Sliding Dovetail Joint - Router Forums
post #1 of 11 (permalink) Old 04-02-2011, 08:50 AM Thread Starter
First Name: Doug
Smile Sliding Dovetail Joint
Hello Forum Members,
I am looking for the optimum depth of cut for a 3/4" 14 degree dovetail router bit to balance the thinning of the tenon as the depth gets deeper with the surface area of the angled tenon as it bonds with the mortise.
Also, my board (tenon) will be tool long to use my router table for machining the tenon (board hits ceiling). I have seen jigs that can be purchased for router, but would prefer to not spend the money. Has anyone ever mounted their router horizontally on the end of the router table on a pivot such that the distance between the router bit and table can be carefully controlled?
doug.vandervoort is offline
post #2 of 11 (permalink) Old 04-02-2011, 03:13 PM
Have you got access to an upper level deck, hang the board over the deck railing and support with clamps to the railings.
CaptRandy is offline
post #3 of 11 (permalink) Old 04-02-2011, 08:08 PM Thread Starter
First Name: Doug
Hello Captain Randy,
My router table is the extention of my 3 HP table saw, so it's not too portable. What I may end up doing is making a simple new router table that is portable.
Thanks for your comments.
post #4 of 11 (permalink) Old 04-02-2011, 09:34 PM
Hi Doug - I think you are asking about a horizontal router table. There are some plans and pics around, I just can't think where right off hand. Try searching the site for "horizontal router table', should hit something.
John Schaben
jschaben is offline
post #5 of 11 (permalink) Old 04-04-2011, 08:57 AM
I was hoping you had a portable table but your rig might be a tad too heavy to move around.
post #6 of 11 (permalink) Old 04-04-2011, 09:16 AM
Hi Doug
What ????? ,,what are you wanting to do. ???
post #7 of 11 (permalink) Old 04-04-2011, 11:24 AM
The Warthog's Avatar
First Name: Roger
Why not go with a straight mortise and tenon instead? Then you could rout the end of the board freehand or on a shop-made jig.
If I understand the question, that is.
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
post #8 of 11 (permalink) Old 04-12-2011, 08:06 PM
First Name: randy
I did something similar recently, I just rolled my router table outside.
rbpilot is offline
post #9 of 11 (permalink) Old 04-13-2011, 06:12 PM
First Name: Robin
ummm, was that in english? i have to look up like every other word!!!
RobinLocksley is offline
post #10 of 11 (permalink) Old 04-18-2011, 08:20 AM Thread Starter
First Name: Doug
I am going to make a sliding dovetail joint to connect my table legs to the aprons.
For Sale: Sears/Craftsman 2579 router dovetail joint template kit. $25, Craigslist Anchorage BigJimAK Woodworking Classifieds 0 01-09-2010 06:40 PM
The first through dovetail joint by AKEDA Benny LaBaw Jigs and Fixtures 9 12-14-2009 08:01 AM
Sliding DoveTail Jig bobj3 Jigs and Fixtures 5 01-06-2007 08:31 PM
