miter joint glue-up jig - Router Forums
 23Likes
  • 17 Post By DesertRatTom
  • 1 Post By Arcola60
  • 3 Post By CharleyL
  • 1 Post By jj777746
  • 1 Post By Cherryville Chuck
post #1 of 10 (permalink) Old 06-14-2018, 12:34 PM Thread Starter
Default miter joint glue-up jig
Finally got the pictures of the small miter clamping jig mentioned recently in another post. Using simple pine, I just glued some 45 degree pieces to a 5 inch long, half inch wide strips. Simple and quick project, but really makes clamping corners of art frames easier.
I have full sized clamps on it in the picture, but will replace them with small Bessy clamps. The heavier weight clamps are pretty clunky and get in the way of other clamps on the same frame. The small ones will be les likely to distort light frames like this one.
The angled pieces are glued on, the second pix shows the pieces and how they got clamped together at glueup. Really effective. Note that to get the pressure perpendicular to the joint, you have to set them back from the corner so the pressure goes directly through the center of the joint.
DesertRatTom is online now
post #2 of 10 (permalink) Old 06-14-2018, 12:46 PM
First Name: Ellery
Very nice set up! Thanks for sharing.
OPG3 likes this.
Arcola60 is offline
post #3 of 10 (permalink) Old 06-14-2018, 10:34 PM
CharleyL's Avatar
First Name: Charley
Way cheaper than the Woodpeckers one time version too.
Charley
OPG3, MEBCWD and jj777746 like this.
Central North Carolina
CharleyL is offline
post #4 of 10 (permalink) Old 06-15-2018, 01:00 AM
jj777746's Avatar
So simple yet so effective. Thanks Tom
OPG3 likes this.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #5 of 10 (permalink) Old 06-15-2018, 07:20 AM
OPG3's Avatar
First Name: Otis
Tom,
These look very effective and I'm guessing you have something on the back (such as sandpaper) to give traction.
OPG3
Tweak everything!
OPG3 is offline
post #6 of 10 (permalink) Old 06-15-2018, 11:15 PM Thread Starter
yup, about 220 grit (what I had on hand), and a little double sided tape. Had to laugh at myself, I made the first four for the pictures, then forgot to make the other four. Did that yesterday, so now I have the full set. I also added four more of the small, 4 inch Bessy bar clamps to make a set of 8. These are smaller than the ones shown, so they stay out of the way. I use the larger Bessy clamp to pull the corners together. My wife has a backlog of paintings that need frames, so the pressure is on to get busy. Bought some pine stock yesterday so I can mill it. Not as fine looking as hardwoods, but it's about 1 inch thick and mills nicely for most of her usual paintings. These little jigs work best on thicker frames.
post #7 of 10 (permalink) Old 06-17-2018, 03:50 AM
Country: Brazil
First Name: sid
The simplest are always the best!! great job! congrats.
ksidwy is offline
post #8 of 10 (permalink) Old 06-17-2018, 12:55 PM Thread Starter
Finishing the frame shown today, getting another prepped for a seascape. This narrow frame has an edge of purpleheart that separates the frame from the picture. Not perfectly happy with the purplewood (trouble cutting it), but the wife loves it so it's time. I'll try this again. Just couldn't get it cut to the same width and thickness. Needed to use a block against the fence because the thin wood slipped under the dust relief on the bottom of the fence. It all looked the same, but really wasn't.
In the seascape I'm using a fairly modern look, but adding a strip of trim that looks like rope. I like mahogany (redish) for frames, with the rope finished much lighter, so I'll stain each separately, then glue on the rope trim, and then apply a few coats of wipe on poly for a glossy look.. Should look great. Going to use scrapers, not sandpaper since the surfaces are all flat.
post #9 of 10 (permalink) Old 06-17-2018, 03:28 PM
Those are a much better idea than the standard right angle corner clamp, especially the ones with only one clamp screw.
DesertRatTom likes this.
post #10 of 10 (permalink) Old 06-17-2018, 07:08 PM Thread Starter
I have a variety of corner clamps, band clamps. an X shaped frame, Bessy right angle clamps, steel wires that grab the corners with spring action, and these. These really work well I'm thinking of making some sort of corner pieces to set in the frame to set everything square before clamps and glueup.
Just remembered, have to go out and apply another coat of cherry stain to that skinny frame.
EZ Dovetail Jig bobj3 Jigs and Fixtures 12 01-14-2020 07:20 PM
rockler box joint jig. ... what am i doing wrong? sjonesphoto Jigs and Fixtures 10 03-10-2014 08:22 AM
Finger Joint jig Cherryville Chuck Jigs and Fixtures 21 01-15-2014 02:41 PM
Bj's box joint jig steveo Jigs and Fixtures 1 02-12-2008 07:49 PM
bit for Jack Miter molding joint tshaw47 Router Bits - Types and Usage 3 09-11-2007 08:01 PM
