Porter Cable 4212 dovetail jig - Router Forums
post #1 of 8 (permalink) Old 03-03-2011, 08:36 PM Thread Starter
jguild45's Avatar
First Name: Jay
Default Porter Cable 4212 dovetail jig
Can anyone tell me how I determine how deep to cut when using 1/2" stock to make half blind joints? My first attempt with 3/4" stock to make a half blind joint worked great! The only problem is I plan on using 1/2" for all four pieces of the drawer.
jguild45 is offline
post #2 of 8 (permalink) Old 03-04-2011, 12:37 AM
Hi Jay.
The setting for all half-blind joints are the same from 1/2" to 1-1/8". The joint is referenced from the inside so same setting works for different thicknesses. If you are happy with the fit on 3/4" stock then use same setting for your 1/2". Thinner than 1/2" I would use the mini template.
Basically it is 5/8" from router base plate (1/4" for template & 3/8" for joint = 5/8"). This will get you in ballpark then adjust for liking.
Your drawer sizing for the pc jig is 1" + 1/4". That means your drawer heights will be for example 3-1/4", 4-1/4", 5-1/4", 6-1/4" etc for centered joints.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 8 (permalink) Old 03-04-2011, 09:49 AM
Hi
I would suggest you set it to 3/8" deep. that's the neat thing about dovetail bits they will work on thin stock as well...it's the angle on the bit that sets up the lock.
Below you will one setup to cut 1/4" deep on 3/4" thick stock with a 1/2" dovetail bit.
post #4 of 8 (permalink) Old 03-04-2011, 10:44 AM
First Name: Kelly
BJ is that a UHMW table top?
KR
Kelly Rittgers is offline
post #5 of 8 (permalink) Old 03-04-2011, 11:18 AM
Hi KR
Just some 1/4" thick white plastic..
KR
post #6 of 8 (permalink) Old 03-04-2011, 06:45 PM
G'day Jay
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #7 of 8 (permalink) Old 03-04-2011, 08:35 PM
Hi
Hi Bob,
The O/P said he was using the PC jig. It is 3/8" for the joint. For this jig with the supplied bit you need to set the bit at 5/8" from the base plate of the router. This will accommodate 1/4" for the template thickness & 3/8" for the joint so he will have 5/8" of bit showing on his router setup.
Whittier, CA.
jlord is offline
post #8 of 8 (permalink) Old 03-04-2011, 09:02 PM
Hi James
Right on but I always use the brass setup bars on the bottom or the top of the template/plate to set the dovetail bit, in that way no guess work needed..
Porter Cable 4212 dovetail jig dwwilson44 Jigs and Fixtures 2 01-28-2013 10:43 AM
Porter Cable 4200 series Dovetail jig ertoolsie Jigs and Fixtures 1 10-06-2010 04:53 PM
Help with a minature dovetail jig (Porter Cable) nrs250 Jigs and Fixtures 4 08-28-2010 03:37 PM
Porter Cable Dovetail Jig 4212 alanwood Jigs and Fixtures 2 10-16-2009 08:53 PM
