record storage box - Router Forums
 42Likes
post #1 of 17 (permalink) Old 02-07-2020, 04:44 PM Thread Starter
makerofdust's Avatar
First Name: Bruce
Default record storage box
You're responsible for me going a head and cutting my first dovetail joints, between past threads and the file section I went and made my first dovetail joints for a vinyl record storage box for my daughter. Still need to finish it but wanted to show some of my work.
So thanks and it was a good thing I found this forum.
harrysin, Marco, CharleyL and 13 others like this.
makerofdust is offline
post #2 of 17 (permalink) Old 02-07-2020, 05:04 PM
1st one ...
if you say so...
makerofdust likes this.
post #3 of 17 (permalink) Old 02-07-2020, 05:09 PM Thread Starter
First Name: Bruce
well first with dovetails in it, I've done box joints on the tablesaw, but the router just took longer to use....
post #4 of 17 (permalink) Old 02-07-2020, 05:19 PM
Good job, Bruce, you will be doing more of these ,I guarantee. The next time set the bit a little deeper to give you a tiny bit proud on the pins. You can always sand them back flush.
HErb
harrysin, Marco and makerofdust like this.
Herb Stoops is offline
post #5 of 17 (permalink) Old 02-07-2020, 05:49 PM
difalkner's Avatar
First Name: David
Well done, Bruce - good job! She's gonna love it, for sure.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #6 of 17 (permalink) Old 02-07-2020, 06:18 PM
PhilBa's Avatar
First Name: phil
Very nice! And if you make the pins and tails a little proud, you can use a bearing topped trim bit to clean them off flush.
Visit my shop website.
PhilBa is offline
post #7 of 17 (permalink) Old 02-07-2020, 07:27 PM
Marco's Avatar
That came out very nice! Keep up the good work!
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #8 of 17 (permalink) Old 02-08-2020, 07:40 AM
sreilly's Avatar
First Name: Steve
Yeah that first try is a bear which apparently you nailed. Now show us the pile of "test cuts".........it took me a pile of scrap to ever get the 1st acceptable joint settings. I was either too loose, too tight, or too shallow/deep. But once set I was golden as long as the wood was square and the same thickness. I gave up trying to do plywood drawers with dovetails as I always seemed to get splinters/tear out even with a backer board if I was using the Incra system. I'm reasonably sure I was using Baltic Birch but may have to try one more time to be sure......it's an old memory thing....or maybe just an old thing......can't remember.
I've used my Porter Cable jig for both through and half blind but have decided to keep it set for 3/4" half blind and set it aside. I now use my Incra Super Fence with the LS System to do all others including half blind. I have found for me it's easier to get the joint dialed in and I have the ability to do wider boards if necessary and a wider variety of designs.
Regardless, very nice results for your 1st. As others have said making the joint slightly proud allows you to flush them.
harrysin and makerofdust like this.
sreilly is offline
post #9 of 17 (permalink) Old 02-08-2020, 10:08 AM
RainMan 2.0's Avatar
Nice work . I’ve never tried one before . Thinking about doing it after I insulate my garage
Ok ,I never insulate
RainMan 2.0 is offline
post #10 of 17 (permalink) Old 02-08-2020, 10:35 AM
Looks great. PC style dovetail jigs are a bit tricky but it seems you nailed it.
