Fort Ladder / Merging Threads - Page 2 - Router Forums
 31Likes
post #11 of 70 (permalink) Old 01-20-2020, 12:55 AM
Stick was talking about nipping the the sharp tips off the gusset. The gusset is an isosceles triangle with leg, leg, and a hypotenuse. He meant nip the tips off perpendicular to the legs.
I don't think I would trust the pocket screws to keep the sides from spreading. I don't trust pocket screws for much but I know lots do. I also don't see much opportunity for racking. The top will be firmly attached to a non moving structure and the bottom will be on the ground. There will be some flexing though and that's why I don't trust the screws. In a traditional wooden step ladder you only have 3/4" thick steps but they are supported by steel rods which help support the load but also keep the sides from spreading. The angle brackets Stick suggested would do that too but I would use machine screws and locking nuts to attach them so that they couldn't loosen over time. I don't know if you really need the gussets and they might get in the way when climbing. I would expect the ladder to flex a bit and some structures need to be able to flex. Too rigid and they'll self destruct over time. An airplane is a good example of that.
Stick486 likes this.
post #12 of 70 (permalink) Old 01-20-2020, 01:45 AM Thread Starter
RickKr's Avatar
I believe I am thinking the same, but here is a drawing of what I am thinking of, with radiuses, 1/2" and 1". I am inclined to the 1" radius. The 1/2" seems to get lost.
I know many do not like and/or do not trust pocket screws. I figured they are better than similar sized screws going through the stringers into the rung end grain, plus I was going to glue them. I realize that could make it too rigid, to your last point. I just don't see this ladder getting stressed that much, similar to your comment about not much racking. As you say, some need to flex, but I don't see this flexing that much (until "I" get on it ).
I do not think the gussets will interfere with climbing, based on the drawing above.
I will think on the matter of using machine screws, etc. I have a little time before needing to make that call.
Rick
Name:	Gusset Radii 01-19-20.JPG
Nickp likes this.
"Quality is like buying oats. If you want nice, clean, fresh oats, you must pay a fair price. However, if you can be satisfied with oats that have already been through the horse, that comes a bit cheaper."
RickKr is offline
post #13 of 70 (permalink) Old 01-20-2020, 02:26 AM
clip instead of radius...
the sharp turn will make a water let (drip point)...
as where water will follow the radius...
radius the long outside edges of the gussets...
thru screw the steps/rungs/gussets w/ RSS/GRK screws from the outside of ladder stringers...
https://www.grkfasteners.com/product...ructural-screw
or headlok structural screws by timberlok...
https://www.fastenmaster.com/product...-fastener.html
use construction adhesive like PL Premium instead og glue... you won't regret it...
https://www.loctiteproducts.com/en/p...nadhesive.html
you get your flex...
you get serious strength..
you get water proof end grain..
Nickp likes this.
post #14 of 70 (permalink) Old 01-20-2020, 06:18 AM
Nickp's Avatar
First Name: Nick
The important thing is that you have plenty of options to consider...and that the kids will have a grand time with the fort...
Cherryville Chuck likes this.
Nick
Nickp is offline
post #15 of 70 (permalink) Old 01-20-2020, 06:58 AM
Bstrom's Avatar
First Name: Brian
This is a cool idea but borrowing from my industrial climbing experience, personnel (children too!) safety calls for a cage around this thing to prevent or minimize falls. I know that complicates the whole idea but it's an OSHA things nowadays.
Of course, they could always wear safety harnesses and fasten to a heavy rope coming down from above - now that's where the fun would begin!
Common Man Woodworking
Powell, TN
Bstrom is online now
post #16 of 70 (permalink) Old 01-20-2020, 11:34 AM
If this goes up more than 10 ft, I think a cage is in order. Falls from that height WILL break bones or cause other injury depending on how they land. Start the cage at 5 or 6 feet, and wide enough so an adult can get through comfortably. A cage will spoil the ship's ladder look unless you make it with a very open look. I bet many kids will see it as kind of a tunnel and enjoy climbing through it.
Another possibility would be to put some soft landing under the ladder. I lived next to a park once and they laid a layer of rubber particles, kind of like pea gravel, under the play areas to soften the landing if a kid fell. You could probably use wood chips for this, but there will be splinters, and it will deteriorate over time. If you use rubber particles, the base for the ladder still needs to be set on something pretty solid, perhaps a short chunk of 2x6 or 8 of synthetic decking that won't rot.
The landing pad, if you do that, would be 4-6 inches thick and wide enough to assure a falling child would land on it. Here's a link for playground safety mats. https://www.greatmats.com/playground...ayground%20Mat
That ladder is too pretty for a cage unless it's tall enough to cause more serious injuries if a child falls. So I'd go with the padding. If this is where many children will find and climb it, you will have created an attractive nuisance and could have some liability issues. If it's in an enclosed back yard, the homeowner insurance MIGHT cover injuries. Damn Lawyers pop up everywhere, don't they, like weeds. Sorry to bring this up, but I remember when the playgrounds were upgraded from dirt, the city had put them in to cover their financial behinds.
Putting my little guy hat on, if I had a ladder like this, I'd HAVE to climb it.
DesertRatTom is online now
post #17 of 70 (permalink) Old 01-20-2020, 12:16 PM Thread Starter
RickKr's Avatar
Default Jig for Keeping Rungs Square
I really appreciate the discussion and idea for fastening and gluing the rungs for this ladder. Thank you all. I will go with the construction wood screws and construction adhesive. I know I've seen screws like that at the local hardware stores but I have not looked at what sorts of construction adhesives they carry. I know the brands of screws Stick posted are NOT available locally, but one brand is at one store 50 miles away. Because of the rigid mount, I may not go with gussets.
So, moving on ...
I am thinking ahead on how to hold the rungs square as they are fastened/glued to the first stringer. I am thinking all the rungs must be secured to one stringer first and then the other stringer added in a second stage. It is possible the rungs would mount fairly square without any jigging (is that a word? - sounds like a fishing action) because the pockets have been routed square bottomed and the ends of the rungs have been cut very square. But, I do not want to rely on that, solely. I would like to come up with a jig, large squares that can be clamped to the stringer and rung while it is being glued and screwed in place. I have a couple of the large construction squares and they clamp up okay with the stringer flat and the rungs sticking upward.
However, that is not a position in which I want to be gluing and screwing, from below. I am not confident that those squares will stay in place if the clamped up rungs/squares were laid over flat, so I think some blocks or something need to be attached to the squares for more secure clamping. I am okay with drilling holes in at least one of the squares for attaching blocks. Alternatively, it could work to clamp blocks to the stingers/rungs and then clamp the squares to those blocks, eliminating the need to drill and bolt blocks to the squares. But... that is a couple extra steps that may not work well with glue setting up.
Thinking further, glue and screw the two first rungs while laid flat, without clamping square. Then tilt it up so the rungs are upright and then clamp them square (as pictured) and let the glue set up. That could be done quickly and well within the glue working time (if not, I need to find a different glue as the final glue up of the second stringer is going to take much longer).
Follow that same procedure for adding the other rungs and use a lath to tack the others square, using the clamped square to align each rung, prior to tacking.
I am also starting to think about the entire gluing/screwing operation/sequence of once the rungs are all in place on the first stringer, how do I go about adding the second stringer and gluing/screwing all nine rungs? Will the working time of the adhesive allow for applying glue to all the pockets/joints, press the stringer on and then drive the screws? I am thinking that at this point the assembled first stringer and rungs can be laid flat on a bench or horses so the screwing of the second stringer could be done horizontally. I anticipate that holes for all the screws will have been pre-drilled in the stingers and the screws in place ready for driving into the rungs.
... OPEN THE FOOD GATES !!!
Rick
Name:	Square Clamping Rungs 2 01-20-20 640.JPG
Name:	Square Clamping Rungs 3 01-20-20 640.JPG
RickKr is offline
post #18 of 70 (permalink) Old 01-21-2020, 12:49 PM Thread Starter
RickKr's Avatar
I found the Loctite adhesive in two forms. Stick’s one is 3X strength, second one says 8x but says “fast grab” but neither says what the working time is. Anyone know anymore amp out these?
Rick
RickKr is offline
post #19 of 70 (permalink) Old 01-21-2020, 01:06 PM
SEE PAGE 2....
You don't want fast grab...
and all you need to know is in the link I gave you...
open time is 15~20 minuets..
reposition time is 30~45 minuets...
post #20 of 70 (permalink) Old 01-21-2020, 01:21 PM
put one tread and two stringers together. glued and screwed....
insert a spreader between the stringers to open the gap a touch.. it doesn't need to be much...
apply the adhesive to the dado...
slide the next tread into place...
remove the spreader...
install the screws...
repeat till yur done...
DaninVan likes this.
