Leigh D4R Pro Help... - Router Forums
 1Likes
  • 1 Post By CharleyL
post #1 of 5 (permalink) Old 10-10-2018, 11:31 AM Thread Starter
Default Leigh D4R Pro Help...
1. I've been making a concerted effort to learn this jig and I have a question on HB DTs. Following the manual, I adjust my bit height so that I have a tight fit. Now, with using the same Pin scale adjustment as I used with Tails, the Tail Board sits a little too far in the Pin Board. So to correct that, I adjust my scale toward me by an 1/8" and with a freshly cut PB, my TB outside surface sits flush with the PB edge. Question is, am I correct in using a different scale adjustment for the PB, as for the TB? If I use the same scale adjustment, then again, the TB will sit too far into the PB.
And while I've got your attention...
2. I've been using my PC 690, because I can mount all the bits all the way into the collet, which gives the bit full support. I also like the lite weight and low center of gravity. Although it is a bit heavier and taller, I'd like to use my Bosch 1617, however the way the collect is made, it doesn't fit inside the Leigh bushing, so I have to mount the bits a little more out from the collet than I'm comfortable with. I don't want to create more chatter or runout than I have to. If I could use the PC collet in the Bosch, problem would be solved. Am I explaining this clearly? Hope so. Is there another maker 8mm collet that I could use?
Darita is offline
post #2 of 5 (permalink) Old 10-10-2018, 02:43 PM
CharleyL's Avatar
First Name: Charley
I answered you on the Sawmill Creek forum this morning.
Charley
rross likes this.
Central North Carolina
CharleyL is offline
post #3 of 5 (permalink) Old 10-10-2018, 11:34 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is offline
post #4 of 5 (permalink) Old 10-11-2018, 08:22 PM
First Name: Nroosevelt
what is sawmillcreek forum
rross is offline
post #5 of 5 (permalink) Old 10-11-2018, 11:27 PM
https://www.sawmillcreek.org/index.php
Herb Stoops is offline
Preferred router for Leigh D4R Pro Bob Adams Jigs and Fixtures 9 10-11-2016 05:51 PM
Cut my first dovetail on Leigh D4R Pro help. 96BelisleAs Jigs and Fixtures 59 04-09-2016 10:09 PM
Dovetail Jigs PC 4216 vs Leigh D4R Pro vs PC Omnijig 96BelisleAs Jigs and Fixtures 51 03-16-2016 05:28 PM
Leigh D4R Pro Single Pass Dovetail trhymers Jigs and Fixtures 7 05-12-2014 01:18 PM
Leigh D4R Pro Spreadsheet evilbadger Jigs and Fixtures 1 02-24-2014 07:30 AM
