Circle/Radius Cutting Jig - Page 2 - Router Forums
 25Likes
post #11 of 46 (permalink) Old 10-02-2019, 06:30 AM
hawkeye10's Avatar
First Name: Don
This is my circle cutting jig. I also use it for making economy bowls.
DesertRatTom and TenGees like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #12 of 46 (permalink) Old 10-02-2019, 08:57 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Originally Posted by CharleyL View Post
All of the posted methods work great, even the Jasper jig that you found in the store. I have used all of them at one time or another, and they all do a good job. Adding the 1/4" pivot pin to your edge guide is yet another good, and cheap, way to cut arcs and circles. Kudos for coming up with a cheap (free) solution.
Bobj3 modified his Jasper jig so he could use it with a router bushing some years ago and posted pictures here. I thought it made the Jasper jig even easier to use, just in case anyone is interested. A search on this site should find it easily.
Charley
Yes Charlie, Bob's version was a BIG improvement on mine.
Harry
harrysin is offline
post #13 of 46 (permalink) Old 10-02-2019, 04:45 PM
CharleyL's Avatar
First Name: Charley
Rick,
The only suggestion that I can make about your router circle jig is to be certain that you have all of the thumb screws good and tight before cutting the circle.
I was using my CRB7 jig and DeWalt 618 router to cut circles from 3/4 cabinet birch ply and my thumb screws were tight, but apparently not tight enough, and my first circle suddenly began to diminish in diameter as I was cutting it. I saved the day by deciding that this piece would now be the smaller of the two diameters that I needed. The smaller diameter circle needed to be 4" in diameter smaller than the large one, and I had luckily been trying to cut the larger one first.
After cranking down on the thumb screws at both ends of each guide rod for each circle setting, my circles in both pieces turned out perfect. They became the two layered lid to attach my Dust Deputy to my metal 20 gallon re-purposed grease barrel.
No matter how good we get at woodworking, there still seems to be a woops every once in a while, and this was one of mine.
Charley
Central North Carolina
CharleyL is offline
post #14 of 46 (permalink) Old 10-02-2019, 06:26 PM
The instructions Pat Warner's router circle jig has pretty much identical instructions for setting the pivot pin to router bit distance - he claims that, with care and experience, the circle diameter can be set within a couple of thousandths. His jig, shown in the attached photo, uses a .185" diameter pin (I believe that this is a section of #13 drill bit) which gives a close but workable fit on a 3/16" drilled hole - you can just make out the pin to the left of the clamp knob. I wish now that I'd thought to ask Pat about making the center hole in the plate for a snug fit on a 3/4" guide bushing - I don't know what the actual hole size is but it's quite a bit larger than the biggest standard size - somewhere in the shop I have a circle guide that I made years ago with a 3/4" center hole; to use, I just mount a 3/4" bushing in the router, drop it in the hole and cut the circle. The router doesn't rotate as you cut the circle and so the power cord doesn't wind itself into a know, no matter how many rotations you make to get to the required depth. Pat's jig is a dream to use, very easy to adjust, and I guess I could modify a guide bushing by shrinking a brass/nylon ring on the OD of a guide bushing and using it that way.
tomp913 is offline
post #15 of 46 (permalink) Old 10-04-2019, 02:40 PM
Rick,
Nice first design. I've attached Pat Warner's circle jig which I have found to the be the best out of all the circle jigs I've used. Unfortunately Pat passed away and his web site is unavailable, but I used the Internet Archive to get a previous version.
3/16" or 1/4" dowel pins make for better pivots and are cheap. You're correct about a bit of trial & error on the radius because the router armature and collet have a bit of runout. Also the router bits have a small tolerance.
I copied Pat's design in MDF. I would suggest cast acrylic because it's super handy to see thru the base. My base has seen quite a bit of use and the couple of coats of thinned polyurathane varnish is holding up well. Some paste wax on the bottom helps too. Below are a couple of pics of the build.
harrysin likes this.
dgwoods is offline
post #16 of 46 (permalink) Old 10-04-2019, 02:53 PM
Lucky you to have an original. I don't quite understand the 3/4" bushing vs using a 3/4" bit as the OD's are different and how you are doing the setup. That said the Porter Cable guide bushing specs are:
  • Thru hole: 1 3/16"
  • Flange: 1 3/8"
The 1 3/8" counterbore is a bit expensive if you work w/acrylic or jig plate.
And yes, you can set the radius to a couple of thou on first try.
dgwoods is offline
post #17 of 46 (permalink) Old 10-04-2019, 11:33 PM
Old_Tom's Avatar
Hi Rick. I made mine out of MDF and it works well. It provides a huge range of circle diameters. Looking at what you did I went back to my trim router accessories and worked out I can produce up to a 13 inch diameter circle with the bits provided with it Oh well practice I suppose.
Great job mate.
Name:	Router Circle Jig1_sm.jpg
There's nothing like the smell of raw wood in the morning!!
Old_Tom is offline
post #18 of 46 (permalink) Old 10-06-2019, 10:46 AM
  • Flange: 1 3/8"
Sorry, didn't make myself clear. When using a guide bushing on the router mated to the corresponding hole in the circle guide, the router is NOT bolted to the circle guide. What this means is that the router doesn't rotate with the jig as you sweep the circumference of the circle being cut ie the router stays in the same position relative to the operator so the guide bushing is rotating inside the hole in the circle guide. This means that the power cord and vacuum hose, supported from above to stay out of the way, stay in the same relative position and don't end up twisted in a know, no matter how many times you need to go around the part to cut through.
Cutting a circle in plywood is a snap, cutting a circle in wood is somewhat of a problem as, depending on the direction of rotation, some segments are being cut against the grain - the solution then is to cut the circle in 4 segments so that you're always cutting with the grain and don't wind up with chip-out.
Old_Tom likes this.
tomp913 is offline
post #19 of 46 (permalink) Old 12-19-2019, 08:08 PM
First Name: Patrick
What was the advantage of machining(?) the brass hex "head" verses just cutting the threads longer and having a regular nut on both sides? Actually I bet I know after asking, it was probably because the nut that should be fixed might move while loosening the other nut, and that would cause slight variances in the distance the pin protruded.
pperry42003 is offline
post #20 of 46 (permalink) Old 12-19-2019, 08:39 PM Thread Starter
RickKr's Avatar
A couple reasons. First, it is like why dogs lick their... Because they can...
Kidding aside, I had the brass hex stock and I wanted the pin to be as secure as possible. With nuts on both side the pin can actually be angled. Turning the shoulder on the brass hex stock ensures to a greater degree that the pin will remain perpendicular. Also, I have not looked at it in a while, but I suspect the stock screw can be undersized. My brass pin is a slip-with-no-slop fit. Overkill, but that is how I like doing things.
The way I've made the brass one, there can be no variation in how far the pin protrudes.
Rick
"Quality is like buying oats. If you want nice, clean, fresh oats, you must pay a fair price. However, if you can be satisfied with oats that have already been through the horse, that comes a bit cheaper."
RickKr is offline
