Best material for templates - Router Forums
post #1 of 24 (permalink) Old 01-29-2011, 07:13 PM Thread Starter
Mark Mayo's Avatar
First Name: Mark
Default Best material for templates
What is your suggestions for material to make a template if a guide bushing is to be used? MDF?
Mark Mayo is offline
post #2 of 24 (permalink) Old 01-29-2011, 08:06 PM
First Name: Keith
I like to use MDF or tempered hardboard (both sides smooth). They are slick and allow for good adhesion of double stick tape and allow the router to move easily.
radar57 is offline
post #3 of 24 (permalink) Old 01-29-2011, 09:01 PM
Hi Mark - I'm with Keith on MDF or hardboard. For me it is usually MDF as it't difficult to get hardboard out here that is smooth both sides. If I'm making a template or jig that I expect to have awhile or if I'm buying I will try to go with Acrylic or polycarbonate for the durability.
John Schaben
jschaben is offline
post #4 of 24 (permalink) Old 01-30-2011, 08:08 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
3/8" or 1/2" MDF is what I use most of the time.
Name:	Copy of new-clock22.jpg
Harry
harrysin is offline
post #5 of 24 (permalink) Old 01-30-2011, 09:49 AM
Ralph Barker's Avatar
First Name: Ralph
Another vote for 3/8" or 1/2" MDF. Where possible, it's good to "standardize" on one thickness, so guide bushings can be trimmed accordingly.
- Ralph
Ralph Barker is offline
post #6 of 24 (permalink) Old 01-30-2011, 10:06 AM
Hi
I use 1/4" and 1/2" MDF, most of my guides are 1/4" long on the stems but I do have some longer one also and that's when I use the 1/2" thick stuff..or the 3/4" thick stuff.
I like to use the pin nailer or the small nails to hold the template down to the stock.I just don't trust the tape most of the time, it likes to move just that little bit and it can lift the wood up when removing it sometimes..
post #7 of 24 (permalink) Old 01-30-2011, 02:33 PM
BigJimAK's Avatar
I use MDF, based on price.
I once had the hairbrained idea of picking up a 4'x8' sheet of 3/4", 1/2" and 1/4" UHMW plastic to cut from when I wanted some.
Then I called the plastics wholesaler...
First I asked him about a sheet of 3/4".. he said something like $21... which I thought was pretty good until I realized he was talking per square foot. That sheet was about $650 and all three would have been over $1,000. Needless to say I'm a big fan of MDF.
If you've got a local supplier who will give you their scrap or have a jig you're going to use a lot it'd be a good idea but if you want to use it exclusively, open your wallet!
BigJimAK is offline
post #8 of 24 (permalink) Old 01-30-2011, 03:13 PM Thread Starter
Mark Mayo's Avatar
First Name: Mark
THANKS
I will use mdf from now on. I tried some Baltic birch I had left and with each pass it changed - no good. All worked out, but I do not want to see that again. I guess you have to make mistakes sometimes to know what NOT to do in the future. I have all of my fingers and I can see!
post #9 of 24 (permalink) Old 02-01-2011, 02:32 PM
I want to make an mdf template too and have a new question on putting a good edge on it. Is it possible to mount a small rotary sanding spindle to a variable speed router (mounted to a router table) and sand the template edge on the lowest rpm setting or is the router way too fast?
boxwood is offline
post #10 of 24 (permalink) Old 02-01-2011, 02:38 PM
Hi
Too fast
Router Table Top Material Yellow Hammer Jigs and Fixtures 100 08-26-2015 05:22 PM
template material mountain monkey Guide Bushings and Templates 37 01-05-2009 08:49 AM
Trouble initializing material.. or table? JCPowell CNC Routing 0 11-11-2008 08:30 AM
Table top material questions majn555 Table-mounted Routing 18 11-06-2008 09:49 AM
Table Top Material rh111 Table-mounted Routing 4 04-19-2005 03:35 AM
