Ideas for 20" wide fluting jig? - Router Forums
post #1 of 20 (permalink) Old 01-18-2011, 07:21 PM Thread Starter
Default Ideas for 20" wide fluting jig?
Hi all, I need to pick your respective brains for a jig idea!
I'm building a fireplace mantel and need to flute the face of the mantel. I have 2 spots that are about 8" tall X 20" wide. I'd like to stop the fluting rather than run them off the ends.
I've seen a rockler fluting jig that looks great, but only does a max of 8" wide, and I need 20". Any ideas for making my own jig?
Thanks!
GH
whizkid is offline
post #2 of 20 (permalink) Old 01-18-2011, 07:33 PM
RJM60's Avatar
First Name: Robert
Thanks!
GH
Milescraft Circle Jig - comes with an edge guide - beam is calibrated.
If not long enough, maybe you can hit it from opposite edges.
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #3 of 20 (permalink) Old 01-18-2011, 08:09 PM Thread Starter
Robert,
Thanks for the quick reply! I looked up the Milescraft and it gets bad reviews due to excessive play and cheap (plastic) parts. Do you have one and do you like it?
I am a bit leery about a small edge fence rather than a large, sled type jig. Any ideas along those lines?
Thanks again for the quick answer...
GH
whizkid is offline
post #4 of 20 (permalink) Old 01-18-2011, 08:36 PM
Hi
This may do the job
The jig can be made on the router table (with the stick way and a trim bit/pattern bit) or with plunge router.
post #5 of 20 (permalink) Old 01-18-2011, 08:43 PM Thread Starter
Bobj3,
This is so simple it's perfect! Just what I was looking for! (Now how do I make the jig?).
GH
whizkid is offline
post #6 of 20 (permalink) Old 01-18-2011, 08:46 PM
Hi GH
What router are you going to use ? (plunge/router table)
Bobj3,
GH
post #7 of 20 (permalink) Old 01-18-2011, 09:50 PM Thread Starter
Plunge router. I don't have a table.
GH
whizkid is offline
post #8 of 20 (permalink) Old 01-18-2011, 10:05 PM
Hi GH
Just put some 2 x 4's down on some scrap plywood (screw down), stick the MDF to the 2 x 4"s , it's just the same way but the sticks are on the bottom side of the MDF, drop the trim bit in the hole and go around the inside of the sticks..check the slots with the brass guide b/4 you take the sticks off the MDF.. when you get done just pop in your 3/4" brass guide on the bottom of your router select the bit you want to use for the flutes,,,a core bit/round nose works well for that job..
http://www.harborfreight.com/10-piec...set-95160.html
http://www.mlcswoodworking.com/shops...s/bt_core.html
http://www.mlcswoodworking.com/shops...nd_Nose_Anchor
GH
post #9 of 20 (permalink) Old 01-19-2011, 08:30 AM
boogalee's Avatar
First Name: Al
Thanks!
GH
You could build a jig similar to Rocklers with ½" MDF and a plastic base for the router.
In stead of putting the slots in the plastic for lateral movement, put the slots in the MDF.
I built mine for 12" wide moulding.
Al
boogalee is offline
post #10 of 20 (permalink) Old 01-19-2011, 09:04 AM
Hi
That would be great if you are going to do it more than one time if not a quick template should do the trick..
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
