Offset Glue Joint - Leigh Dovetail - Router Forums
 13Likes
post #1 of 15 (permalink) Old 09-05-2018, 10:03 AM Thread Starter
Default Offset Glue Joint - Leigh Dovetail
I am building a tool chest for a client and the pin and tail boards will be 18" wide. I was thinking of gluing up the boards in 10" wide and 8" wide so that the glue joints will be offset on the pin and tail boards. Is there a way to mark the boards in the dovetail procedures that will ensure that they are offset or would this happen by default in the way Leigh has you rotate the boards?
I have added simple pic for clarity. Pin boards would be the 20" dimension. The 10" and 8" shown would be the Tails. Thanks in advance.
vwalla is offline
post #2 of 15 (permalink) Old 09-06-2018, 09:35 AM
Don't have that jig, but it seems to me that if you edge glue up the 8 and 10 inch boards, you will have an 18 inch wide boad, which when cut to length, can simply be rotated as you assemble the case. So I'd glue up the boards, then cut and create the joint you're going to use on the corners.
This is the kind of case that probably should have at least box joints. Once filled with tools, this thing is going to be very heavy, and expansion and contraction is also going to affect it, particularly if the owner lives in a changeable climate, especially if the box will be stored outside.
With that in mind, I'd probably be very practical and make it from plywood.
post #3 of 15 (permalink) Old 09-06-2018, 10:14 AM Thread Starter
DesertRatTom, thanks for your input. I have to make this for a museum here in Texas (San Felipe de Austin), so it has to be out of nature wood (no plywood), but it wont be loaded full of tools, but just as a display piece. I think making sure all my joints are offset on each board will ensure strength on the sides, plus some battens on the inside.
I feel more comfortable now in the direction I need to go. Thanks again!
DesertRatTom likes this.
vwalla is offline
post #4 of 15 (permalink) Old 09-06-2018, 10:40 AM
Thanks for the further information. In that case, you don't really need to make a complex joint, just make sure the end cuts are absolutely square (90 degrees). You know that every woodworker who passes by will be looking at your corner joints, so I'd suggest you use a joint that lets them see the end grain so they know it's solid wood.
Are you thinking of using some sort of antique type of finish? Will it be a display of older tools? A new looking box might not look right with old tools.
post #5 of 15 (permalink) Old 09-06-2018, 11:07 AM Thread Starter
I'm going to use dovetail joins, as the provide example. The tools will be replicas, so they will look new. My client wanted this to be build as it would have looked in the 1800's (no aging). Makes my job easier
He is creating an area where people can interact with the items, but since they can't touch the real ones, he is having me make replicas (musket crate, rough tool chest, this tool chest, compass case, and Stephen F. Austin's field desk.
vwalla is offline
post #6 of 15 (permalink) Old 09-06-2018, 11:12 AM Thread Starter
Couple of items I made for him (Austin's desk and the compass cases).
vwalla is offline
post #7 of 15 (permalink) Old 09-06-2018, 05:35 PM
That is really nice work!
post #8 of 15 (permalink) Old 09-06-2018, 05:43 PM Thread Starter
Thanks!
vwalla is offline
post #9 of 15 (permalink) Old 09-07-2018, 12:12 AM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is online now
post #10 of 15 (permalink) Old 09-07-2018, 04:59 AM
hawkeye10's Avatar
First Name: Don
WOW!!! That is some kind of woodworking. I love it. What wood are you using?
Don in Murfreesboro,Tn.
hawkeye10 is offline
Cut my first dovetail on Leigh D4R Pro help. 96BelisleAs Jigs and Fixtures 59 04-09-2016 09:09 PM
Dovetail Jigs PC 4216 vs Leigh D4R Pro vs PC Omnijig 96BelisleAs Jigs and Fixtures 51 03-16-2016 04:28 PM
For Sale: Leigh D4R-24" Dovetail Jig for sale the beaver Woodworking Classifieds 6 08-06-2012 10:05 PM
The first through dovetail joint by AKEDA Benny LaBaw Jigs and Fixtures 9 12-14-2009 08:01 AM
Biscuit or glue joint Ghidrah Router Bits - Types and Usage 13 11-13-2008 04:10 PM
