Simple Router Planer for Small Pieces - Page 3 - Router Forums
 20Likes
post #21 of 26 (permalink) Old 09-25-2019, 12:27 PM
it's resaws he's trying to flatten...
Yes....?
DesertRatTom is online now
post #22 of 26 (permalink) Old 09-25-2019, 02:04 PM
Originally Posted by Nickp View Post
Didn't think a 3-6" piece would go through a planer properly...? Am I missing something...?
The risk with short or very thin pieces is that the leading end can tip up slightly and get caught by the planner head and send it upwards. A sled can help but that doesn't mean there is zero risk in doing it. Taped down will also help but the tape can only hold so much. I think skis or sled is probably safest since you can adjust for a very thin bite and the force is sideways on the piece with no tendency to lift it up.
Gene Howe, Nickp and Stick486 like this.
post #23 of 26 (permalink) Old 09-25-2019, 04:41 PM
Originally Posted by DesertRatTom View Post
Yes....?
yes...
post #24 of 26 (permalink) Old 09-25-2019, 06:48 PM
yes...
Stick, I saw no mention of resawing early on in this string. And even if it is resawn, the same problem arises with flattening and the same methods apply.
post #25 of 26 (permalink) Old 09-28-2019, 03:06 PM
Sorry, took me a while to find this. If the OP is trying to clean up a resawn board, this would work by sticking the original flat side to some double-sided tape and using a planer bit to clean up the sawn surface/finish to the required thickness.
Stick486 likes this.
tomp913 is offline
post #26 of 26 (permalink) Old 09-29-2019, 03:41 AM Thread Starter
That would work esp since I am just taking a very small amount off to true up a surface. !!!! Thanks!
Flutemaker is offline
