Routing Inside a Stock 1x4 - Router Forums
 29Likes
post #1 of 22 (permalink) Old 06-21-2018, 07:37 PM Thread Starter
First Name: Ed
Default Routing Inside a Stock 1x4
I am building a small movable kitchen island ~ 30"x36". I want to use decorative pieces at the corners fashioned from 1"x4"x~30" stock. What would be the easiest way to route inside the 3.5" width. My thought is to build the case out of plywood attach the vertical decorative pieces 2 at each corner un-mitered placing a vertical dowel to fill the open corner. I don't have a plan to share as I am just winging it. I have three portable routers, a .25" trim router, a .25" fixed base and a .5" fixed base. I also have a Stumpy Nubs horizontal router table for the .5" motor that I have never used. I haven't done any woodworking in several years as I have been involved in care giving.
Eddie_T
Eddie_T is offline
post #2 of 22 (permalink) Old 06-21-2018, 08:32 PM
Can't quite picture what you're doing from the description. Could you draw a simple picture and indicate what you intend to produce? Take a picture with your cell phone and post it. You can just use arrows to point to what you want to wind up with.
In general I always prefer to use a router table whenever possible. Putting a roundover on the four 4x4 legs would be easy, although I'd keep what I assume will be the four legs, as square as possible for the ply to mount against. 4x4 is also pretty heavy for a kitchen, perhaps you could cut a taper so the legs thin out toward the floor. This sounds like a very practical table. I'd seriously consider gluing up some hard wood to make the top. Finish the top with food friendly oil. It will look really nice that way. The appearance of this table will depend a loton your lumber selection. Look for pretty tight grain, and consider checking out Oak for the legs. Some stores have this kind of material in their stair making area.
Reading your post over again, I think you're planning to use 1x4 to fashion the legs. If so you can still taper the material, then glue two pieces together to make the legs. Then use some hefty quarter round on the inside joint of each leg, which will add strength and a more finished look. Extend the quarter round straiht up and fasten it to the table sides.
Once you get the legs together, use a rounhdover on the legs. Glue and clamp carefully so the two parts of each leg don't have any gaps. I don't think I'd want the legs splayed out, just straight down.
Hope I read this right.
Hope this is helpful.
DesertRatTom is online now
post #3 of 22 (permalink) Old 06-21-2018, 09:50 PM Thread Starter
First Name: Ed
Sorry I wasn't clear with my OP. The 1x4 strips are decorative and will be glued onto the corners of the case. They are not legs, the case will sit on 4 fixed casters concealed with base molding.
I just need help with the best routing technique to make the 1x4s decorative. This is not it but shows similar corner treatment.
Eddie_T
Eddie_T is offline
post #4 of 22 (permalink) Old 06-21-2018, 11:02 PM
If you are making "L" shaped corner pieces with a mitered joint, glue them together then run your router down the corner before cutting them to length and installing them on the cabinet.
If you are butting together at the corner, rip one leg narrower by the thickness of the board it will be butted to and then glue up ,after gluing and sanding flush at the joint run the round over bit on the router table,or freehand to round off the point. Then cut to fit the vertical.
If you are making the picture frame corners like shown and are asking about the inside profile , you will have to route the stock on the side that goes inside before you miter the corners to make the pictures frame. You can not get a good looking inside corner by cutting out the center and routing the inside as the corners will come out round and not square and look odd.
Make up the 2 picture frames, miter one side of each and either glue together before or after you install on the corner.
Eddie_T and DaninVan like this.
Herb Stoops is offline
post #5 of 22 (permalink) Old 06-21-2018, 11:06 PM
lay your material face up on a solid work surface...
clamp it in place...
route one edge to the profile of your choice..
cut your pieces to size and miter the corners so that the profile is to thee inside of your frame...
splines for this joint are a plus...
Eddie_T and ksidwy like this.
Stick486 is offline
post #6 of 22 (permalink) Old 06-21-2018, 11:20 PM
I used stopped cove profiles on the edges of the stiles I used for some home made wainscoting. I stopped the profiles about an inch before they met the rail and base board. It doesnít sound that fancy but it looked pretty good and itís really easy to do with a bearing guided cove bit.
Eddie_T and Herb Stoops like this.
post #7 of 22 (permalink) Old 06-22-2018, 12:07 AM
TWheels's Avatar
If the corner pieces just below the top are examples of what you are trying to do, it seems to me a template guide and dish cutter bit in a hand held router ia what you need. If it is the pieces on the bottom corners as @Cherryville Chuck suggested a cove bit or perhaps a classical profile or some ogee profile, maybe easiest in a router table
Eddie_T likes this.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #8 of 22 (permalink) Old 06-22-2018, 10:01 AM
TenGees's Avatar
First Name: Paul
The corners in the picture seem to use a profile like the drawer fronts and doors. Rather than cutting out the 1x4, it might be easier to cut strips and make rectangles then use a bearing guided bit or route one edge of the all strips and then miter them like picture frames.
Eddie_T likes this.
TenGees is offline
post #9 of 22 (permalink) Old 06-22-2018, 10:31 AM Thread Starter
First Name: Ed
Thanks for all the inputs, I think I will try a hand held router with the piece clamped near a fence to guide the router. I may route a cove to ease the outer edge transitioning to the vertical dowel that will fill the open corner (see OP).
Eddie_T
Eddie_T is offline
post #10 of 22 (permalink) Old 06-22-2018, 10:55 AM
A totally different approach, Ed, is to apply the flat stock first then install the mouldings on top. Basically run off a bunch of the profile you like, on your router table. Cut whatever miters you need, and install.
You don't necessarily need to cut the mouldings to size first; you can profile both edges of a 1x4 or whatever size you have available, then rip off the profiled edges to the width you want.
Believe it or not I do that handheld, with my basic stock clamped or taped down. I usually have an additional piece laying behind the work piece, as additional support for the base plate.
I know several of the members here are probably quaking at the thought, but in all the years I've been doing it that way, I've never had a bad incident. Like so many things in woodworking there are multiple ways to achieve something.
TenGees likes this.
DaninVan is offline
Center finder for drilling round stock Gaffboat Tool Reviews 21 10-02-2016 07:05 AM
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 03:18 AM
Routing an Arch Curmudgeon10 Table-mounted Routing 9 03-04-2013 03:06 PM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 04:24 AM
Help on Inside Corner Routing aquarium-builder General Routing 6 01-06-2005 02:43 PM
