concave jig - Router Forums
post #1 of 12 (permalink) Old 01-30-2011, 07:58 PM Thread Starter
First Name: Ryan
Default concave jig
I'm building hardwood skateboards and am trying to build a jig that will let me rout a concave deck and also a convex bottom. I figure the jigs will just have to have opposing arcs. Any thoughts or ideas would be great. thanks!
rrwc110 is offline
post #2 of 12 (permalink) Old 01-30-2011, 10:06 PM
G'day Ryan
Welcome to the forum
Sydney, Australia
jw2170 is offline
post #3 of 12 (permalink) Old 01-31-2011, 02:06 AM
gav
Country: Croatia
First Name: Gavin
Hi Ryan, first off as you probably know, the curve in a skateboard is usually made by bending it into shape.
If you're determined to rout them, you want a rail and sled type set up.
2 straight rail set parallel to each other and a sled that the router is mounted to that has a concave base and another convex base.
The router and sled travel on the rails.
Hopefully this picture will make it clear for you even though it's being used on a guitar.
gav is offline
post #4 of 12 (permalink) Old 01-31-2011, 06:31 AM
Hi Ryan, Welcome.
Look into bent lamination for your decks. I worked with a guy & this is how he made his boards. They came out very nice.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #5 of 12 (permalink) Old 01-31-2011, 07:55 AM Thread Starter
First Name: Ryan
I really appreciate the tips The picture is cool and helps a lot. About laminations, We're trying to go a different way than other longboard builders. We're using exotic hardwoods and making each board to order for customers. We can guarantee that no two boards will be the same.
rrwc110 is offline
post #6 of 12 (permalink) Old 01-31-2011, 07:57 AM Thread Starter
First Name: Ryan
Great picture, one of my friends recently asked me to build him a guitar, so perfect!
rrwc110 is offline
post #7 of 12 (permalink) Old 11-15-2011, 10:30 AM
First Name: Greg
Default Why is the profile created with this jig Convex?
Hello Gavin,
I see the arc base in the photo - but do not understand why it creates a convex profile on top of he neck. It seems that the top of the bit is the same distance from the top of the guitar neck so it would simply plane/flatten the top of the guitar neck as the router is moved along the rails.
Is the arc base actually being rotated back and forth on the rails to get the curve?
Greg
taxque is offline
post #8 of 12 (permalink) Old 11-15-2011, 11:13 AM
gav
Country: Croatia
First Name: Gavin
Yep, apparently that's how it works. For a guitar neck it's quite a shallow curve.
gav is offline
post #9 of 12 (permalink) Old 11-15-2011, 01:50 PM
Greg, the arc of the jig is what defines the cut. If you think this is way out there check out these jigs and the legs they make. Photo 3 shows using a round over bit on one of the legs. The Router Workshop videos are priceless with all the excellent information offered; I highly recommend them.
Name:	Odd shape routing 01.JPG
Name:	Odd shape routing 02.JPG
Name:	Odd shape routing 03.JPG
post #10 of 12 (permalink) Old 11-16-2011, 09:53 AM
First Name: Greg
Thanks Mike - those legs are out there. I will have to check the videos out. I used to watch the show regularly and picked up a lot of good tricks.
taxque is offline
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
