Router Lathe - Router Forums
 6Likes
post #1 of 22 (permalink) Old 06-14-2019, 02:17 PM Thread Starter
First Name: Larry
Question Router Lathe
Has anyone did any thing with the Router Lathe?
woodie26 is offline
post #2 of 22 (permalink) Old 06-14-2019, 05:39 PM
no...
post #3 of 22 (permalink) Old 06-14-2019, 07:00 PM
That's a pretty specialized tool. Haven't needed to make what they produce. Here's a link with basic information on the tool.
https://www.wisegeek.com/what-is-a-router-lathe.htm
post #4 of 22 (permalink) Old 06-14-2019, 09:36 PM
kp91's Avatar
First Name: Doug
I've used a Legacy Ornamental Mill for a bunch of projects, essentially a router lathe
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #5 of 22 (permalink) Old 06-14-2019, 11:39 PM
First Name: Rick (actually Enrico)
Default "router lathe"
Yes, I have a Craftsman Rputer-Lathe from the 1980's that I use to make spindles (and half spindles) with spirals and other decorative patterns. What is it that you wish to know about this fixture/machine?
I have previously posted photos of a six drawer sewing spool cabinet that I made for my wife that has decorative half spindles with a spiral pattern. I will try to add one photo to this post.
Rick
It seems that I am not able to post photo into this thread.
jaguar1201 is offline
post #6 of 22 (permalink) Old 06-15-2019, 07:15 AM
Country: South Africa
First Name: Hentie
I want to modify my router lathe so that I can add a template or item to copy, at the exact distance that the router is from the pivot point
lowracer is offline
post #7 of 22 (permalink) Old 06-16-2019, 06:17 PM
First Name: Biagio
Hentie, I have an old Vermont American model that I have not used in about 30 years, after I got a lathe. I used to do twists and open spirals on it. From what I remember, one could use a template, but the template follower is at the front of the router carriage.
I don’t see how it could be otherwise. If the follower were in the midline, where would you place the template? The workpiece is in the midline.
If you are worried that the workpiece diameter will be smaller than that of the template, because of the “pantograph” effect of having the follower at the front, you can compensate by adjusting the bit height, or by increasing the template diameter, but the calculation involved in doing so, is beyond me. Trial and error, in my ignorance.
I do remember having some dissatisfaction with the bit not being perpendicular to the workpiece throughout its travel, because the carriage pivots on the rear rail, and the tip of the bit therefore travels through an arc. This was only a major problem when cutting open spirals - the spirals landed up having a “rhomboid” cross-section. For surface decoration (e.g. diamonds cut with a twist and reverse twist) it was not that noticeable.
I had had a vague notion of making a parallelogram-based carriage to try and keep the bit travel perpendicular to the workpiece axis, but the model I have is very basic, with a fixed ratio of turn to travel, so probably not worth it.
Biagio is offline
post #8 of 22 (permalink) Old 06-16-2019, 10:38 PM
Use the Advanced Reply and click on Manage Attachments Rick.
post #9 of 22 (permalink) Old 06-16-2019, 11:40 PM
Default What model Router-Crafter do you own?
Larry,
You have not said what make/model of "Router Crafter" you own. Is it a Craftsman or its English brother? If so, the operator manual details how to mount a linear template across the front base of the fixture/machine. By linear template, I mean the a profile template of the desired shape of cross-section if a plane were cut through the centerline of the work piece.
Rick
I am trying again to upload a photo of the spiral half spindles on the spool cabinet that I made for my wife.
marecat3 and lowracer like this.
post #10 of 22 (permalink) Old 06-17-2019, 02:36 AM
First Name: Hentie
Biagio, My router lathe is one of the newer tork craft ones, it doesnt have a place to mount templates, except I can put a screw in to turn cylinders(that will run on one of the rails). I have downloaded the manuals for the original craftsman router lathe, and I completely understand regarding the pantograph effect. Because the following pin is saw twice the distance, the high spots needs to be twice the distance you want it to be. In addition, you cannot mount an existing item (table leg, baseball bat, etc) and you have to create a template for everything.
Now - think outside the box. Think see-saw. if you extend the router carriage to the other side and put the pin/follower at the exact distance your router bit is from the hinge, and your pin will ride at the bottom of the Template or existing item
it doesn't even need to be straight, as long as it is fixed. top left is what the first thinking is, but if the router gets in the way, you can do it like the picture below. on the right is where and how - it doesn't have to be a plate. it just needs to be sturdy
Does the picture make sense?
Name:	Router lathe.jpg
lowracer is offline
