Curved Rectangle Drawer Hole Jig? - Page 2 - Router Forums
 32Likes
post #11 of 16 (permalink) Old 01-19-2020, 12:50 PM
RickKr's Avatar
Originally Posted by CharleyL View Post
I made a template from 1/4" Baltic Birch and used my DeWalt 611 with a router bushing and up spiral bit to make the hand holes in the tote bins in the attached photo. I made 12 of these bins, 24 total hand holes. ...snip...
Charley
Nice boxes, man! I will keep that idea as I would like to make some. I use quite a few of the plastic milk crates that I scored from a "rebuilding" center (24 of them). They came in quite handy when I moved 4 years ago. They are not nearly as "decorative" as your wooden boxes.
Are they made from Baltic birch plywood (BBP), or "real" wood? I would likely use the BBP.
Rick
"Quality is like buying oats. If you want nice, clean, fresh oats, you must pay a fair price. However, if you can be satisfied with oats that have already been through the horse, that comes a bit cheaper."
RickKr is offline
post #12 of 16 (permalink) Old 01-19-2020, 01:04 PM
RickKr's Avatar
Originally Posted by wwian View Post
...snip...
Yes, I could drill two Forstner holes and then the jigsaw cut the drawers. But, I'm looking for something that I could use my router to make the holes more smooth and uniform.
Thanks for any wisdoms!
I agree with drilling/sawing out the waste and making a template to route the profile with a shallow clean-up cut, 1/8". I have done this in 2x10 lumber for making handholds in a ladder. Templates I made used the router base as the guide, but comments pointed heavily towards using guide bushings (more accurate and less material), which I will do in the future.
For smoothing over the edges, I think using a round over bit makes more sense than doing it by sanding. For my project, which was quite thick, I used a 1/2" radius round over bit. If your stock is 3/4", I would use 3/8" or maybe 5/16" if the stock is slightly undersized.
Rick
Name:	Handholds in Stringers Done 1 01-11-20 640.JPG
wwian likes this.
RickKr is offline
post #13 of 16 (permalink) Old 01-19-2020, 01:59 PM
PhilBa's Avatar
First Name: phil
Rick
Those came out pretty nice, rick. A round over bit makes a lot of sense down to about 3/16". Below that I think sanding is easier.
Cherryville Chuck likes this.
Visit my shop website.
PhilBa is offline
post #14 of 16 (permalink) Old 01-19-2020, 08:54 PM
RickKr's Avatar
Thanks. Yes, I think so too. Very pleased. It took a lot of work getting the templates right, but once that was done, it went very quickly.
I have a 1/8" round over bit and by the wood dust on it, I've used. I just recalled on what, some 1x2" clear pine that I made a "twined rag rug" loom with.
Rick
RickKr is offline
post #15 of 16 (permalink) Old 01-20-2020, 04:07 AM
CharleyL's Avatar
First Name: Charley
Rick
Yes, Rick.
My tote bins were made from 12 mm (1/2" ) Baltic Birch plywood. I had found a source for buying 1 X 5' drops from a very large CNC project that needed 4 X 5' of each sheet. The remaining drops were being sold for $2.50 each ($0.50/sq ft) and I bought a bunch of them. I still have quite a few left.
I didn't remove the waste before cutting the hand holes in the tote bin end pieces, but I did rout them in 3 passes at increasing depths, then rounded them over with a 1/8" bit before assembly. You can't round from both sides if the box is assembled before this step. Care is also needed to make certain that the bearing rides on the center of the work thickness. I would have preferred a larger radius, but the bearing must touch the center uncut area when rounding from both sides The bottoms of these bins were just made slightly over size, glued on, and then trimmed flush on the router table. For their intended purpose of moving and organizing small pieces of wood for the scroll saw, I felt that just gluing the bottoms on was sufficient. Baltic Birch is quite stable, so shop moisture level changes aren't expected to cause the bottoms to pull free.
Charley
Central North Carolina
CharleyL is offline
post #16 of 16 (permalink) Old 01-20-2020, 11:15 AM
I've cut many of these holes, used instead of drawer pulls. The attached photos show a drawer front on a platform bed that I made 30+ years ago. To be efficient, you need 3 routers - a plunge router with a 1/4" up-spiral bit and a 1" guide bushing, a standard router with a 3/4" bowl bit (although a plunge router will let you take smaller bites or eliminate the need to reset the depth) and a trim router with a 1/4"R round-over bit. Make the template 3/8" larger all around than the finished hole size - this is the offset between the OD of the 1/4" bit and the OD of the guide bushing. Clamp the template on the BACK side of the drawer front, and use the 1/4" bit to cut the hole through the part. Leave the template clamped on, flip it over and use the trim router to cut the 1/4" round-over around the front of the hole. Flip the part back over and use the router with the bowl bit to cut a recess 3/8" deep around the hole, running the bearing on the bit against the inside of the template (this will leave an 1/8" flat between the bottom of the recess and the edge of the round-over in case you want to do the round-over last). This procedure will give you a finger pull recess when the front has been screwed to the drawer. If you want a deeper recess, use a smaller round-over bit and cut the recess right up to the edge of the radius, cutting the round-over before the recess gives you plenty of flat to run the bearing of the round-over bit, and you can take some sandpaper and break the sharp edge around the inside of the hole. If you don't have a bowl bit, a standard pattern bit will work, you just won't have the radius in the corner of the recess.
Stick486 and wwian like this.
tomp913 is offline
