mortise & tenon jig - Router Forums
post #1 of 24 (permalink) Old 04-03-2009, 04:38 PM Thread Starter
yairfe's Avatar
Country: Israel
First Name: Yair
Send a message via Skype™ to yairfe
Default mortise & tenon jig
I thought it would be nice to build a all-in-one plunge router mortise & tenon jig. The jig consists of a plastic sheet mounted on a wooden structure, on which the router moves in four directions. A 4 mm thick plastic sheet was chosen: a. because it very smooth. b. it is thin enough to be strong - and yet does not "steal" too much of the bit cutting length.
As can be seen in the photos + the YouTube link, the travel of the router is limited by three sliding fences, located in specific distances marked on the measure-tapes. Those distances were set regarding the desired length of the mortise (and tenon) and the thickbess of the tenon. The left side is fixed and needs no sliding fence.
To make the mortise, I clamp the stock using two clamps, and move the router from left to right. To make the tenon I clamp the stock using a sliding fence, which guarantees it's perpendicular, and then pull the router towards me, then right, than push onward, then left, always keeping the router base in contact with the fence.
I made the base of the router (using the same plastic sheet) perfectly round, so the distance from the fence to the bit is always the same, no matter the position of my hands holding the router handles.
With some experience I achieved excellent results.
As a newbie in this forum I am not allowed to post the URL. So, if you want to see the jig in action, please search yair_fe in YouTube, and there you'll find the mortise & tenon jig, and two other jigs.
yairfe is offline
post #2 of 24 (permalink) Old 04-03-2009, 04:53 PM Thread Starter
yairfe's Avatar
Country: Israel
First Name: Yair
Default Correct YouTube username: yairfe
Sorry - the correct username is: yairfe
yairfe is offline
post #3 of 24 (permalink) Old 04-03-2009, 05:23 PM
Bob N's Avatar
First Name: Bob
Yair,
VERY VERY NICE jig and well illustrated too. Thanks for taking the time to share it with us.
When you hit the 10 post mark you will be able to post your link as well.
For now I will post it for you so others can get there easily and see your work.
YouTube - mortise&tenon jig
Bob N is offline
post #4 of 24 (permalink) Old 04-03-2009, 06:05 PM
Hamlin's Avatar
First Name: Ken
Hi Yairfe,
That is a sweet jig. Very nicely done.
Ken
"A VETERAN"
Hamlin is offline
post #5 of 24 (permalink) Old 04-03-2009, 06:31 PM
kolias's Avatar
First Name: Nicolas
Excellent jig Yair and thanks for sharing
The video also was very good for the details
Nicolas
kolias is offline
post #6 of 24 (permalink) Old 04-03-2009, 07:47 PM
dutchman 46's Avatar
First Name: Howard
Hello Yairfe Welcome to Router Forums. Very very nice work. It helps a lot to see what you have built when we can see it. Thank you very much, and i am glad you are here.
John 3:16
dutchman 46 is offline
post #7 of 24 (permalink) Old 04-03-2009, 11:06 PM
kolias's Avatar
First Name: Nicolas
Hello Yair
Looking at your video again and again I don't understand how you do the settings for a particular size mortise or tenon.
If you have a chance, it will be nice to explain this
Nicolas
kolias is offline
post #8 of 24 (permalink) Old 04-03-2009, 11:26 PM
Hi yairfe
Very Nice job on the jig
It's looks like a mix of the Craftsman and the Trend® Mortise & Tenon Jig, I do like jigs alot , here's a small tip,,,if you use one of the small bar clamps and remove the small stop pin on the end of the bar you will not need to look for it all the time it will just be in the cabinet sticking out..no round hole needed to put it in place just a slot like the Trend type..
http://www.routerforums.com/show-n-t...h-m-t-jig.html
http://www.rockler.com/tech/RTD10000037AB.pdf
post #9 of 24 (permalink) Old 04-04-2009, 01:21 AM
CanuckGal's Avatar
First Name: Deb
Great jig and great job yairfe! It's very encouraging to newbies like me to see someone make it look so easy
CanuckGal is offline
post #10 of 24 (permalink) Old 04-04-2009, 12:12 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Very interesting! I've not used YouTube much before and started to explore further. It didn't take long for joints to become joints, if you know what I mean!
Thank you for posting the jig.
Cheers
Peter
istracpsboss is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Mortise and Tenon Joints TheVogon Table-mounted Routing 9 07-20-2009 07:26 AM
How to do Mortise and Tenon? JDługosz Jigs and Fixtures 26 10-21-2007 02:17 PM
Mortise & Tenon System Router questions kenadian Table-mounted Routing 2 11-17-2005 04:22 PM
