Exact width dado jig - Router Forums
 4Likes
  • 1 Post By Nickp
  • 1 Post By Cherryville Chuck
  • 1 Post By Stick486
  • 1 Post By DesertRatTom
post #1 of 8 (permalink) Old 02-04-2019, 09:40 AM Thread Starter
Default Exact width dado jig
Any one have plans for a simple exact width dado jig to be used with Bosch 1617 plunge base router? Okay
Sawdust74 is offline
post #2 of 8 (permalink) Old 02-04-2019, 09:53 AM
Nickp's Avatar
First Name: Nick
...see post #22 in the link for pics...
https://www.routerforums.com/general...-size-bit.html
Herb Stoops likes this.
Nick
Nickp is offline
post #3 of 8 (permalink) Old 02-04-2019, 10:37 AM
There are a couple of variations I think. You might find other ones by using the Community Search.
post #4 of 8 (permalink) Old 02-04-2019, 10:46 AM
here's a couple three...
post #5 of 8 (permalink) Old 02-04-2019, 11:07 AM
Pix helps me work out a project. Here's one Mike posted. I think the only really critical part is getting the fixed end pieces connected at an exact 90 so the dado is 90 to the workpiece edge. I usually add a couple of pieces of paper when setting the width, to give a little room for glue.
Name:	Exact Width Dado Jig - Mike.jpg
sreilly likes this.
post #6 of 8 (permalink) Old 02-05-2019, 11:33 AM
sreilly's Avatar
First Name: Steve
Made this one myself. Of course if you want a Woodpeckers version see https://www.woodpeck.com/exact-width...usuxewuo02ctgk
sreilly is offline
post #7 of 8 (permalink) Old 02-05-2019, 11:53 AM
I use a Dado Wiz for exact fit dados. Router beats table saw in terms of easy setup. I really dislike setting the stack on a dado set. Set. Test. Reset. Test. Fiddle. Test, fiddle some more. Exact fit jig, insert piece, tighten, make several passes. Done.
post #8 of 8 (permalink) Old 02-05-2019, 11:58 AM
If you have $330 to burn you could get this one from Woodpecker. https://www.woodpeck.com/exact-width...8vssy5azda0x2w It's still the exact same jig you can build for a few dollars worth of knobs but it will look a lot nicer.
I agree with you Tom about fiddling with dado blades and shims. I found out it's easier to pick a size that's close and then trim the end of the board to fit. It's much quicker to dial in a saw blade height and fence offset and fit the board to the groove.
Rockler Perfect Fit Dado Jig jangelini Jigs and Fixtures 8 02-05-2015 10:26 PM
Minimum dado width with bit Rouben Starting Off 12 04-28-2014 07:44 AM
Exact Width Dado Jig jaytosh522 Jigs and Fixtures 17 10-25-2012 06:07 PM
Router Adjustable Dado Jig Barry_White Jigs and Fixtures 18 07-20-2010 04:36 PM
Hinge mortising question Dalec Jigs and Fixtures 8 03-02-2009 07:17 AM
