How to make a jig to route a grove - Router Forums
post #1 of 13 (permalink) Old 02-25-2011, 04:58 PM Thread Starter
keenecowboy's Avatar
First Name: Martin
Smile How to make a jig to route a grove
I would like to make a jig to route a grove in a maple cutting board. I will need to repeat this on several boards.
The overall size is 16 x 20 end grain maple 1 1/4 inches thick.
I would like the grove to be approx. 3/4 inches from the edge a little more if needed.
I have a DWalt 625 plunge router.
email me if you folks need more information.[email protected]
keenecowboy is offline
post #2 of 13 (permalink) Old 02-25-2011, 06:15 PM
Hi
Just pop on your edge guide on your router and go for it..
post #3 of 13 (permalink) Old 02-25-2011, 09:22 PM
That's one method. Another is to build a frame that fits around your cutting board. It has to be wide enough so that when the cutting board is centered in the frame, your router bit will cut the groove at the right distance from the edge of the board. To keep the cutting board centered you will cut spacer blocks to fit between the cutting board and the frame. This is a good method for grooving many cutting boards.
post #4 of 13 (permalink) Old 02-27-2011, 10:29 AM Thread Starter
First Name: Martin
Default Frame jig for cutting groves
I built the frame and am attaching photos of my efforts.
Here are some problems I encountered.
1. made the initial frame from 2 x4's
2. it racked, with a bow will not lay flat.
3. using a Dewalt 625 as you can see.
4. i trying re-screwing the end pieces but still have the bow.
Any suggestions would be appreciated.
post #5 of 13 (permalink) Old 02-27-2011, 12:25 PM
wcpalmer's Avatar
Send a message via Yahoo to wcpalmer
Martin,
I suspect one of the 2x4's has a twist in it. When I make jigs I either use MDF or Baltic Birch plywood. If thicker material is needed for the jig, laminate one or more pieces of MDF or plywood.
I noticed pocket screws used to join the corners pf the frame. These screws are driven at an angle and the material is pulled up at an angle, the direction of force is not at 180 degrees. When using pocket screws to joint a frame. clamp the two piesces to a flat surface before installing the screws.
Bill
wcpalmer is offline
post #6 of 13 (permalink) Old 02-27-2011, 12:30 PM Thread Starter
First Name: Martin
Thanks, I am going to redo the frame as you suggested, and clamp for the pockets.
I need 1 1/4 height so i will laminate two pieces together. Thanks again for the tips.
Martin
post #7 of 13 (permalink) Old 02-27-2011, 04:53 PM Thread Starter
First Name: Martin
I will need to laminate to build up the thickness what glue would you sugest for the mdf board
post #8 of 13 (permalink) Old 02-27-2011, 08:09 PM
wcpalmer's Avatar
Tight bond II will do just fine.
Bill
wcpalmer is offline
post #9 of 13 (permalink) Old 02-27-2011, 08:09 PM
RouterForums.com User
harrysin's Avatar
First Name: Harry
A far better and simpler way to make templates is as shown, using 1/2" MDF. Leave the surround wide enough for the router to be stable and/or make a router support, the one shown is made from a side fence, there is no need for it to be that fancy as shown in the last shot of a hastily made one when the fancy one was too tall for the particular job.
Harry
harrysin is offline
post #10 of 13 (permalink) Old 02-28-2011, 05:57 AM
allthunbs's Avatar
First Name: Ron
Hi Martin:
The above suggestions are all valid and well worth pursuing. I'm going to add another.
I have skis in several lengths. One option to your problem involves a long set of smooth-rod skis. Lock your skis onto your table. To do the cut, slide your router across the skis. Set stop blocks on the rails for your starting and end points and put blocks under the rails to control deflection while starting your cut. Repeat for each groove. You can do bread board edges the same way. Another alternative is to use a shii and a male template.
Allthunbs
allthunbs is offline
Incra Jig Process Imporovement tprofera Jigs and Fixtures 21 09-18-2012 08:45 PM
Sliding Mortise Jig Glen L Jigs and Fixtures 6 02-23-2011 10:11 PM
Simple mortising jig rwyoung Jigs and Fixtures 2 12-17-2008 09:44 PM
My Dovetail Jig Arrived.... challagan Jigs and Fixtures 21 01-08-2007 05:52 PM
Jig to make spoons Norm Johnson Jigs and Fixtures 1 10-20-2004 11:02 AM
