cutting circles - Router Forums
post #1 of 6 (permalink) Old 01-23-2011, 11:25 AM Thread Starter
Default cutting circles
just got 1st. router,Bosch1617evs. ? is why does the base plate on the plunge base have to be removed &remounted on a trammel? why cant the base plate be left on & fastened to trammel.? Also, on my router what is the best place to anchor a trammel to? instructions are vague for a newbie. I'm going to try to make a trammel from plywood or standard 3/4 stock. Help- Jim
jimc6543 is offline
post #2 of 6 (permalink) Old 01-23-2011, 12:47 PM
Hi Jim, Welcome.
The reason you remove the base is because the trammel arm is mounted using the base plate location. It becomes the base plate for the operation. Making a trammel out of 3/4 stock is ok but you can use much thinner material. The added thickness will limit you to the depth you will be able to cut. I have made quik trammels out of 1/4" luan which measures 3/16" thick.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 6 (permalink) Old 01-24-2011, 11:22 AM Thread Starter
Thank You. Another ? I got what seems to be a spare? base plate w/ router & it seems to have some type of insert that seems to be spring loaded. This sits in spare base where the bit would come through. Is this made to hold something?is there some kind of bushyng? that fits in there? Thanks Jim
jimc6543 is offline
post #4 of 6 (permalink) Old 01-24-2011, 07:47 PM
Is the router you have a kit with 2 bases? One a fixed base & the other a plunge base(spring loaded). If so you just unfasten the router motor & slip it in the other base. Each base will allow you to do a couple of things different.
Whittier, CA.
jlord is offline
post #5 of 6 (permalink) Old 01-25-2011, 09:34 AM
Yes. the spring loaded gizmo on the plunge base is to hold bushings.
Mikeon is offline
post #6 of 6 (permalink) Old 01-25-2011, 02:18 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Jimc.
Dave
the "Doctor"
Dr.Zook is offline
Cutting boards for gifts.... gad5264 Project Plans and How To 16 08-17-2016 07:35 AM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
Cutting small external radi don't look like circles more like small hexagons TroyB CNC Routing 6 06-22-2010 09:03 AM
Cutting circles on the table crquack General Routing 10 11-04-2008 09:05 PM
Router and cutting circles chrissy Jigs and Fixtures 9 02-09-2005 04:22 PM
