Router Sled to Hold Flute - Router Forums
post #1 of 8 (permalink) Old 04-18-2018, 07:19 PM Thread Starter
Default Router Sled to Hold Flute
I am a flutemaker and am starting working on a new flute(new to me that is). I already see that I need some how to hold a somewhat irregular shaped flute so that I can rout about a 2" groove with a straight bit..Nothing fancy but I want to leave the router in the table and set something up for use on it.
The flute would be 1 1/4" with some taper to it. Any help is appreciated.Thanks in advance!!!
Flutemaker is offline
post #2 of 8 (permalink) Old 04-18-2018, 07:22 PM
can you reference a picture???
Stick486 is offline
post #3 of 8 (permalink) Old 04-18-2018, 08:27 PM
JOAT's Avatar
First Name: Theo
How wide? How deep? What's the groove for? And, yeah, a picture would definitely help. Be sure to show where the groove will be.
JOAT is online now
post #4 of 8 (permalink) Old 04-18-2018, 11:55 PM
Have a look at this old thread. It might be just what you are looking for. http://www.routerforums.com/table-mo...osts-legs.html
post #5 of 8 (permalink) Old 04-19-2018, 03:13 AM Thread Starter
Second Voice Flutes - Workshop: Fipples, voice boxes and flues
Click on link.The first pic shows the groove...Can be about 3/4" to 1" wide and 2 '' long.It is flexible..Scroll down a little on link and see the second pic. There is actually another groove inside the big one...It is the flue channel .Ill have some file and chisel or dremel work to do here also. Some do all this by hand but using the router when I get it figured out would be great for me!
post #6 of 8 (permalink) Old 04-19-2018, 04:41 AM
build a clamping nest w/ built in guides for the body...
free hand rout the grove w/ a small plunge router like a Bosch Colt...
a top bearing mortising bit would be my choice for a bit...
Freud Tools | 3/4" (Dia.) Mortising Bit
Stick486 is offline
post #7 of 8 (permalink) Old 04-19-2018, 10:10 AM
You want to rout out a pocket. I agree with Stick, a small trim router with plunge capability (that's a must have in this case) like the Bosch Colt or DeWalt 611. A jig with a hole the size of the pocket and that mortising bit would be easy. You'd need a different jig for each offset in the pocket. Another option might be using guide bushings but you are limited to jumps or either 1/16" or 1/8". There is no real fine tuning using guide bushings. If you want an idea of how they work you can go to our home page by clicking on the large Routerforums logo at the top of the page and look for the tutorials on them by Harrysin (Sinclair).
post #8 of 8 (permalink) Old 04-20-2018, 03:13 AM Thread Starter
Thanks Ill check those ideas out!!!
Coping Sled Suitable For Triton RTA 300 Router Table Gaia Jigs and Fixtures 11 11-25-2015 02:15 PM
A DIFFERENT ROUTER LATHE or “A ROUTER STANDARDIZER” neville9999 Jigs and Fixtures 8 01-04-2013 12:48 PM
VIDEO - Shop built Mitering and Crosscut Sled johnwnixon Tools and Woodworking 5 09-06-2009 10:14 AM
