Radial Drill Press Jig - Router Forums
post #1 of 16 (permalink) Old 02-10-2011, 07:46 PM Thread Starter
Glen L's Avatar
First Name: Glen
Default Radial Drill Press Jig
Hello All:
Just thought I would share this with you.
I made the table top from 2 X 24"X12" 3/4" MDF panels that I glued together. The fence is measured at 24" X 3" X 1.5" that can slide up to 11" forward, I also add 3/4 utility tracks for clamps and stops and whatever else I want to add on at a later date.
The paper measuring tape's I got from Ikea, hey!! it's free and it came in handy for this jig If you have any questions or comments their always welcomed
Here's the pics.
Cheers
Glen
Glen L is offline
post #2 of 16 (permalink) Old 02-11-2011, 04:58 AM
First Name: Simon
Hi Glen,
that looks stunning. It also looks like other jigs I have seen so I'm guessing they work well. Have you thought about a replaceable insert to minimise tear out in the future?. As you use the jig obviously you will drill into the base and make holes. To minimise tear out you may even move the jig about on your existing table so there is no hole under the drill path. With a removable insert you just change it out when it becomes to full of holes.
I have re written this a couple of times and don't mean to be telling you suck eggs, and if I haven't explained myself very well please ask.
Cheers Si
chickenslippers is offline
post #3 of 16 (permalink) Old 02-11-2011, 09:06 AM
walowan's Avatar
First Name: Michael
I always end up with holes all over my drill press tabels so I just have a piece of 3/4 mdf attached to the metal table, no tracks or clamps.
walowan is offline
post #4 of 16 (permalink) Old 02-11-2011, 10:02 AM Thread Starter
Glen L's Avatar
First Name: Glen
Originally Posted by chickenslippers View Post
Hi Glen,
Cheers Si
Thanks for the complements on the jig.
I set this jig up mainly for drilling holes in stiles for installing cabinet hinges, requiring no through holes, but I'm in the process of making some round 2" 0 clearance inserts
from 3/4 MDF when I need them.
The advantage of having a radial drill press is the table and drill head can articulate in all directions to position to drill where you want it, in this case right on the tables center. here's some photos that illustrate that.
Cheers
Glen
Glen L is offline
post #5 of 16 (permalink) Old 02-11-2011, 01:14 PM
First Name: Simon
Hi Glen ,
that looks like a seriously nice piece of kit.
Cheers,Si
post #6 of 16 (permalink) Old 02-11-2011, 03:32 PM
allthunbs's Avatar
First Name: Ron
Originally Posted by Glen L View Post
The advantage of having a radial drill press is the table and drill head can articulate in all directions...
Hi Glenn:
The only thing I can add is to be able to move the head up and down, rather than the table. On my old drill press I put a hydraulic lift under the bench top drill press column. The table top is 2'x4' and the head moves up and down relative to the table. I now have the radial that you have but I haven't been able to restore the column lift. Planned for down the road but I'm not sure how far.
Allthunbs
allthunbs is offline
post #7 of 16 (permalink) Old 02-11-2011, 05:05 PM Thread Starter
Glen L's Avatar
First Name: Glen
Originally Posted by allthunbs View Post
Hi Glenn:
Yes it would be nice to lift the head with a push of a button, lifting the table at best is pain in the butt
Glen L is offline
post #8 of 16 (permalink) Old 02-19-2011, 04:57 PM
ethylplant's Avatar
Man, that is just what I needed to see.
Very nice work.
I have a very old PowrKraft radial drill press, and I am getting ready to tear it down, clean it up, and make a new table for it. Your ideas are just what I need.
Thanks,
ethylplant is offline
post #9 of 16 (permalink) Old 02-20-2011, 09:46 AM Thread Starter
Glen L's Avatar
First Name: Glen
Thumbs up
Hi Glen,
Cheers Si
Hi Si
This jig is mainly for drilling 35mm holes in stiles for Euro hinges and 5mm pin holes for shelving, requiring no through holes, most of the work I do is cabinetry and trim. For installing pulls and handles I use my template and cordless drill.
I have update the jig with a 3" removable plug to accommodate a sanding drum that I could have used many of times for sanding curves I cut with a jigsaw. here's some
pics
Cheers
Glen
Glen L is offline
post #10 of 16 (permalink) Old 02-20-2011, 09:51 AM Thread Starter
Glen L's Avatar
First Name: Glen
Thanks James
Are making you're own table or buying one?
Cheers
Glen
Glen L is offline
Radial drill press... Brian Oglow Tools and Woodworking 15 10-04-2011 08:01 AM
radial drill press experiences pls. allthunbs Tools and Woodworking 6 07-03-2010 06:08 AM
opinions on radial arm drill press please. jer760 Tools and Woodworking 7 03-11-2008 03:50 PM
