Drill Press Lighting - Router Forums
 34Likes
post #1 of 30 (permalink) Old 04-26-2018, 08:44 AM Thread Starter
Default Drill Press Lighting
Hello All,
One of the small frustrations of drilling holes is aligning the bit to the x on the item to be drilled. I know from experience that a single source light on the work causes shadows and can block the center of the x. So I decided to build a 360 degree light source for my drill press. It uses cheap white LEDs purchased on Ebay for $2. A switch and a 5 volt "wall wart" power supply does the trick. The holes for the LEDS is drilled into a round piece of 1/2 inch plywood at a 10 degree angle to focus the LED lights at about 8 inches below the mounting point on the drill press quill.
First picture is the typical shadow seen
Second picture is the 31 LEDs
Third picture is the circuitry Leds and 100 ohm resistors and switch.
Fourth picture is the resulting clear view of the x to be drilled.
Total cost was about $10 for everything.
Now I can see clearly the x on the work to be drilled.
Woodworker3
Woodworker3 is offline
post #2 of 30 (permalink) Old 04-26-2018, 09:01 AM
I like it..
A lot..
Stick486 is offline
post #3 of 30 (permalink) Old 04-26-2018, 09:15 AM
Very clever. I can never get enough light on my workpieces.
post #4 of 30 (permalink) Old 04-26-2018, 09:24 AM
A picture of how it is mounted on the Drill Press would be nice. I like the results of the light, though.
TenGees and Shop guy like this.
Herb Stoops is offline
post #5 of 30 (permalink) Old 04-26-2018, 09:34 AM
Amen to 'never enough light'!
DaninVan is offline
post #6 of 30 (permalink) Old 04-26-2018, 09:35 AM
First Name: Richard
Like Herb said I like the light but how did you mount it.
Herb Stoops likes this.
Shop guy is offline
post #7 of 30 (permalink) Old 04-26-2018, 11:22 AM
Gaffboat's Avatar
First Name: Oliver
A great solution. The older I get, the more light I need.
MEBCWD and Rogerdodge like this.
Gaffboat is offline
post #8 of 30 (permalink) Old 04-26-2018, 12:08 PM
JFPNCM's Avatar
First Name: Jon
+2 on all the above.
Jon
JFPNCM is offline
post #9 of 30 (permalink) Old 04-26-2018, 12:58 PM
hawkeye10's Avatar
First Name: Don
I agree with others you made a nice light. I had to look up a "Wall wart" I have not heard of that before.
DaninVan and HoweA like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #10 of 30 (permalink) Old 04-26-2018, 02:14 PM
That would be why they call you 'Hawk Eye"?
thomas1389 likes this.
DaninVan is offline
Drill DP15501 15" Drill Press allthunbs Ridgid Manuals 2 01-18-2018 12:13 AM
How to Drill a Hole without using a Drill Press MT Stringer Jigs and Fixtures 4 04-20-2017 01:24 AM
Drill PRess.. help me pick please!! woodaholic Tools and Woodworking 8 09-13-2011 10:53 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
