custom made dovetail jig? - Router Forums
post #1 of 19 (permalink) Old 03-21-2011, 03:58 PM Thread Starter
Jack Wilson's Avatar
First Name: Jack
Default custom made dovetail jig?
Ok friends, please help if you can on this. I have some pine I will be making into a chest, about 28" high, (give or take, so the jig needs to be that wide), and I would like to make a jig of masonite or aluminum to set the joints at my chosen spacing. I have never used ANY type of dovetail jig before, I have never made any dovetail joints, period. This is all uncharted water for me and I don't want to spend a lot on a really wide jig. Is what I want to do feasible? I plan on using 5/4 pine, so what about offset, how should I handle this so I can route both sides at once? I plan on through dovetails. Can you offer advice or experience?
Thanks guys, and gals
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #2 of 19 (permalink) Old 03-21-2011, 04:43 PM
kp91's Avatar
First Name: Doug
Popular woodworking had an article on the $19 dovetail jig, it may be available online
Ok, so I found it for ya, http://www.popularwoodworking.com/te...9_dovetail_jig
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 19 (permalink) Old 03-21-2011, 06:16 PM Thread Starter
First Name: Jack
Thanks Doug, I am still going over it trying to glean how this can be used on a wide panel.
Jack
post #4 of 19 (permalink) Old 03-21-2011, 08:14 PM
Hi Jack
You may want to look at the BIG dovetails , you can get the template at the right price and anyone can put the big ones it place and not need a hammer to get them to fit at glue up time...just do the 1st. 16" of the board and than slide the board down and do the rest of them, with the hand router..
Pins & Tails Through Dovetail Templates
Large Through Templates
Pins and Tails, Half-Blind, Box Joint Dovetail Jigs
post #5 of 19 (permalink) Old 03-21-2011, 10:19 PM Thread Starter
First Name: Jack
Hi Jack
Yes Bob, I absolutely want the bigger joints. I wondered if there was a way to machine my own, actually have a buddy do it, that would accomodate this size, but I guess I could just copy this one onto a larger pc. of aluminum to accomplish that. I think I have seen jigs that put both pcs of wood on the same side but they are offset some, and then you just route them once and it's all done, thats what I would really like to be able to do.
Jack
post #6 of 19 (permalink) Old 03-21-2011, 10:30 PM
Hi Jack
That would be great but it's takes a male and a female to make a dovetail joint the norm a box joint will work the way you want..
post #7 of 19 (permalink) Old 03-22-2011, 06:09 AM
gav
Country: Croatia
First Name: Gavin
Jack, i think the most useful thing for you to look at would be this.
Stots Dovetail Template Master- "You can make your own jigs." - Page 1
gav is offline
post #8 of 19 (permalink) Old 03-22-2011, 10:25 AM
Ralph Barker's Avatar
First Name: Ralph
Since you haven't done dovetails before, Jack, you might want to spend some time studying the geometry of the joint first, and then how that geometry is applied to the manufacturing of a jig. The additional wrinkle is that you said you want to determine the spacing yourself, which is a more complex task. Plus, the 28" size is wider than the 24" width of commercially-made jigs.
As you might guess, precision is the name of the game with dovetails. Not only do the male and female parts of the joint (pins and tails respectively) need to fit on one corner, the precision has to be such that the fit will follow around all four corners of the box. Any errors (lack of precision) will be additive as you move from corner to corner. So, a seemingly small error will become a big one during assembly.
For through dovetails, the tails are cut with the angled dovetail bit following a template with straight fingers, and the pins are cut with a straight bit following the template with angled fingers. The angle on the template must, of course, be the same as the angle on the dovetail bit being used.
If you look at the templates for the jigs designed to do through dovetails, you'll see that the templates typically have straight fingers on one side, and angled fingers on the other, all precisely aligned, so the two parts of the joint are cut by turning the template around. The versions of the machines that allow custom spacing (e.g. the Leigh DR4 Pro and the PC OmniJig) have movable individual fingers that are locked into a template base.
The instructions for the PC 4200-series (fixed-spacing) jigs include methods for attaching the template to a separate wooden bar that can then be clamped to the stock for making wider joints. Essentially, you clamp it in one place, cut those tails or pins, then reposition it on the stock, and cut the next set. Precisely repeatable alignment becomes the issue.
There are also "chest" jigs available for making wide panels with dovetail joinery. These, again, typically involve multiple repositioning of the jig along the end of each panel, introducing potential alignment errors with each repositioning.
If you have machine-shop capabilities, you could certainly duplicate the templates from one of the commercially-made fixed-spacing jigs to be long enough to avoid the repositioning problem. If so, use aluminum, not Masonite. The Masonite would wear too quickly to be practical. But, that doesn't accomplish your custom spacing.
The other alternative, of course, would be to lay out the spacing as you want, and then hand cut the tails and pins, as has been done for years. You'd likely need to do a fair amount of practice before tackling the chest, however.
- Ralph
Ralph Barker is offline
post #9 of 19 (permalink) Old 03-22-2011, 10:56 AM
First Name: Randal
Jack,
Part of your description (both parts on one side, able to do larger panels), reminded me of a post from a couple of days ago. It mentioned the General tools jig with a link to the videos. Could this be one of the ones your thinking of?
LinuxRandal is offline
post #10 of 19 (permalink) Old 03-22-2011, 12:20 PM
Hi Jack
If you can swing it buy the over price PC 24" dovetail jig (550.oo ) for the one time job but it's hard to beat a template made by a CNC machine..but it's your money so I would say go for it.. it's only money and you can't take it with you they say..
Amazon.com: Porter-Cable 77240 24-Inch Omnijig Joinery System: Home Improvement
Router set and dovetail jig advise el gaucho General Routing 4 02-11-2011 03:21 PM
New Dovetail Jig for $30 - is it worth it? Gweedz Jigs and Fixtures 6 09-19-2010 08:57 AM
Dovetail Jig - Dakota Ebony Guide Bushings and Templates 2 07-07-2010 07:42 AM
Bit Speed for Dovetail Jig darenrogers Jigs and Fixtures 8 05-14-2010 10:23 AM
Making your own dovetail jig templates Dominick Giarraputo Jigs and Fixtures 2 09-03-2005 06:17 AM
