Sliding Mortise Jig - Router Forums
post #1 of 7 (permalink) Old 02-22-2011, 09:06 PM Thread Starter
Glen L's Avatar
First Name: Glen
Default Sliding Mortise Jig
I just completed the mortising jig for my Incra table, for those who have an Incra table with the highrise cap and looking for a salutation to a mortising jig then this will work great for you.
As owners of the Incra jig we can take advantage of the system being mechanical and knowing how easy it is to return to the same setting for repeatable cuts and setups without pulling out the measuring tape to reset the jig for the same cuts you did last week. The fact that the Incra system is well known for its capabilities of making tons of box joints with it's template driven system, it can be applied the same way for mortise cuts just by recording the setup using the slide in templates that come in the kit.
Setting up for the first mortise cut is simple just by centering the router bit were you want it and slide the auto centering scale to O on the cursur in the LS Positioners base and you're ready to make the first cut, if need be, it can be fine tuned by the micro adjuster to get the cut right were you want it. The carriage on the LS Positioner has five slots for measuring scales that can be added for other mortising setups down the road.
Both the fence and highrise cap on the Incra will accept 1/4 20 rectangular nuts allowing the panel to slide along the fence and cap, so that's half the battle won when you plan to make the jig.
My jig is made from 15" X 7" 3/4 X 5/8 melamine I had in my scrap pile.
I added 2, 5 1/2" utility tracks and 2, Pro-Grip clamps to secure the work piece and prevent lifting while the bit is being plunged. I also added a top cap and push-pull handle to guide the jig along the fence and highrise cap
I'm happy to report that this setup works perfect, now if MLCS will start stocking the motorized router lift again I can mount the PC890 under the table and lift it with the foot pedal so I can ditch the manual crank system on the Triton TRC-001. Here's the pictures.
Cheers
Glen
Glen L is offline
post #2 of 7 (permalink) Old 02-22-2011, 11:33 PM
BigJimAK's Avatar
Very impressive, Glen... and nicely executed! Good use of the highrise, too.
BigJimAK is offline
post #3 of 7 (permalink) Old 02-23-2011, 12:34 AM Thread Starter
Glen L's Avatar
First Name: Glen
Thanks Jim
I figured that highrise would come in handy one day, again thanks for the comments.
Cheers
Glen
Glen L is offline
post #4 of 7 (permalink) Old 02-23-2011, 06:08 AM
Cassandra's Avatar
First Name: Cassandra
Hi Glen:
Excellent work! Thanks for the ideas!
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #5 of 7 (permalink) Old 02-23-2011, 07:00 AM Thread Starter
Glen L's Avatar
First Name: Glen
Originally Posted by Cassandra View Post
Hi Glen:
Cassandra
You're welcome Cassandra
The LS super system has more hidden gems I'm sure Cassandra have you tried using the wonder fence and the LS as a jointer?
Cheers
Glen
Glen L is offline
post #6 of 7 (permalink) Old 02-23-2011, 06:37 PM
Cassandra's Avatar
Cheers
Glen
Yes, I did, Glen. It's a treat to set-up and use. Once the fences are offset to each other, one can then use the micro-adjuster to get the outfeed fence properly aligned with the bit.
Cassandra
post #7 of 7 (permalink) Old 02-23-2011, 10:11 PM
CanuckGal's Avatar
First Name: Deb
That's a very impressive jig. Well done!
I measured, I marked, I cut.
CanuckGal is offline
mortise & tenon jig yairfe Jigs and Fixtures 23 10-21-2009 05:49 PM
jig it mortise jig ernest plutko Jigs and Fixtures 16 08-21-2009 07:14 PM
