Toggle clamps...how strong? - Router Forums
post #1 of 22 (permalink) Old 01-26-2011, 05:50 AM Thread Starter
matt1710's Avatar
Country: New Zealand
First Name: Matthew
Question Toggle clamps...how strong?
Am about to construct two jigs for use with my router table : a long-grain sled and an end-grain sled. They look like mighty useful (and safe!) device for a router newbie like me. The plans that I'm working from depict two toggle clamps per sled, however the strength of the clamps is not mentioned. I've been to the local engineering supply shop and tried to size up the clamps on offer - the ones that looked most suitable were rated at 75kg (165lbs) and 150kg (330lbs).
Any suggestions as to which would be most suitable - perhaps based on what you fellas use? I know it depends a little on the size of the stock being routered - I guess it's best to go too big than too small?
Matthew
PS - am happy to post some scans of the sleds for anyone interested.
matt1710 is offline
post #2 of 22 (permalink) Old 01-26-2011, 07:45 AM
First Name: Warren
All things being normal....nothing out of line etc. either of these should work IF they are set up and adjusted properly. With the larger clamps I have put 3/4" stock down and I don't think you could get it loose with a pry bar and both hands!!
The wise old grey beards will be along shortly and correct me if I have mis-spoken.
sourdough is offline
post #3 of 22 (permalink) Old 01-26-2011, 08:23 AM
Gene Howe's Avatar
First Name: Gene
Matt,
Either will work. For my own sense of security, I apply sandpaper to bearing surfaces. I use the lighter toggles and have had no slippage.
And, yes I'd like to see you sleds.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 22 (permalink) Old 01-27-2011, 02:37 PM
First Name: Simon
Hi, I am interested in the response you get as I to will need some toggle clamps soon.
I would like to see your plans, please.
Many thanks in advance, Si
chickenslippers is offline
post #5 of 22 (permalink) Old 01-27-2011, 04:43 PM
Ralph Barker's Avatar
First Name: Ralph
I've mostly used the smaller toggle clamps, as well. Gene's sandpaper suggestion is good, too, since in most cases the toggle is creating a friction-based hold on the work piece.
Note, too, tha the amount of pressure that is desireable is also affected by the strength of the jig component being toggled against. A thin base on a sled, for example, might be distorted by too much force.
- Ralph
Ralph Barker is offline
post #6 of 22 (permalink) Old 01-28-2011, 01:01 AM Thread Starter
matt1710's Avatar
First Name: Matthew
Default Thanks...and the pictures
Thanks for all the input. Ralph - when you say "the smaller clamps" are you referring to smaller toggle clamps in general, or the smaller of the two sizes that I've listed above?
Attached are the pictures of the two sleds that I intend to build. Based on the photos in these attachments, can anyone tell approximately what size clamps are being used, by the fact that the man's hands are almost completely covering the clamps?
Matthew
matt1710 is offline
post #7 of 22 (permalink) Old 01-28-2011, 01:53 AM
Country: Germany
First Name: Titus
Originally Posted by Gene Howe View Post
Matt,
I'm with Gene on this one, I use some very small el cheepo (99 euro cents) toggle clamps with sandpaper and have had no problems.
Thanks for posting the sketches up Matt, most useful.
Cum Catapultae Proscriptae Erunt Tum Soli Proscripti Catapultas Habebunt
Titus A Duxass is offline
post #8 of 22 (permalink) Old 01-28-2011, 01:57 AM Thread Starter
matt1710's Avatar
First Name: Matthew
Woah - that's cheap! The only ones I've found thus far are US$21 (75kg) and US$28 (150kg) per clamp. Brand is Brauer - I think they're German.
matt1710 is offline
post #9 of 22 (permalink) Old 01-28-2011, 02:37 AM
Country: Germany
First Name: Titus
I got them from the bay direct from China.
I tried to get them locally here in Germany but they wanted 40€.
post #10 of 22 (permalink) Old 01-28-2011, 07:32 AM
go to harbor freight. they have 200lb toggle clamps for $3.49 and 500lb clamps for $0.50 more
200 Lb. Horizontal Toggle Clamp
500 Lb. Horizontal Toggle Clamp
they also have the vertical clamps as well
Mike Gager is offline
Shop Made Toggle Clamps for Gav Stefang Jigs and Fixtures 40 02-04-2011 05:38 AM
C clamps w/ball handle JerryPat Tools and Woodworking 2 01-16-2011 07:29 PM
toggle clamps vjeko Jigs and Fixtures 6 03-28-2009 06:36 PM
Toggle Clamps (Update) Pop_pop1 Table-mounted Routing 1 08-29-2005 06:52 AM
T Track Toggle Clamps Pop_pop1 Table-mounted Routing 4 07-29-2005 02:22 AM
