noob: jigs, bushings, calculations ...
Ok, this is something I have never bothered with before ... my router came with what I assume you 'd call a bushing,
attaches to the router base, pokes out of the bottom for a router bit to stick through and provide guidance along
the edge of a jig.
I want to cut a rebate around the holes in the top of my assembly bench so I can get a friend to do some 3d printed
plugs for it, to stop things from falling into the holes.
I am completely baffled by how to calculate anything here.
So I decided to resort to empirical data:
I have a bushing with an outside diameter of 18mm.
I am using a 1/2" router bit.
I cut a 32mm hole into a scrap of plywood to use as jig for an experiment.
The hole I ended up cutting below the jig turns out to have a diameter of 28mm.
Which happens to be more or less exactly what I needed. But: I have no idea
how that number came to pass.
12.7mm inside 18mm inside 32mm gives a result of 28.
Would the size of the router bit change this ? One would intuit it should, but ...
If anyone has a link to a website that explains this, or a youtube video, I'd be grateful.
Or .. explain it here ;-)
T.I.A. -Peter
P.W.H. is offline
post #2 of 9 (permalink) Old 03-03-2018, 12:30 AM
Semipro's Avatar
First Name: John_*
Sorry here is a utube video but not in metric
Semipro is offline
post #3 of 9 (permalink) Old 03-03-2018, 01:03 AM
see if this helps..
Name:	GUIDE BUSHINGS.jpg
Name:	GUIDE BUSHING - TEMPLATE.jpg
post #4 of 9 (permalink) Old 03-03-2018, 01:35 AM Thread Starter
First Name: Peter
Thanks John and Stick. Delved into the tables, and watched the video. All that makes perfect sense.
The thing that boggles my mind is that in my experiment I should have ended up routing a hole with a diameter of 26.7mm
but my calipers told me that the hole was/is 28mm. A discrepancy of 1.3mm.
That was why I thought that I was doing the math wrong, some kind of gigo happening here. But no, the info you gave
is exactly what I thought _should_ have happened.
Heh.
Regardless, I feel a lot more confident now about not being a total dipstick, thanks a bunch guys! -P.
DaninVan, whimsofchaz and jj777746 like this.
P.W.H. is offline
post #5 of 9 (permalink) Old 03-03-2018, 01:43 AM
gigo???
is that like mojo...
glad we could help...
post #6 of 9 (permalink) Old 03-03-2018, 04:15 AM Thread Starter
First Name: Peter
gigo???
"garbage in, garbage out". Erstwhile computer programmer slang. But really it applies to every
data processing, including humans 'thinking'.
Herb Stoops likes this.
P.W.H. is offline
post #7 of 9 (permalink) Old 03-03-2018, 04:36 AM
ahhh.
where in NZ are you??
post #8 of 9 (permalink) Old 03-03-2018, 08:22 AM
MEBCWD's Avatar
One more thing to consider is centering the bushing. If the bushing is not perfectly centered then the resulting cut may not be what the calculations would make you think it should be.
Also you need to remember different wood cut differently so that can add to the mix.
TenGees and Herb Stoops like this.
MEBCWD is online now
post #9 of 9 (permalink) Old 03-03-2018, 12:55 PM Thread Starter
First Name: Peter
I'm on the outskirts of a (for New Zealand) mid-sized town called Whangarei; which is on the east coast of the skinny bit at the top.
Oh, centering the bushing .... I should see if I can pick up one of those centering cones, for sure! Good point.
DaninVan, MEBCWD and TenGees like this.
P.W.H. is offline
Oversized guide bushings and storage Mike Guide Bushings and Templates 7 09-04-2016 11:40 AM
what size insert rings for pc guide bushings? Goblu Guide Bushings and Templates 5 03-03-2015 05:22 AM
Metric bits and guide bushings Mike The Voting Booth 29 05-09-2012 09:08 AM
Total Noob FranzBibfeldt New Member Introductions 1 03-09-2012 05:39 AM
