Double Sided Tape for Jigs/Fixtures - Router Forums
 14Likes
post #1 of 28 (permalink) Old 01-17-2019, 06:28 PM Thread Starter
First Name: ben
Default Double Sided Tape for Jigs/Fixtures
I just finished reading Woodsmith eTIPS on 5 different tapes for the woodshop. While I found the article interesting, it seemed to raise a number of questions. The first tape they discussed was Avery Dennison's Woodworkers Tape. If you check Amazon's reviews of this tape, there were some negative comments. One of the negative reviewers said Spectape ST501 (paper backing) was better. There is also a cloth backed tape Spectape H555136.
Another tape mentioned by Woodsmith was Speed Tape by FastCap. I have personal experience with the FastCap tape and found that it left residue behind; see attachment for a discussion.
What have your experiences been with double sided tapes?
File Type: pdf Comparison of Two Different Double Sided Tapes v2.pdf (138.4 KB, 161 views)
bfblack is offline
post #2 of 28 (permalink) Old 01-17-2019, 06:42 PM
JOAT's Avatar
First Name: Theo
Tried some long ago. Didn't like it, too way too long, and way too much of a PITA, to cleanup the residue later. So now I tack my masters down. Works great, no residue, but does leave nail holes - no problem, the side with the nail holes is never on the outside of whatever. And, after the initial purchase price, no more expense. There is a video of a harp maker, making a concert harp, and he uses nails too.
JOAT is offline
post #3 of 28 (permalink) Old 01-17-2019, 07:11 PM
TwoSkies57's Avatar
Been using Golfworks/GolfSmith 2 sides grip tape for years. Works great!! Also have a roll of Duck brand 2 sided tape that works almost as equally as well. Only difference is that for me at least the Golfworks grip tape last longer when doing multiple pieces from a single template. Usually 3-5 uses before having to replace the tape. Duck tape seems to run 2-4 applications. YMMV....
Rarely does one or the other leave behind any residue.
Duck tape can be a little fussy to peel apart and off
both reasonably priced and readily available
The roll of Duck tape I have is a mesh fiber, looks like drywall tape. Can't say if the new stuff is the same
Arcola60 likes this.
Skipper the Penguin
TwoSkies57 is offline
post #4 of 28 (permalink) Old 01-17-2019, 07:27 PM
First Name: JJ
I have used XFasten Double Sided Tape that I bought from Amazon. It was a good price and sticks and releases from templates without leaving sticky residue.
Isn't the SpeedTape a more long term adhesive so you don't have to use a spray or other contact cement?
Flipsaw is online now
post #5 of 28 (permalink) Old 01-17-2019, 07:58 PM
I used the Duck Tape when I had 16 drawer sides to cut to the same profile using a pattern. The tape typically held for 4-6 pieces before it had to be renewed.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #6 of 28 (permalink) Old 01-17-2019, 08:48 PM
A picture is worth a lot of typing...
Here's the Infinity setup jig set with their bits as well.
Name:	Increa lock miter jig I have these.jpg
post #7 of 28 (permalink) Old 01-17-2019, 08:54 PM
I think you are on the wrong tread, Tom.
DesertRatTom likes this.
Herb Stoops is offline
post #8 of 28 (permalink) Old 01-17-2019, 09:37 PM
First Name: Ellery
I have tried a few different brands when milling 6" long pieces for cutting boards. Duck brand was the strongest, of what I tried. As long as I did not take a heavy cut, no problems.
I used pieces of feeler gauges to set the depth. It was very consistent to nail a specific thickness on a piece of stock that was too short to run through the planer. Also I did not have a planer, at that time. I still use this process, from time to time when I have short lengths of stock to mill. I made a router sled which made it possible to do multiples of 6 pieces at a time.
I have also used it on the face of metal lathe jaws to make router base plates. I turned the OD, and machined the ID to accept the PC style guide bushings. This ensured total concentricity in one setup.
I know this thread is about DST, but I just wanted to explain the application. It may not work in every situation.
Ellery Becnel
Arcola60 is offline
post #9 of 28 (permalink) Old 01-18-2019, 08:55 AM
Whatever they use they seem to have no trouble removing the backing, whereas I seem to have a lot more difficulty removing mine.....
IRestore is offline
post #10 of 28 (permalink) Old 01-18-2019, 09:19 AM
First Name: Ellery
I have had some issues in removing the backing as well. It drove me nuts. Using a utility knife to cut it, and using the tip of the blade to get it started has given me the best results so far.
DesertRatTom and Flipsaw like this.
Arcola60 is offline
For Sale: Router Double sided Template Tape woodman79 Woodworking Classifieds 35 07-10-2018 06:27 AM
Double sided tape asrubin Table-mounted Routing 11 09-06-2015 07:24 AM
Where in Aus to get double sided tape? darsev Jigs and Fixtures 10 03-12-2012 11:09 PM
double sided tape FEARGI New Member Introductions 4 08-25-2010 10:54 AM
Double sided tape sankarmohan Lobby 16 12-11-2008 11:31 PM
