Template - Router Forums
 33Likes
post #1 of 47 (permalink) Old 12-03-2018, 12:58 PM Thread Starter
peterbata's Avatar
First Name: Peter
Default Template
Hello all. I hope that I am posting in the appropriate section. I was very impressed by the warm welcome that I received recently and was encouraged to ask questions if necessary. Well, I am here to ask.
I posted a photo in the "New Member Introductions" sub-forum of an acoustic panel that I wish to construct. I also mentioned that I purchased a Craftsman router thinking that it would be the right tool for the job.
For the most part the panels will measure 48" x 24" x 3" or 6" deep.
Now this is my thinking:
I thought that I would perhaps create a template based on the oval cutout seen on the 24" panel (top + bottom of panel) I could then use said template to make the slats on the side planks which are 48" in length.
I do not know how I am going to create this template (wood / plexiglass). And. if I did, how would I fasten it to the individual panels so that I might use my router to make the clean / straight cutouts. Would I clamp it down flat against the planks to be cut? I could also choose to go with the other option where circular holes were made in the planks but then I suppose that I would need a drill press to do this properly. Which I do not possess. I am also not that fond of the look. In the event that I keep the wood exposed.
I would also like to know what bit I would use if the router is what I end up using. I will attach a photo here as well.
I hope that I am making some sense! I really appreciate all the help that I can get. Peter
Name:	Panel with Slats.jpg
Name:	Panel with Holes.jpg
It's better to burn out than to fade away!
peterbata is offline
post #2 of 47 (permalink) Old 12-03-2018, 01:43 PM
drill guide for the round holes...
do not cut the slots w/ the router w/o hogging out the material w/ a jigsaw 1st...
use the router w/ a trim bit to dress the slot's sides...
Freud Tools - Search Results for helix
make the template from any wood sheet goods ya have... can the pliglas plan..
do you have access to a table saw???
peterbata likes this.
post #3 of 47 (permalink) Old 12-03-2018, 03:27 PM Thread Starter
peterbata's Avatar
First Name: Peter
Actually, I had my heart set on the panel with the cutout slots.
By the way, who makes that drill guide?
Something just occurred to me, my son-in-law has a drill press. I suppose that would do
Thanks so much for the info / advice @Stick486 . Unfortunately, I do not have a table saw.
Don't have a jigsaw either but can borrow one. Boy, I'm hitting a thousand am I not?
What would I use the table for? If necessary I can always look for something used.
post #4 of 47 (permalink) Old 12-03-2018, 06:42 PM
I would be looking for one...Promax
pass on the Ryobie... VOE.....
put a Bosch on your Xmas list...
cutting material...
easiest tool to make a template for those slots...
post #5 of 47 (permalink) Old 12-03-2018, 09:13 PM Thread Starter
peterbata's Avatar
First Name: Peter
@Stick486 Thanks again. I don't even know if the Promax brand is sold in Canada. Is it somehow tied to the Bench Dog brand? All I come up with is cast iron router table when I do a Google search.
I contacted someone online earlier about a Skilsaw table saw. He was selling it for 95.00. When I asked him to provide me with a model number he went MIA.
There are plenty of used tables on Facebook marketplace within close proximity to where I live. I just don't enough about the hardware in general to make a proper decision.
Any recommendations (beside Promax) if I should go the used route?
Patience and some research I guess. Oh, and this forum of course!
Danman1957 likes this.
post #6 of 47 (permalink) Old 12-04-2018, 01:50 AM
hardware we know...
just ask...
post #7 of 47 (permalink) Old 12-04-2018, 12:14 PM
Danman1957's Avatar
Peter,
I showed my son the 2 designs and he said the second one is too much work for the end result. You don't need the holes on the sides even if you choose the first design. The first one will be solid and much easier to build. If you need advice on a Marketplace find I would be happy to consult for free. So you don't need a drill guide or drill press for now. You could definitely use a table saw if you don't have one, unless you don't plan on any other woodworking projects. You could give a cutting list to wherever you buy your wood from and for a fee(usually $1/cut) they can give you what you need. If you don't have clamps for glue ups you can use screws (pre-drill pilot holes)
What area of Laval do you live in ? maybe we can get together to discuss your project.
Cheers,
Dan
Rogerdodge likes this.
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
post #8 of 47 (permalink) Old 12-04-2018, 01:17 PM Thread Starter
peterbata's Avatar
First Name: Peter
Originally Posted by Danman1957 View Post
Peter,
I showed my son the 2 designs and he said the second one is too much work for the end result. You don't need the holes on the sides even if you choose the first design. The first one will be solid and much easier to build.Cheers,
Dan
Good day Dan
So nice of you to get back to me. I wasn't really fond of the design that featured the holes (never a big fan of Swiss cheese
If I can pick up a used table saw for a reasonable price I would do so. I am putting together a tools / supply list as we speak actually. I will attach it to this post.
I was planning on having the folks at either Reno Depot or Home Depot rip my MDF 4'x8' into 3" and 6" x 8' lengths. Easier to transport and work with once I get back home.
I was pleasantly surprised when a few minutes ago I received an email message from my son-in-law. In it, he attached a Solidworks plan for the acoustic panel. I will attach that as well. This fellow is so talented. Oh, and what a guitarist!
I may pick up a few clamps.
I live in close proximity to the large hospital which is located on Boulevard René-Laennec, Laval, QC H7M 3L9. Actually, we're not that far from the mall Le Carrefour Laval. If you're ever in the area we could together for a cup of Joe. It would certainly be a pleasure.
post #9 of 47 (permalink) Old 12-04-2018, 02:02 PM Thread Starter
peterbata's Avatar
First Name: Peter
Here are some used table saw brands that I came across. Any recommendations. Certain makes / models I should stay away from like the plague?
Craftsman - Skilsaw - Delta - Rockwell
post #10 of 47 (permalink) Old 12-04-2018, 02:13 PM
Craftsman - NO... support and parts are a serious problem...
Skilsaw - leaves a lot to be desired..
Delta/Rockwell - need model numbers..
Bosch 4100 - you can't go wrong...
DesertRatTom likes this.
Routing to a template??? ZTAtZAU Table-mounted Routing 31 03-27-2018 11:35 AM
Can't get the hang of template routing kglade Starting Off 39 04-07-2016 11:00 AM
Advice on Cable Grommet Techniques plunger Starting Off 13 10-03-2015 02:03 AM
Porter Cable 55160 Omnijig Review Echonav Tool Reviews 19 06-21-2015 03:59 AM
How to Make a router Template MT Stringer Jigs and Fixtures 8 04-22-2015 02:46 PM
