Dovetail Jig Dust Collection Jig for PC 4200 series - Router Forums
 6Likes
  • 2 Post By Marco
  • 2 Post By Marco
  • 2 Post By Marco
post #1 of 6 (permalink) Old 05-03-2019, 07:27 PM Thread Starter
Marco's Avatar
Default Dovetail Jig Dust Collection Jig for PC 4200 series
Dovetail jigs without Dust collection are a mess and for many lead to one of the reasons to stop using it. For the Porter Cable 4200 Jigs, Leigh makes their LEIGH VRS1200 VACUUM AND ROUTER ATTACHMENT https://woodworker.com/fullpres.asp?PARTNUM=176-609 and can be in your shop for the total of $84. It looks and works great, check out their video.
Now if you have PC jig or any Dovetail jig that has bracket legs on their template you can make your own for the price of scrap wood and $8 of hardware. Here is the jig, it connects to the same bolt that the template attaches to. It picks up about 95% of the debris.
MEBCWD and Herb Stoops like this.
Galatians 5:13
Marco is offline
post #2 of 6 (permalink) Old 05-03-2019, 07:45 PM Thread Starter
Marco's Avatar
Default Jig Size
The Bottom of the jig is 14 1/16" long- 5 3/8" deep- it is cut at a 30 degree angle with a 3/4" 90 degree piece at its 2 wide end sides. It is cut from a 1/2" piece of plywood
The top is 13 3/8" long and 4 1/4" deep cut a t 30 degrees it is cut from a piece of 3/4" Plywood. Cut an extra top using 1/4" luan for different thickness.
The sides and back are 1x2's cut at 30 degrees. Covering the 1x2's sides are luan pieces used to snug the jig to the brackets and bolts.
Galatians 5:13
Marco is offline
post #3 of 6 (permalink) Old 05-03-2019, 08:02 PM Thread Starter
Marco's Avatar
The design was limited to the available hardware. Fortunately I was able to make things work from what I could get from my local hardware store.
The L brackets had to be bored out to larger than 3/8", the size of the bolt that holds the template and now Dust Collection Jig. They also needed to be bent to 30 degrees or the angle from the jig to the bolt. When I did that there was a gap on each side. That's when the additional luan side pieces were added.
To hold the Template in place I used 3/8" x 1" T-Nuts and 2 3/8" by 1" washers. The Porter Cable knobs are now used to hold the Dust Collection Jig in place. A standard Shop Vac 2 1/2" to 1 1/2" reducer was used and inserted in to a drilled hole saw hole (1 1/8" ?)
The Design is based on William M. Porters design https://www.portercalls.com/napkin_holder.htm
Galatians 5:13
Marco is offline
post #4 of 6 (permalink) Old 05-03-2019, 11:30 PM
Good job, Jim, You are right about a mess if you don't use one, that is one reason I stopped using dovetail jigs. Thanks for posting the details of how you built it.
Herb Stoops is online now
post #5 of 6 (permalink) Old 05-04-2019, 12:59 AM
I have a Rockler jig that has a dust collection attachment. I switched to a different kind of jig and would dearly love to sell the Rockler jig. PM if interested, it will be a nice price plus shipping. Just hate to see a new tool sitting unused on a shelf.
post #6 of 6 (permalink) Old 05-04-2019, 01:17 AM
MEBCWD's Avatar
Jim that's a good solution to get rid of most of the dust when using the dovetail jig. I think I'll have to bookmark this post.
MEBCWD is offline
Dust collection - Do something about it... DesertRatTom Shop Safety 30 05-11-2019 12:48 PM
Peachtree 15 inch dovetail jig Noob Jigs and Fixtures 13 12-03-2013 07:37 PM
Dovetail Jig Tip jlord Jigs and Fixtures 4 11-04-2011 10:20 AM
Dust collection base for pc 690 series routers rstermer Portable Routing 6 06-12-2008 08:42 AM
New Lower Priced Leigh Dovetail Jig scrollwolf Jigs and Fixtures 1 07-08-2007 05:10 PM
