circle jig - Router Forums
 16Likes
post #1 of 11 (permalink) Old 04-12-2020, 03:44 PM Thread Starter
Gerald Lutness's Avatar
First Name: Gerald
Default circle jig
Does anyone know where I can get plans for a simple circle jig. Also a manual for a Craftsman router model 315.240270. Thanks
Gerald Lutness is offline
post #2 of 11 (permalink) Old 04-12-2020, 04:04 PM
for the circle jig...
post #3 of 11 (permalink) Old 04-12-2020, 04:09 PM
for your manual...
this is all we gots...
https://www.routerforums.com/craftsman-manuals/
BTW.. your router was made by Ryobie if that's any help...
post #4 of 11 (permalink) Old 04-12-2020, 09:43 PM
The simplest circle jig I've ever seen is one made by past member Derek Willis. It's just a piece of shop scrap wide enough for the router to sit stably on that has been drilled with a hole the same size as the O.D. of a guide bushing. You then install the guide bushing on your router and stick it in the hole and then drive a nail through your jig and into the center of where you want the circle.
roxanne562001, MYB and Herb Stoops like this.
post #5 of 11 (permalink) Old 04-13-2020, 06:24 AM
John Smith_'s Avatar
Default Round Disk with Router
Gerald - what are your projects that require round disks ?
a long base plate made out of thin material like plexiglass
or similar material is the norm. there are jigs for bandsaws as well
that are different than the ones used for a router.
sign makers (such as myself) often have to make round signs so they
will have several jigs in the shop. what are you making ??
there is no size limit as to how big you can cut a round disk with a router.
I am a painter: that's what I do, I like to paint things.
John Smith_ is offline
post #6 of 11 (permalink) Old 04-13-2020, 04:54 PM
Bstrom's Avatar
First Name: Brian
Here’s my version - all ready to cut a 15” diameter face in Cherry for a reproduction antique school clock...made good use of that dreaded Bosch base too.
Common Man Woodworking
Powell, TN
Bstrom is offline
post #7 of 11 (permalink) Old 04-13-2020, 04:59 PM
there's always Jasper...
https://www.woodcraft.com/products/l...cle-router-jig
post #8 of 11 (permalink) Old 04-14-2020, 02:11 PM
I have both the Craftsman and Bosch edge guides. The Bosch is far and away the more useful and better designed.
It comes with an infinitely adjustable circle cutting attachment (within its range...up to 32")
At approx. 2 min into this vid...
.it illustrates the circle cutting function.
Seems like it'd be a very simple project to make a DIY rig.
I measured the Craftsman guide rods on mine, they're .048" ie 1/4" rod.
And the rod distance apart (on mine) is 4 7/8" on ctrs.
Check with your router to confirm, but those really are all the measurements you need to whip one up.
Other members have posted pics of their DIY edge/circle cutting guides in the past.
DaninVan is online now
post #9 of 11 (permalink) Old 04-14-2020, 02:13 PM
Bstrom's Avatar
First Name: Brian
My Jasper cost me nothin’ but an hour of layout, cutting and drilling. Here it is making the cuts on some Cherry for an antique wall clock reproduction. It’s hitting perfectly and the plunge makes depth control a breeze!
DaninVan and Gerald Lutness like this.
Powell, TN
Bstrom is offline
post #10 of 11 (permalink) Old 04-14-2020, 02:15 PM
At approx. 2 min into this vid... https://www.youtube.com/watch?v=O4kSqS1K7SY .it illustrates the circle cutting function.
And the rod length can be changed to what you need...
DaninVan likes this.
