Installing Kreg Clamp Plate - Router Forums
 11Likes
  • 5 Post By tomp913
  • 2 Post By RainMan 2.0
  • 2 Post By Knot2square
  • 1 Post By bryansong
  • 1 Post By DesertRatTom
post #1 of 5 (permalink) Old 05-20-2019, 10:45 PM Thread Starter
Default Installing Kreg Clamp Plate
Finally getting around to installing a Kreg Clamp Plate in my workbench top. I built the jig shown using scrap plywood and pocket holes, but if/when doing it again I would just use strips of MDF and double sided tape.
I cut the recess and then had second thoughts about squaring out the corners left by the router bit - I could see the laminate chipping when I used a chisel, not to mention what it would do to the edge on the chisel, so had the idea that the smarter way would be to round the corners of the clamp plate (maybe something that Kreg should have done?). I screwed the plate to a length of 2x4 so that I could hold the wood rather than the aluminum while rounding the corners on the disc sander - this worked very well, a lot easier, and probably safer, than trying to hold the short plate. In order to check progress on the rounding, I cut a corner into a piece of plywood and used that to check how well the corners matched - this was when I found that the recess wasn't quite deep enough so I had to relocate the fixture over the recess in the top. Turned out the easy way was to put some washers in the recess and set the clamp plate on top of then, and then drop the fixture over the projecting plate and reclamp it. Installation turned out OK except for the little whoops on the first plunge - I set the plunge depth to barely cut through the laminate and then had the bit too close to the jig before I plunged and wound up putting a little divot in the edge. A little wood putty took care of that before plunging the full depth.
tomp913 is offline
post #2 of 5 (permalink) Old 05-20-2019, 10:57 PM
RainMan 2.0's Avatar
Like your pocket hole template . Thanks for sharing
MEBCWD and tomp913 like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 5 (permalink) Old 05-21-2019, 06:51 AM
First Name: Steve
I too had wondered why Kreg didn't round over the corners. Nice fix for the problem.
Knot2square is online now
post #4 of 5 (permalink) Old 05-21-2019, 03:29 PM
bryansong's Avatar
First Name: bryan
Nice job Tom, I like your thinking. I have the Kreg plate clamp but I just mounted mine to a sanded plywood sheet I use for a table. I really like this clamp. I don’t remember exactly how I cut out the corners but sanding down the corners would have been a good idea.
tomp913 likes this.
bryansong is offline
post #5 of 5 (permalink) Old 05-21-2019, 04:05 PM
I like simple cures like this. Nice.
tomp913 likes this.
For Sale: KREG Router Table Top - $75 - Kenosha, WI marc82much Woodworking Classifieds 3 04-14-2014 12:23 PM
For Sale: Kreg Router Plate - New - Kenosha, WI marc82much Woodworking Classifieds 2 04-14-2014 09:04 AM
Router Plate Installation Rutabagared Project Plans and How To 11 01-14-2012 08:15 PM
Kreg Router Table and Fence jeffk Table-mounted Routing 25 10-14-2011 07:25 PM
MLCS/Harbor freight router plate inserts not flush with plate Mike Gager Table-mounted Routing 14 12-22-2009 10:54 PM
