Jig for using a Lock Miter bit on large pieces - Router Forums
 10Likes
  • 4 Post By Gene Howe
  • 2 Post By CharleyL
  • 1 Post By tomp913
  • 1 Post By Gene Howe
  • 2 Post By Gene Howe
post #1 of 7 (permalink) Old 04-29-2018, 04:27 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
Default Jig for using a Lock Miter bit on large pieces
I'm building the second of two rifle boxes. The first one was made with mitered corners and keyed dovetails. Thought I'd give Lock Miters a try this time.
As most will know, a Lock Miter joint is cut on with one piece ran vertically across the bit, using the fence, and the mating piece is ran horizontally, flat on the table. The pieces for the rifle box ends are 12 x 6 x 5/8 and, the sides are 46 x 6 x 5/8. I was concerned about stability of the 12" high piece riding against the 2 1/2" high fence. And also, maintaining an accurate cut on the ends of the 46" long sides.
Here are a few pictures of how I've attempted to allay my concerns.
The first two show a fence with an added auxiliary fence for more height. That auxiliary fence came with the stock fence from Jointec. I rides in a T track on top of the stock fence and is secured in back with brackets and T bolts. Then another fence that slides on the auxiliary fence was added. That fence has a block at the back edge to help with stability as the work passes the bit. You can see that my paranoia also led me to clamp the work.
That yellow apparatus is/are four plastic feather boards from Harbor Freight. They are stuck together with fibered carped tape. Two 4" 1/4 20 T bolts secure whole thing to a T track milled into the cross table clamp. Also from Jointec. It was their method for mounting thinner feather boards, as the table doesn't have an embedded T track.
The next two pictures show two views of the "coping sled" supplied by Jointech. It is guided by the T track on the top of the fence. That's where their Auxiliary fence is mounted.
A 2' 2X3 was mounted to the coping device to provide stability for the long pieces. This is the first time I have wished for a T track in the table. A miter gauge would sure be handier.
First test flight tomorrow. I'll report my successes or, lack thereof, later.
Thanks for looking.
harrysin, TenGees, tomp913 and 1 others like this.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #2 of 7 (permalink) Old 04-29-2018, 07:17 PM
CharleyL's Avatar
First Name: Charley
Your setup looks pretty good to me, but what are you using to get the fence and bit positioned correctly? Do you have any kind of setup gauge? I have the Lock Miter Master gauges from Infinity Tool and they do a great job of getting the fence position and bit height correct. All you need to do is determine the exact center of the thickness of each board. The Lock Miter Master gauge then attaches with magnets to your bit and has a horizontal and a vertical line on it that you use to set the bit and fence positions so the center line of your boards line up with these marks. The resulting positions will be near perfect, requiring only a test cut pair to verify that they are correct.
Keeping the boards being cut horizontal is relatively easy, but more difficult for the vertical board. From what I can see in your pictures, I think you have a good setup. Feed the stock past the bit slowly and I think you will get acceptable results, but a pair of test pieces cut from the same stock before your final cuts should prove it.
Charley
Herb Stoops and jj777746 like this.
Central North Carolina
CharleyL is offline
post #3 of 7 (permalink) Old 04-29-2018, 07:56 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
I'm with ya, Charlie. Got the Infinity set up gauges. The big 'un and the bitty one. Just ordered the "Baby" bit. And, I've made me a center finder. When I ran the stock for the box, I also ran some for trial runs. I hope, I ran enough.
Gene Howe
Snowflake, AZ
post #4 of 7 (permalink) Old 04-29-2018, 09:32 PM
Your set-ups look good. If I might make a suggestion - I see that you don't have a back-up strip in either case to prevent some blow-out when the bit exits the part, might be an idea to add them. I like that idea of providing a mounting provision for the featherboards, I believe that Mike (@MT Stringer) posted details of a home-made version that he'd made.
Gene Howe likes this.
tomp913 is offline
post #5 of 7 (permalink) Old 04-29-2018, 10:58 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
Hi again, Tom. Gotcha covered. Thanks, friend.
tomp913 likes this.
Gene Howe
Snowflake, AZ
post #6 of 7 (permalink) Old 04-30-2018, 12:20 AM
jj777746's Avatar
Hey Gene,I have watched the video from Infinity Cutting Tools & it shows that you are doing every thing right & then some, using their lock miter bits,so you should expect a perfect result.All the best,Jamesjj
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #7 of 7 (permalink) Old 05-02-2018, 01:05 PM Thread Starter
Gene Howe's Avatar
First Name: Gene
After a few missteps, a change of glasses, and some YouTube instruction, I finally have cut a perfect lock miter joint.
The jigs worked great. My eyesight was the problem. With lock miters, precision is everything. After donning my magnifying headset, I found where I was off. Fixed that and it worked much better.
tomp913 and hawkeye10 like this.
Gene Howe
Snowflake, AZ
Lock Miter Bits for Boxes, Your Thoughts on the Better Bit. jhelminski Table-mounted Routing 3 10-08-2010 07:28 PM
using a 45 Lock Miter Bit allthunbs Table-mounted Routing 3 07-07-2008 04:04 PM
Lock miter bit Drick Router Bits - Types and Usage 10 12-28-2005 09:54 AM
