Incra IBox Jig - Router Forums
 15Likes
post #1 of 12 (permalink) Old 05-10-2019, 09:56 AM Thread Starter
First Name: JJ
Default Incra IBox Jig
Received this notification from Peachtree Woodworking Supply that the Jig is $30 dollars off and comes with free shipping. Thought I would pass it along if anyone was interested.
Have a great day!
Herb Stoops and artman60 like this.
Flipsaw is offline
post #2 of 12 (permalink) Old 05-10-2019, 12:43 PM
CharleyL's Avatar
First Name: Charley
A great deal on a great jig.
When it was first invented, the inventor / friend of mine demonstrated his prototype to me, and I just had to have one, but I had to wait almost 5 months before they reached the stores. I paid a premium to get one from the early production, but it was worth every penny. I love that jig, and I threw about 8 shop made box joint jigs of various designs and sizes in the fire shortly after receiving it. Some made good joints and some were a little loose, but together they took up way too much storage space in my small shop. The I-Box jig replaced them all and takes up about 1/3 of the space. Plus, it's so easy to adjust for any width joint from 1/8" up to about 1". There are many ways to make box joints and I've tried many, but for me, this jig is the only way that I make them now.
The I-Box jig can be used on a router table, but I found that I can get better cuts using it on my table saw. A router bit cuts in both directions, so it really needs a sacrificial backer on both sides of the work to keep tear-out to a minimum. The I-Box jig has a backer for one side of the work included in the design, but you will need to attach a second backer to the face side of your work with double sided tape to get the best cuts with a router bit and you will need a new backer for the face side of every piece cut to get the same great results.
Pair the I-Box jig with your table saw and a Freud SBOX8 blade set or equivalent for 1/4" and 3/8" cuts, or a Freud LM72R008 or equivalent FTG type blade for 1/8" cuts and it makes some beautiful box joints. I rarely make box joints larger than 3/8", but have used my Freud SD608 Dado blade set for a few boxes and had good results too. They just don't have the perfectly square, flat bottomed cuts that these other blades can produce.
I know the inventor, but I have no other connection to him or Incra. I do like his I-Box jig though.
Charley
kp91, Gaffboat, jj777746 and 3 others like this.
Central North Carolina
CharleyL is offline
post #3 of 12 (permalink) Old 05-10-2019, 02:50 PM Thread Starter
First Name: JJ
Thanks for that info Charley. Can I ask, were you the member who bought the Rockler Corner Key Doweling Jig? If so do you like it?
Flipsaw is offline
post #4 of 12 (permalink) Old 05-10-2019, 08:10 PM
CharleyL's Avatar
First Name: Charley
To be honest, I haven't been in my shop much at all since I got the jig.
I'm building a photo/video studio in the second master bedroom/guest room of my house. It's a 18 X 26' room on the 2nd floor. For the last 5 months I've only been going out to the shop when I need something, so no, I haven't used the corner key jig yet.
My wife has had cataract surgery, now in both eyes, so I've also been the on call designated driver for her needs too. I guess right now I'm a woodworking wannabe with lots of ideas, but no time left in my days to work on them. If/when I do get back to real woodworking, the photos of my projects are going to be significantly improved though.
MY most recent challenge is getting a 60 inch wide format photo quality printer working. I've stored it for 3 years and I'm trying to get it to print again. It'll be printing my project drawings as well as BIG photos, if I can succeed in getting the ink flowing again.
Charley
CharleyL is offline
post #5 of 12 (permalink) Old 05-10-2019, 09:20 PM
Best luck I've had with getting ink to flow again was to wet a cloth with rubbing alcohol and daub until I don't get any more ink color, then with a fresh cloth, I go back over the print head, rubbing it somewhat lightly to pull any deeper dried ink out.
If that doesn't work I replace the printhead. I have had less luck doing this with Epson than with HP. From time to time I think about switching to a color laser printer, but that toner is really pricey. I don't count on ink jet printers lasting more than 3 years, less if they aren't in regular use.
Using a brand new laptop today. Will keep it and donate my last win 10 laptop to my senior group. Win 10 doesn't suck, at least not much. I just have to remember it's only on loan from Bill Gates.
DesertRatTom is online now
post #6 of 12 (permalink) Old 05-10-2019, 09:45 PM Thread Starter
First Name: JJ
Wow Charley you sure do have your time all taken care of for sure. Hope that you wife does well with her recovery and that you get that printer working without costing you too much. Good luck with all.
Flipsaw is offline
post #7 of 12 (permalink) Old 05-11-2019, 10:21 AM
CharleyL's Avatar
First Name: Charley
I actually have 2 of those wide format printers and they are almost the same model, but one has a sheet flipping assembly on it so it can automatically print both sides of the sheet. I'm trying to get the one without this sheet flipper working first. If I need parts, which I doubt, the other will likely be the source of them. A print shop that owed me money for fixing one of their large presses, gave them to me as partial payment of my bill.
I had used the one that I'm trying to get working again for a short time, but then had to put it in storage when I closed my office. These printers are each almost 9' wide and 30" deep, so a lot of floor space is needed for them as well as the support space around them to be able to use them, and being ink jet, they need to be used at least once a week or the ink dries up in the heads. A refill cartridge for just one color is the size of a quart of milk and cost new about $300 each. There are 6 of them, so I'm hoping that I don't need to replace too many. All of them had plenty left when it went into storage. The problems and cost to keep these running is on a whole other level than the smaller ink jet printers that you have connected to your home PC, but oh what wonderful large banners, shop drawings, and life size photos they can print.
Charley
Herb Stoops likes this.
CharleyL is offline
post #8 of 12 (permalink) Old 05-11-2019, 12:13 PM
A guy I knew had a good business going around one of those oversized printers. He would contract with a bank or other institution to take local photos and blow them up to very large sizes and mount them for display. A number of restaurants around here do the same thing. He charged a lot for those prints. There are lots of photographers out there who make very little money. Having an oversized printer changes the game entirely. I think hotels and other public buildings would be interested in localized images in large sizes as well. Printing oversize versions of historic photos would another revenue source. To keep that kind of printer operating, you'd need to sell a fair number of images per week. I think it can take most of a working day to print a single picture, including a test strip. 1800 per ink change is some serious money.
post #9 of 12 (permalink) Old 05-11-2019, 02:33 PM
I had a decent home made jig but the issue with it was setting a saw stack back together that matched the original. As Charley pointed out with the Ibox you adjust the jig to your blade stack instead which is much easier and faster and gives better results.
Flipsaw likes this.
post #10 of 12 (permalink) Old 05-16-2019, 08:03 AM
First Name: ben
Charlie has given me some incentive to revisit the Incra Ibox jig. I purchased one some time in the past year and did not have a stellar success as shown in the attached photo. I had plenty of (nominal) 1/2" Baltic Birch scraps so I used them for my first test. I like having small boxes around the shop so my efforts did not go to waste. However, my ego was bruised with the quality of the joint plus I consumed a lot of setup time. The work was done on the table saw with a dado blade.
I need to rebuild the drawer box in an existing bathroom vanity and it will be about 5" deep and I will be using 1/2" Baltic Birch. Would you recommend using a 3/8" joint?
If you want to see some pretty examples of what the Pro's can do with the Ibox, visit the Incra facility in the Dallas, TX area. They don't have a fancy show room but did have lots of samples of fancy joints.
Name:	Ibox jig results.jpg
bfblack is offline
Has anyone used an Incra original jig with a Bench Dog Contractor? friscomike Jigs and Fixtures 3 06-04-2013 10:53 PM
My First Jig Coleve Show N' Tell 14 03-10-2013 09:12 PM
Original Incra Jig on my table rwl7532 Table-mounted Routing 6 03-05-2013 10:47 AM
The Incra I-Box Jig Tagwatts1 Tools and Woodworking 1 07-17-2012 06:19 AM
Akeda BC24 Dovetail Jig arrived! Michael H Jigs and Fixtures 13 04-11-2012 10:50 PM
