Side clamping for router ski operations - Router Forums
post #1 of 15 (permalink) Old 04-12-2011, 05:44 AM Thread Starter
bobbotron's Avatar
First Name: Rob
Default Side clamping for router ski operations
Hi all,
I'm not sure how to clamp objects that I want to "flatten" with router skis - I know I have to clamp it from the sides, but I'm not sure how to do so securely. I would hate to have it become unclamped during routing. For instance, I would like to flatten this disc by passing my router over it...
Wacky maple by bobbotron1, on Flickr
bobbotron is offline
post #2 of 15 (permalink) Old 04-12-2011, 10:03 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Rob
I use a board with a matrix of tapped holes all over it. The tapped holes all use T-nuts to provide the threading. I've then got eccentric clamps that can be fitted on to the threaded holes that are most suitable, once the work piece has been laid upon it. The outer limits of the board provide the guidance for the skis.
Does this make sense?
Cheers
Peter
istracpsboss is offline
post #3 of 15 (permalink) Old 04-12-2011, 10:04 AM
Ralph Barker's Avatar
First Name: Ralph
One approach would be the work-holding jigs that many here use - essentially a support surface with a matrix of holes, into which a series of wooden cams can be inserted and turned to make contact with the work piece, and then screwed tight to the support surface. The matrix approach is often more secure than the typical three-point system used with bench dogs.
To keep the router's vertical position consistent, the router can be mounted on skis (lots of discussion about skis here), or mounted on an over-sized base that rides on a frame of some sort.
- Ralph
Ralph Barker is offline
post #4 of 15 (permalink) Old 04-12-2011, 10:22 AM
Hi Bob
Just to add to Peter post, one picture is worth a 1000 words.
Originally Posted by bobbotron View Post
Hi all,
post #5 of 15 (permalink) Old 04-12-2011, 08:01 PM Thread Starter
bobbotron's Avatar
First Name: Rob
Hey guys!
That's interesting, thanks for the info! Hrm, I get the idea... Bob, do you think you could post a photo of one of those oak cams unscrewed from board? And, is there a knob per cam on the underside to tighten down each cam?
I thought, another way to do it could be to have a number of verticle wooden clamps, attached to a table. I think that board would get less in the way of the skiis though.
post #6 of 15 (permalink) Old 04-13-2011, 08:32 AM
Hi Bob
I use Tee nuts on the back side of the board but it's not a must have item a simple dry wall screw will do the same job, screwed down to some scrap plywood..it's the off center hole that works on the cams lock blocks..
Just about any clamp will get the way of the router but the cams are below the edge of the lumber.
Hey guys!
post #7 of 15 (permalink) Old 04-13-2011, 08:53 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Hi all,
Whilst I have several cam boxes, in my humble opinion, pinning pieces of scrap material around the item is far simpler and very effective as I've shown in many of my threads, here is but one example.
Harry
harrysin is offline
post #8 of 15 (permalink) Old 04-13-2011, 09:11 AM Thread Starter
bobbotron's Avatar
First Name: Rob
Hi Bob
Ah, ok I get it now. It's morning here, and I took another look at your photo. I think I have some scrap plywood and jig hardware that would work well for this... Thanks!
post #9 of 15 (permalink) Old 12-15-2011, 06:12 PM
Hi all,
I see no-one replied so I thought I'd take a stab. I've used the rubberized drawer liner you can get at any household store to hold items to a workbench while routing. You just place the stuff on the workbench and then the item on that and it stays put. Same way that the Bench Cookies work.
If the stock is really thin or you're worried about it not staying put I'd build a small box/square around it via 1x1 stock, screwed into a flat board such as plywood, to hold it in place while skiing over it. That should trap it in place so it can't move.
PigBear is offline
post #10 of 15 (permalink) Old 12-15-2011, 06:15 PM
Ok that's weird the page loaded at first without any replies...probably the work web filter being screwy.
PigBear is offline
