Wooden Hinge Drill Jig - Router Forums
 18Likes
post #1 of 12 (permalink) Old 09-29-2018, 04:02 PM Thread Starter
Default Wooden Hinge Drill Jig
I ordered a hole drilling jig for my dowel hinges from Rob Cosman a couple of weeks ago and Rob actually called me up and notified me he had shipped it and thanked me for ordering it.
It is well machined and in it's own little wood tray. It has 1/2",3/8",5/16",and 1/4" cups, with 2 mandrels. One is for a 1/16" drill bit,and the other for 1/8"drill bit,plus the allen wrench to set the drill bits to depth.
You cut the dowel segments to length, and turn on the drill and push it into the cup, turn it around and do the other end.
If you leave it like that then cut the pins, 1" long and stick one in each end of the dowel, it will stick out into the next dowel segment. Or you can then after both ends are drilled run a drill through full length of the dowel segment, it will follow perfectly from one hole to the other.
https://robcosman.com/products/wood-...nt=51775444307
Herb Stoops is offline
post #2 of 12 (permalink) Old 09-29-2018, 09:38 PM
old55's Avatar
First Name: Ross
Interesting piece of kit, Herb.
Herb Stoops likes this.
Ross,
old55 is offline
post #3 of 12 (permalink) Old 09-29-2018, 10:04 PM
wow!!are you coming up in the world...
post #4 of 12 (permalink) Old 09-30-2018, 09:50 AM
First Name: Dennis
Interesting. Thanks for posting. I watched his video for the full demo. Could have been half the length but maybe that's his style. Never watched him before.
denniswoody is offline
post #5 of 12 (permalink) Old 09-30-2018, 10:30 AM
Honored Member
harrysin's Avatar
First Name: Harry
A very clever jig for everyone making wood hinges if they don't have a lathe. I didn't see the price mentioned.
Harry
harrysin is online now
post #6 of 12 (permalink) Old 09-30-2018, 11:03 AM
kywoodchopper's Avatar
First Name: malcolm
I have one of Rob's earlier versions of hinge making devices. Haven't used it lately. I make a lot of wooden boxes, but most of my boxes I cut 45 degree for the corners so wooden hinges wouldn't work. I have made a lot of boxes with box joints (one cut using a 1/2" diameter bit and the other piece of wood I cut a 3/16" bit).
Thanks for bringing to my attention.
You didn't say whether you had made any boxes and used the device.
Malcolm / Kentucky USA
kywoodchopper is offline
post #7 of 12 (permalink) Old 09-30-2018, 11:06 AM
First Name: malcolm
Hi Herb, I had an earlier version of Rob's jig for making wooden hinges. I made a lot of boxes with box joints - one cut would be with a 1/2" bit and the other cut with a 3/16" bit and used the jig to make wooden hinges. Most boxes that I make now are with mitered corners. So wooden hinges wouldn't work.
Thanks for bringing it to my attention.
You didn't say whether you have use the jig.
post #8 of 12 (permalink) Old 09-30-2018, 12:39 PM
TenGees's Avatar
First Name: Paul
Interesting, Herb, that looks nice. A while back, I was looking for a way to drill a hole straight into the end of a broomstick, much like that does for dowels.
TenGees is offline
post #9 of 12 (permalink) Old 09-30-2018, 01:50 PM Thread Starter
Harry it is priced @ $44.95 USD for the individual sizes, or $129.95 USD for the kit of 4 sizes. I assume it is made in Canada,there is no indication of otherwise, and the fit and finish is excellent.
post #10 of 12 (permalink) Old 09-30-2018, 01:59 PM Thread Starter
Malcolm, I have used it to drill up a bunch of dowel segments to have on hand, and it works very well. I have only used it for 1/2" dowels w/1/8" holes so far, it is easy and fast, and right on the money, the drill doesn't wander with the grain like was the problem in the past.
kaytlynedwards13 likes this.
One tool does it all? JFPNCM Tools and Woodworking 4 04-16-2017 07:28 AM
My First Jig Coleve Show N' Tell 14 03-10-2013 09:12 PM
Trend hinge jig - thoughts? steveo1 Jigs and Fixtures 0 02-26-2012 02:54 AM
Box Hinge Jig challagan Jigs and Fixtures 8 01-08-2007 09:06 PM
Hinge jig Gouger06 Jigs and Fixtures 2 12-13-2006 12:22 PM
