Any suggestion for a Dovetail Jig? - Router Forums
post #1 of 16 (permalink) Old 03-09-2011, 03:24 PM Thread Starter
First Name: will
Default Any suggestion for a Dovetail Jig?
I don't do many dovetail, maybe several times a year for small furniture. I used to use hand saw and chisel to make it. It is kind of painful.
I just bought a Craftsman router last weekend. I searched online and found too many dovetail jigs, templates. A lot of them are over $100. I don't need that kind of professional one for my work. Any suggestion for my case? Is a template enough for me?
Thanks.
volunteers is offline
post #2 of 16 (permalink) Old 03-09-2011, 04:14 PM
40.oo dollars dovetail jig, by the way this jig will do both types of dovetails..
The General Tools & Instruments Newsroom | The EZ Pro Dovetail Jig Instructional Videos
Thanks.
post #3 of 16 (permalink) Old 03-10-2011, 12:49 PM
First Name: Bob
I'm kinda partial to the ChestMate myself.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
bobfowler is offline
post #4 of 16 (permalink) Old 03-10-2011, 05:35 PM
Ralph Barker's Avatar
First Name: Ralph
I think the first question you need to ask yourself is whether you want to do only half-blind DTs or also through DTs. Then, do you want them all with fixed spacing, or do you want adjustable spacing. Fixed spacing imposes limitations on the width of the stock, so as to conform to the geometry of the jig. Adjustable spacing removes that limitation, but introduces much greater complexity of set-up.
Then, there's the whole issue of fiddle factor. The better jigs are designed to minimize that as much as possible, while still providing flexibility. It's a time-spent versus money-spent sort of issue, I think.
That said, I'm a fan of the Porter Cable 4212, which has templates for both 1/4" and 1/2" DTs in thin and thick stock, correspondingly, and does half-blind and through DTs, as well as box joints.
- Ralph
Ralph Barker is offline
post #5 of 16 (permalink) Old 03-10-2011, 08:37 PM
Hi Will,
For a jig I use the PC. Once you remember some simple rules to go by it is a simple & quick jig to use.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #6 of 16 (permalink) Old 03-10-2011, 08:49 PM
Hi Will
I use the Katie jig, no rules just pop the bit in the router table or you can use your hand router as well ,and make the all parts for drawers/boxes in about 2 mins.or less..
New Katie Jig w/Bars-Sommerfeld's Tools For Wood
Organic Half-Blind Dovetail Katie Jig Plate-Sommerfeld's Tools For Wood
Box Joint Tuning Forks-Sommerfeld's Tools For Wood
Katie Jig Forks-Sommerfeld's Tools For Wood
Just a note ...You can make your own very easy and cheap. so to say you don't need to put out 240.oo bucks for one.
" Dovetail jigs are like soft drinks-there are so many choices that selecting one for your shop can be tough.
To make this process simpler for you, here are eight great reasons why the Katie Jig is your best bet:
1. No complicated assembly-Just take it out of the box and use it immediately. No alignment.
2. No lengthy manual to read-Just a few pages of clear, easy-to-follow directions show you how to use the jig to achieve professional results.
3. Only one set-up necessary to cut pins & tails-All other dovetail jigs need two set-ups to complete both parts of a joint.
4. Hand-held or router table operations-Works equally well using either method of operation.
5. The perfect glue gap of .006"-010"-between pins & tails is produced by matched bits & guides.
6. Hassel-free variable spacing-Just choose your guide/tuning for positions and go to work.
Even use different thickness boards with no ill effects.
7. Handles stock up to 12" wide-more than wide enouh for all but the latest projects.
Quality constructions ensures unwavering precision and long-term durability.
While many dovetail/box joint jigs are made of steel rods or bars (poor choices for precison), the Katie Jig uses rigid, engineered extrusions that are manufactured to + .002 tolerances, from high quality aluminum...then gold anodized for lasting dependability.
These super-rigid extrusions and close tolerances make the Katie Jig virtually vibration-proof and enable it to maintain the .006"-.010" pin/tail glue gap clearances that result in perfect, tight-fitting joints...Every time!
Set Includes: Pre-assembled Jig w/ *(9) 5/8" dovetail guide/tuning forks * (2) edge stops * 7/16" Dovetail Router Bit * 5/8" Pattern Bit * 5/32" Allen Wrench * Written Instructions. "
post #7 of 16 (permalink) Old 03-10-2011, 10:58 PM
First Name: Kelly
what do you do when you need new backer boards on Katie. Make your own?
Kelly Rittgers is offline
post #8 of 16 (permalink) Old 03-11-2011, 02:59 AM
Hi Will
If you want a symmetrical joint the rule you need to follow is for drawer sizing so you end up with the traditional half-pins top & bottom. This pretty much applies to all jigs that use a fixed template to follow. The next step up would be the variable spacing jigs but they will require a little more setup. You cannot get the thin pins or tails with jigs as you can with a hand cut joint because you can only go as thin as the shank of the bit. So it all comes down to how much time you are willing to invest in your joints to get the look that you want.
"The Porter-Cable 4200 series dovetail jig will help you cut these joints efficiently. An accessory kit will enable you to
cut miniature versions of these joints for small gift boxes or cubbyhole drawers on a roll-top desk. The 4200 series
also has the capability to cut more advanced joints (dovetails that skip pins, wood hinges, end-to-end joints, various
types of angle joints, and joints with inlays)."
Whittier, CA.
jlord is offline
post #9 of 16 (permalink) Old 03-11-2011, 05:46 AM
I think you should go for the Porter Cable 4200 series. You can start with the 4210 for not much over $100 and then buy additional templates when you need them.
Dovetailer59 is offline
post #10 of 16 (permalink) Old 03-11-2011, 10:17 AM
Hi KR
Yes, very easy to replace one but it will be a long time for that job..
Just a note you are not locked into one pattern the Katie jig comes with spacers or you can make your own to setup any pattern like on long dovetail if you want to..or one or two dovetails and than put in a box joint in the same board like say in the corners of the box or drawer.
The neat thing about the Katie jig ,if you need the box to slide in a hole all the parts are cut to the right size, no math needed , just cut the parts and it will fit in the hole every time...if you want to used guides for the drawers just cut the stock 1" shorter for the guides to sit in the hole also.
Peachtree 15 inch dovetail jig Noob Jigs and Fixtures 13 12-03-2013 07:37 PM
New Lower Priced Leigh Dovetail Jig scrollwolf Jigs and Fixtures 1 07-08-2007 05:10 PM
