Baseplate for Makita RP2301FC - Router Forums
 2Likes
  • 2 Post By harrysin
post #1 of 5 (permalink) Old 08-17-2018, 02:46 PM Thread Starter
Default Baseplate for Makita RP2301FC
I need a baseplate for my Makita RP2301FC. Has to accept 1 3/8" dia template bushing. Anyone know of a source? Preferably Canadian.
Woodskip23 is offline
post #2 of 5 (permalink) Old 08-17-2018, 05:36 PM
JOAT's Avatar
First Name: Theo
Don't have a Makita, but made my own.
JOAT is online now
post #3 of 5 (permalink) Old 08-17-2018, 06:23 PM
There are some universal ones:
https://www.woodcraft.com/products/r...-centering-pin
https://www.amazon.ca/MLCS-9099-Univ...SIN=B0035EQ7GE
https://www.amazon.ca/POWERTEC-71022...SIN=B002E4VC1G
Lee Valley also sells one or two. One I think is a Wolfcraft.
post #4 of 5 (permalink) Old 08-17-2018, 11:03 PM
Make your own. Don't drill a standard countersunk hole, it will be almost impossible to center it properly. Drill the center hole to size first, use a centering cone to hold it in place, centered accurately. Then carefully mark the center of each mounting hole with a fine punch. Be as precise as you can. Then drill a hole a little larger than the threaded portion of your bolt (save the ones from the original base). Next, drill just about half way through with a bit a little larger than than the diameter of a flat headed bolt. That little bit of wiggle room will allow you center the base on the cone. I think you could use some 1/4 inch lexan for this, which will make it easy to mark the locations for drilling.
If you use an opaque material, you will need to take the old base off and do your best to mark a piece of paper or chip board accurately, then use that template to mark the new base. You will want to mark the center very carefully, for example, take a pointed bit or short, half inch drill bit, Put the base on and then lower the bit til it marks the exact center, then with a drill press, drill out the opening size you want, probably with a forstner bit.
This is a painfully detailed description, but since you're using bushings, precision will be extremely important. Even drilling slightly off center will introduce errors if the router turns somewhat or changes direction. With this replacement base, you will want to recenter it with a centering cone everytime you remove, then reattach the base.
post #5 of 5 (permalink) Old 08-18-2018, 10:13 AM
Honored Member
harrysin's Avatar
First Name: Harry
I'm intrigued to know what happened to the original base. It really is easy to make your own, this pdf shows how I made a lighted base which now sits on my Makita 3612C which is mounted on skis, the RP3201FC is now for hand held use. The base was made for the Makita 3600 which I no longer have but the bases are identical.
DesertRatTom and Rogerdodge like this.
Harry
harrysin is offline
Review of the Makita RP2301FC router harrysin General Routing 20 11-20-2018 09:19 AM
Do I need to use the plastic baseplate when mounting a router to a router table? bighank Table-mounted Routing 8 02-25-2013 10:56 AM
Making a guidebushing baseplate loninappleton Guide Bushings and Templates 17 01-01-2009 08:34 PM
Mounting Bosch Jigsaw to Router Baseplate - finished Ladd Table-mounted Routing 4 02-06-2008 06:47 PM
Oak-Park baseplate for PC7518 Drick Table-mounted Routing 2 05-19-2005 06:09 PM
