Clamp Guides - Router Forums
post #1 of 8 (permalink) Old 03-28-2011, 07:13 AM Thread Starter
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Default Clamp Guides
I've various lengths of these, which I find very useful. I'm beginning to see wider uses for them, linking them together. Some lock jigs use the same basic system but with just very short lengths.
I'm trying to find a source of the joining plates. I've seen them in China, but I don't want a 20ft box full. I've sourced suitable screws and the T-Nuts aren't a problem, but finding suitable material of the right thickness, etc., to make some of the plates up is proving difficult.
I've an idea that one of the US woodworking suppliers offers them as a separate item but I can't find who. Does anyone happen to know? They are just the 'U' shaped plates.
Cheers
Peter
Name:	Progrip Clamp Guides marked.jpg
istracpsboss is offline
post #2 of 8 (permalink) Old 03-28-2011, 07:30 AM
First Name: Danny
That kind of looks like some kind of re-enforcement or support bracket. Could an L bracket be strong enough to do the job?
Doesn't look like it would be that hard to make.
jd99 is offline
post #3 of 8 (permalink) Old 03-28-2011, 07:31 AM
Gene Howe's Avatar
First Name: Gene
It looks like Peachtree has what you need.
Straight Edge Clamps - Peachtree Woodworking Supply
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 8 (permalink) Old 03-28-2011, 08:05 AM
gav
Country: Croatia
First Name: Gavin
Cheers
Peter
Trend seems to have something a lot like what you're after.
http://www.trend-uk.com/en/US/produc...ting_kit_.html
gav is offline
post #5 of 8 (permalink) Old 03-28-2011, 10:48 AM Thread Starter
Country: Croatia
First Name: Peter
Thanks Gene. That's a pretty comprehensive range of accessories although, while they sell the T-Nuts, they don't seem to offer the plates separately.
Cheers
Peter
post #6 of 8 (permalink) Old 03-28-2011, 10:54 AM Thread Starter
Country: Croatia
First Name: Peter
Hi Danny
That was my first thought and I picked up some 'L' shaped plates to try. The problem was that the arms were a bit too wide, and being pre drilled, if I took off some material, the size of the holes brought them close to the edges and seriously weakened them. The material was also a little thin. If my metal working shop was up and running, I'd certainly make them.
Cheers
Peter
post #7 of 8 (permalink) Old 03-28-2011, 10:59 AM Thread Starter
Country: Croatia
First Name: Peter
Hi Gav
Yeah, those are the beasties ! The price, though, for a handful of stampings, made me blanche ! Those are exactly what I was after.
Cheers
Peter
post #8 of 8 (permalink) Old 04-04-2011, 09:35 AM Thread Starter
Country: Croatia
First Name: Peter
Well, I picked up a suitable piece of mild steel locally that should be sufficient for four plates for Kns20 (around 3 Bucks 80).
All I need to do now is drill and hacksaw them out. :-) I've plenty of T-nuts from other accessories like stops and I've already got suitable Csk head screws.
Cheers
Peter
Bosch 1615 & template guides? TomHudson Guide Bushings and Templates 19 10-21-2016 01:23 AM
Producing projects with the aid of the guides Doak Guide Bushings and Templates 21 08-29-2009 10:15 AM
template guides for Bosch Colt RuggerJoe Guide Bushings and Templates 13 02-10-2009 08:41 AM
40mm Guides for Templates + more bobj3 Jigs and Fixtures 30 07-22-2007 11:09 PM
