Double Sided Tape for Jigs/Fixtures - Page 3 - Router Forums
 14Likes
post #21 of 28 (permalink) Old 01-21-2019, 07:39 AM Thread Starter
First Name: ben
Default separating taped pieces
Originally Posted by JFPNCM View Post
I routinely used the double sided turning tape from Lee Valley to run parts through the TS, planer and router and have not had any issues with residue or parts working loose. I use a razor blade knife to peel one corner of the backing up and the rest peels away easily. The downside, if you use to much of it getting the pieces separated can be tough and it is a bit spendy.
I think the key to separating the two work pieces is to make sure you leave a portion of the perimeter of the two joined pieces with no tape. And, remember where this no tape area is located. I have two old putty knives (unknown origin) that I reach for all the time. The 1" wide knife is thin (~ 1/64" thick) and the 1 1/2" wide knife is thicker (~ 3/64"). Start with the thin knife to create an opening for the thicker knife. Using the two knives in tandem, work you way around the perimeter. It may be slow but I have never had a failure.
Arcola60 and Herb Stoops like this.
bfblack is offline
post #22 of 28 (permalink) Old 01-21-2019, 09:22 AM
Ok, thanks, that is how I do it as well.
IRestore is offline
post #23 of 28 (permalink) Old 01-21-2019, 10:22 AM
Gaffboat's Avatar
First Name: Oliver
You could always use the CNCerís tape method that has proven to be very secure. Itís the combination of painterís tape and super glue. The tape is burnished to the backs of the two pieces to be joined, then a few beads of super glue are applied to the tape on one of the parts, and the two pieces firmly pressed together for a few moments. The super glue welds the tape pieces together but the tape is easily removed from the parts when finished, and without leaving a residue. I have also had success using spray adhesive on the painterís tape instead of super glue.
Name:	1 Tape and glue.jpeg
Name:	2 Secured.jpeg
JFPNCM and Herb Stoops like this.
Gaffboat is online now
post #24 of 28 (permalink) Old 01-21-2019, 10:49 AM
JFPNCM's Avatar
First Name: Jon
@bfblack
I use a similar approach.
Appreciate the suggestion.
Jon
JFPNCM is online now
post #25 of 28 (permalink) Old 01-23-2019, 07:28 PM
First Name: Steve
i use DS tape from amazon, however thrift Or cheap as my says) I use masking tape. I use the whit 3M because is not that much and I use gorilla Gel super glue. Place a strip on masking tape on both surfaces. Add a few drops of sg to on piece of work and press together. It sets fairly quickly and after cutting whatever it is I pull the pieces of wood apart. The tape will let of remove from both pieces and discard.
Steve Pack is offline
post #26 of 28 (permalink) Old 01-23-2019, 09:47 PM
First Name: Harry
On the CNC I used 2sided for years then got turned on to painters tape on both the table/spoilboard and the part to be cut. Press both on firmly and and then some CA on the tape with accellerant . Instant bond and ez to remove. Leave tape a little long to be able to lift it.
htasker is offline
post #27 of 28 (permalink) Old 01-23-2019, 10:29 PM
First Name: Ellery
I never thought of that method! Thank You to everyone for sharing. I will certainly incorporate that into future practices.
Arcola60 is offline
post #28 of 28 (permalink) Old 01-23-2019, 10:56 PM
I use some I got here on this forum about a year ago.
https://www.routerforums.com/woodwor...late-tape.html
It works great no residue.
Herb Stoops is offline
For Sale: Router Double sided Template Tape woodman79 Woodworking Classifieds 35 07-10-2018 05:27 AM
Double sided tape asrubin Table-mounted Routing 11 09-06-2015 06:24 AM
Where in Aus to get double sided tape? darsev Jigs and Fixtures 10 03-12-2012 10:09 PM
double sided tape FEARGI New Member Introductions 4 08-25-2010 09:54 AM
Double sided tape sankarmohan Lobby 16 12-11-2008 10:31 PM
