router jig combs - Router Forums
post #1 of 3 (permalink) Old 03-10-2011, 01:30 PM Thread Starter
First Name: Joe
Default router jig combs
I have a Central Machinery dovetail jig, which came with a 1/2" spacing and 1" between fingers.
The dovetail router is 10 degree, the height of the router cutting edge is 1/2".
Using a 7/16" collar in the router, I had to lower the cutter into the 3/4" material 9/16" and still did not got a tight fit, and the cutting edge of the bit is below the surface leaving a rim.
I read that the standard spacing between the comb fingers are 7/8" , but I can not find any replacement comb template.
Do I have to make one? What are the proper dimensions?
Please help, Joe
joesolymar is offline
post #2 of 3 (permalink) Old 03-11-2011, 02:41 PM
First Name: Richard
Joe, I think the ones from MCLS will fit it. Try this link Pins and Tails, Half-Blind, Box Joint Dovetail Jigs
If not I am sure Bob will pop in and let you know where to to get them as he has the same unit.
Ok I found the other site it is woodstock tools. Here is link to the parts you need.
http://www.woodstockint.com/search.aspx?q=dovetail+jig
Racer2007 is offline
post #3 of 3 (permalink) Old 03-13-2011, 12:14 AM Thread Starter
First Name: Joe
Default Solving 1" dovetail sloppyness
Please help, Joe
I solved the problem of loose pins and tails in halfblind dovetails, in 1" comb plate, by modifying a router collar, I turned the .500 collar down to .47 dia. And following the side of the comb.
Need Jig for Dovetailing ĹĒ stock + Rockler woes + Katie? JavaGeek Jigs and Fixtures 16 02-17-2011 01:46 PM
Router Biscuit Bit Usage Question (jig)??? Nickbee Router Bits - Types and Usage 15 11-22-2007 10:55 PM
