Tenon on a Dowel - Router Forums
 20Likes
post #1 of 27 (permalink) Old 03-11-2018, 08:47 PM Thread Starter
First Name: Larry
Default Tenon on a Dowel
Any one have a Jig for cutting a tendon on a Dowel
woodie26 is offline
post #2 of 27 (permalink) Old 03-11-2018, 09:27 PM
hawkeye10's Avatar
First Name: Don
Larry, I am betting you don't have a lathe so I am thinking drill a hole and insert a smaller dowel.
MEBCWD and Roy Drake like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 27 (permalink) Old 03-11-2018, 09:33 PM
what exactly are you trying to do??/
need a better picture in my head...
dimensions would be nice...
post #4 of 27 (permalink) Old 03-11-2018, 09:39 PM
Across the width, or down the length? Size of the dowel and of the mortise, or the tennon.
Either way, you can cut two 45 degree strips in a 2x4, leaving you with a V groove into which you would clamp the dowel. This would be the basic setup whether you wanted to make a tennon on the end or a mortise in the middle somewhere. How you cut the tennon can vary, from using a Japanese pull saw to using a dado stack. Either way, the V groove and a clamp will stabilize the dowel as you make the cuts.
The simple illustration is the essence. If you're cutting a tennon on the end, let the dowel hang over one edge, put the 2x against your miter gauge and use the TS blade to flatten the tennon, flip the dowel over (measure carefully!) and cut the other side. You'll probably have to do some chisel work to shape from round to square for appearance sake.
If you're cutting a mortise, on a drill press, make sure the cut is made where the 2x supports the dowel.
Clamping could just be a strip of wood across the dowel and a couple of bolts sticking up from the edges of the 2x, through the strip of wood, with butterfly nuts to tighten the wood down. I'm probably use a hardwood for the V piece so it's less likely the wood will split. Pre drill a hole for the bolt and maybe use a fender washer underneath, countersunk a little bit, to spread the force of the tightened bolt across the 2x while keeping the bottom flat. Simple, cheap, make it from scrap.
jj777746 likes this.
DesertRatTom is online now
post #5 of 27 (permalink) Old 03-12-2018, 09:12 AM
Garyk's Avatar
First Name: Gary
Try Lee Valley. They have some that work like pencil sharpeners. Google tenon cutters for dowels and you will find them other places for less $$.
Herb Stoops likes this.
Garyk is offline
post #6 of 27 (permalink) Old 03-12-2018, 09:31 AM
but not near the quality...
Veritas® Tapered Tenon Cutters - Lee Valley Tools
Carbide-Tipped Dowel, Plug & Tenon Cutters - Lee Valley Tools
Herb Stoops and hawkeye10 like this.
post #7 of 27 (permalink) Old 03-12-2018, 09:50 AM
TenGees's Avatar
First Name: Paul
I had a simple idea posted a while back. http://www.routerforums.com/general-...tml#post383313
I used this a few times to cut tenons on broomstick ends (like for paper towel holders). Not sure if that's what you're trying to do, Larry.
MEBCWD and Herb Stoops like this.
TenGees is offline
post #8 of 27 (permalink) Old 03-12-2018, 10:21 AM
bore out the end and dowel it if it's large enough...
MEBCWD and jj777746 like this.
post #9 of 27 (permalink) Old 03-12-2018, 10:44 AM Thread Starter
First Name: Larry
I have a 5/8" Dowel and I want a 3/8" tendon cut on the End.
woodie26 is offline
post #10 of 27 (permalink) Old 03-12-2018, 10:47 AM
couple of ways to bore out a dowel end...
V notch the end of a 2x...
install a drill bit the same dia as the dowel in your DP...
slide the V notched 2x up to the bit and clamp the 2x to the table...
change the bit to the desired 2nd bore size...
inset the dowel to be drilled into the V notch and clamp that in place...
the dowel will be auto centered to the bit...
bore the hole...
bore/drill a hole in your 2x near the end... edge drill for longer dowels, face side for shorter dowels..
saw of the end of the 2x cutting through the bored hole leaving 60~70% of the hole...
set the 2x back on the DP w/ the bit you drilled the hole w/ set in the drilled hole and clamp the 2x in place...
inset the dowel to be drilled into the open sided hole and clamp that in place...
bore the hole...
either works w/ a 4x4...
a 4x will give you better stability..
Trimming Tenon To Fit Mortise. Gaia Tools and Woodworking 16 07-22-2015 05:57 PM
Making A Stub Haunched Tenon & Mortice??? Gaia Tools and Woodworking 4 07-15-2015 10:47 AM
What do you think about this dowelling jig? bclarknc Jigs and Fixtures 10 03-08-2012 10:01 AM
mortise tenon dowel post and beam hamrhed Tools and Woodworking 1 04-28-2011 03:30 AM
mortise & tenon jig yairfe Jigs and Fixtures 23 10-21-2009 05:49 PM
