Featherboard alternatives? - Page 2 - Router Forums
 12Likes
post #11 of 21 (permalink) Old 08-03-2018, 05:18 PM
MEBCWD's Avatar
These are the parts I used for, what I call, a springboard.
I glue and screw the spring to the base on both sides. I use 2 countersunk head machine screws through the runner, 2 washers and 2 knobs to mount it in a miter groove. Adjust it where it is in contact with the material with a little pressure and when the knobs are tightened the countersunk screws spread the sides of the runner and clamps it into the miter slot and holds the base in place.
You can also make these and just glue and screw the spring to the leading edge of the base. The spring can be any length and can be a little thicker (like a single finger feather board).
Name:	Spring board parts.jpg
MEBCWD is offline
post #12 of 21 (permalink) Old 02-05-2020, 04:08 AM
First Name: Roy
Small Feather Board for Table Saw, Mitre Saw, Fencing, Bandsaw This 3/8" x 3-1/4" x 7-1/2" with aprox. 2" up and down adjustment is really Great for drill press fences, shop built Miter Saw , Fence or any other fence that excepts 1/4" x 20 hex head bolts. With this jig & Fixture set, this allows you to set up the feather board to lock in any standard 3/4" miter slot with or without T slot.
Roy A is offline
post #13 of 21 (permalink) Old 02-10-2020, 08:18 AM
This is a simple video that I think is what you're looking for. Very minimal gear required. Note how high the blade is, that's so all the fingers will be close to the same length on both top and bottom. Simple clamping method demonstrated as well.Personally, I would leave the long board and cut it off AFTER cutting the fingers, just don't like getting my paws that close to a blade. Note that you don't have to overdo the pressure of the fingers against the workpiece. That kind of featherboard can be used on any table with T track, or you can simply clamp it to a fence for down pressure on a workpiece. That would be the case with many routing tasks.
DesertRatTom is online now
post #14 of 21 (permalink) Old 02-10-2020, 08:24 AM
chessnut2's Avatar
I've been thinking about trying one of these:
https://www.toolnut.com/hedgehog-hh-...xoCQXYQAvD_BwE
chessnut2 is offline
post #15 of 21 (permalink) Old 02-10-2020, 09:01 AM
First Name: Steve
Is this what you are looking for? Not cheap but well made.
JessEm - Clear-Cut Precision Stock Guides, # 04215
Herb Stoops likes this.
Steve Pack is offline
post #16 of 21 (permalink) Old 02-10-2020, 11:37 AM
If you make a lot of featherboards (or just like to make neat jigs), here's an idea for a jig similar to that used for cutting box joints. It does have a limitation on how long the fingers can be cut, based of the max. height of the blade above the saw table.
I can't find a photo of the actual jig (left it in my buddy's shop) but it was similar to that shown in the photo, except on a smaller scale and with the fingers made from Lexan. It was almost as long as the fence on the router table so supported both the infeed and outfeed sides of the part and was perfect for routing the edge on small moldings
Name:	Featherboard Kerfing Jig.jpg
chessnut2 and Herb Stoops like this.
tomp913 is offline
post #17 of 21 (permalink) Old 02-10-2020, 12:05 PM
A little more searching and I found the picture of the featherboard that I posted on this forum a couple of years back. The Lexan finger is basically the same as the one on the Grip-Tite magnetic featherboard (I have an earlier version where the body is made of wood and there is no lever to release the magnet so you wind up prying it off the saw table.
Did find this photo of my magnetic featherboard in use, and the molding I was cutting - you can see the drawback using it when cutting a narrow part, the magnet didn't hit the table ripping this narrow part so I had to use a standard feather board and just use it to keep downward pressure on the part. Have the problem solved now since I replaced the Unifence............
tomp913 is offline
post #18 of 21 (permalink) Old 02-10-2020, 09:05 PM
PhilBa's Avatar
First Name: phil
One of the things about a lot of those devices is that they take more time to set up than it takes to make the cut. One that doesn't is the the magswitch. It looks like the model I have isn't sold any more but there are newer ones that look similarly easy. They are super fast to set up so I wind up using it a lot. When you have to fiddle a bunch to set up before making just one cut, the temptation is to skip the safety device. I have "board buddies" that are really effective but a PITA to set up so they don't get used unless I'm doing a lot of cutting.
Visit my shop website.
PhilBa is offline
post #19 of 21 (permalink) Old 02-11-2020, 09:12 AM
CharleyL's Avatar
First Name: Charley
The WoodRat uses a stiff bristle scrub brush as a featherboard. I've tried using a brush like this as a featherboard on my router table, and it works quite well. I attached one to a board so I can clamp the board to hold the brush in just the right position. It works quite well.
Charley
Central North Carolina
CharleyL is online now
post #20 of 21 (permalink) Old 02-11-2020, 09:37 AM
Charley
will that brush hold against a kick back???
Featherboard Fit- Shim or return AzOwl Table-mounted Routing 8 05-05-2015 05:20 PM
Arched featherboard Mike Wingate Table-mounted Routing 4 06-21-2011 04:28 AM
featherboard use Marco Table-mounted Routing 8 04-08-2011 03:35 PM
RIDGID MagSwitch Plastic Featherboard kp91 Tool Reviews 2 03-17-2011 07:52 PM
