Incra Right Angle Jig on Kreg Fence - Router Forums
post #1 of 10 (permalink) Old 03-02-2011, 04:16 PM Thread Starter
Default Incra Right Angle Jig on Kreg Fence
Does anyone know if you can use the Incra Right Angle Jig on a Kreg router fence, or any other non-Incra fence, for that matter?
chalfke1 is offline
post #2 of 10 (permalink) Old 03-02-2011, 08:04 PM
Right angle jig on Incra ultra lite fence
Right angle jig next to a Kreg PRS1010
I suppose the Incra right angle could be "made" to work by jigging up to the Kreg fence but direct attachment is apparently a no go.
TomE is offline
post #3 of 10 (permalink) Old 03-02-2011, 10:47 PM Thread Starter
Thanks TomE. Anyone aware of a right angle sled/fixture that works well with the Kreg fence?
chalfke1 is offline
post #4 of 10 (permalink) Old 03-03-2011, 03:40 PM
Glen L's Avatar
First Name: Glen
Attachment 41849
Attachment 41850
It might work if you make a taller set of guide blocks.
Glen L is offline
post #5 of 10 (permalink) Old 03-03-2011, 07:25 PM
Yep, but the key to the jig is that the "hook" goes over the Incra fence and uses the nylon screws to set sideplay tolerance, it actually uses the fence as a guide similar in function to a miter gauge and slot.
The T-track atop the Kreg fence is not in position to accept the hook even if the wood rails were modified to raise the jig to height.
There are probably many ways to get it to work but the OP might be hesitant to cobble it up and we're not sure how he intends to use it. If he needs a simple sled type jig then there are plenty of options that do not attach to the fence.
One might get the jig to work using Incra parts (bolting an Incra pro 2 fence to the Kreg for instance) but not sure why one would when an Incra ultra lite setup would run about $50 more, includes the positioner and can be clamped to the table.
TomE is offline
post #6 of 10 (permalink) Old 03-03-2011, 07:36 PM
Hi
Just use a sub fence (3/4" MDF) in front of the other one with stand off blocks..on the back side of the sub fence.
post #7 of 10 (permalink) Old 03-03-2011, 08:54 PM
Glen L's Avatar
First Name: Glen
Ok I see what you mean, I'm going to have look at my right angle fixture again..hmmm
Glen
Glen L is offline
post #8 of 10 (permalink) Old 03-03-2011, 09:22 PM
Glen L's Avatar
First Name: Glen
Ok hang on, this might work... I'm going to post some pics in a second
Glen L is offline
post #9 of 10 (permalink) Old 03-03-2011, 09:43 PM
Glen L's Avatar
First Name: Glen
Try sliding the face plate to line up with the guide (see photos), screw in a 10-32 machine screw with a 10-32 rectangular nut so it can slide into the utility track on the Kreg fence, if that works add another 2 screws and nuts and adjust them up for a nice smooth glide. If the fixture is to low or to hieght make a new set of runners or add shims maybe.
Cheers
Glen
Glen L is offline
post #10 of 10 (permalink) Old 03-07-2011, 12:40 PM Thread Starter
Thanks Glen! That looks like a winner.
chalfke1 is offline
Incra Jig Process Imporovement tprofera Jigs and Fixtures 21 09-18-2012 08:45 PM
Incra Jig and Fence System Combo mpbc48 Table-mounted Routing 6 02-23-2011 06:10 AM
Incra Wonder Fence / Right Angle Jig Help bribassguy Jigs and Fixtures 5 01-21-2010 09:08 AM
incra jig right angle bruce thom Jigs and Fixtures 20 06-29-2009 02:01 PM
