Very Simple Router Planer - Page 2 - Router Forums
 41Likes
post #11 of 22 (permalink) Old 11-23-2019, 04:42 PM Thread Starter
LeftFinger's Avatar
First Name: Rich
Originally Posted by DaninVan View Post
A beauty, Rich! Is that a temporary base, or was it previously used; it looks like it has some history(?).
No it was made for a work bench .Take 8 nuts off and the base is in pieces for storage .The top just lifts off. The finish on the oak is steel wool/vinegar and peroxide (home made aging stain) almost turns the oak black. I can switch between a butcher table and a workbench in seconds .Just have to build the workbench
Originally Posted by RainMan 2.0 View Post
I also like the idea of having those marks on the side pieces so you know how much to move it each time .
Im liking the aluminum idea as its thin horizontally , which should be better as your not extending the router out as far.
Nice outcome on the table to Rich
Thankyou
strong, light and simple is what I was looking for. and yes the marks really work . Bits 2 1/4 marks are 1 1/2 good overlap for a smooth finish
DaninVan and RainMan 2.0 like this.
LeftFinger is offline
post #12 of 22 (permalink) Old 12-29-2019, 12:11 PM
Simply excellent!
I would like to do something similar using my Festool OF1400 router which is quite heavy but on a smaller scale to plane cutting boards.
I have just made my first cutting board but caused a hollow using a sander right in the centre of the board trying to get rid of the glue squeeze-out.
Please can you advise the size of the aluminium angle iron particularly the thickness. I have some already but am concerned it might be too thin.
Many thanks.
Lofty Dave from the UK.
LeftFinger likes this.
LoftyDave is online now
post #13 of 22 (permalink) Old 04-08-2020, 08:04 PM
First Name: Michael
Nice Job Rich.
Curious, did you sense much deflection in your jig when you were sliding the router or did it seem nice and solid.
Sent from my iPad using Tapatalk
mbrun is offline
post #14 of 22 (permalink) Old 04-08-2020, 08:26 PM
Michael; in theory at least, there shouldn't be any deflection. That's the beauty of angle iron; the adjacent legs add tremendous stiffness and strength to the other leg.
It comes in two styles, Structural and Architectural. The Architectural has clean sharp corners, no molded-in fillets
https://www.metalsdepot.com/aluminum...num-angle-6063
DaninVan is offline
post #15 of 22 (permalink) Old 04-09-2020, 06:37 PM
First Name: Michael
You jig looks like it could handle about a 36 slab, is that about right?
mbrun is offline
post #16 of 22 (permalink) Old 04-09-2020, 07:56 PM
Very smart move raising the router so you just adjust bit height to set thickness. You could also use low friction tape in the channel to smooth out sliding. Really good idea to mark the spacing as well. Welcome to the Forum, by the way, darn good first post!
post #17 of 22 (permalink) Old 04-11-2020, 05:56 PM Thread Starter
LeftFinger's Avatar
First Name: Rich
I use paste wax on the rails
no friction
DesertRatTom likes this.
post #18 of 22 (permalink) Old 04-11-2020, 05:57 PM Thread Starter
LeftFinger's Avatar
First Name: Rich
good eye
post #19 of 22 (permalink) Old 04-11-2020, 06:03 PM Thread Starter
LeftFinger's Avatar
First Name: Rich
Originally Posted by LoftyDave View Post
Simply excellent!
This was only 1/8 or .125 of an inch thick but 3"x 3"
3.17mm x 76x76mm
Many thanks.
[QUOTE=mbrun;2101273]Nice Job Rich.
No decernable deflection
post #20 of 22 (permalink) Old 05-17-2020, 01:39 PM
JFPNCM's Avatar
First Name: Jon
Well executed concept. Appreciate the details and looking forward to future posts.
Jon
JFPNCM is offline
